Delete
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Keith120286, Apr 1, 2014.
  1. Apr 1, 2014 at 12:44 AM
    Keith120286
    Keith120286 [OP] Well-Known Member
    Kempner, Texas
    2013 Toyota Tacoma TRD Sport DCSB Auto 4X4
    Delete
  2. Apr 1, 2014 at 4:59 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    885x would be the way to go. If you want to achieve a full 3", you'll want the 10mm or 13mm lift enhancer. I'd go ahead and get UCA at that lift. Might as well do it right. No need for a diff drop.
    As far as the rear goes, it all depends what you'll be using your truck for.
  3. Apr 1, 2014 at 8:18 AM
    CO Taco
    CO Taco Well-Known Member
    Tyler
    Seattle,WA
    ‘25 SR5 4x4 Black
    Clazzio Seat Covers Black badge overlays All weather floor mats Glass navigation screen protector
    bump/sub
    I'm here for answers too (my truck is the same specs but an 08). I would think that adding three inches to the front we would only need 1.5'' AAL in the rear to level it out, but i'm only assuming here....
    anyone familiar with the mini 3 leaf pack toytec has optioned with the OME kit?
  4. Apr 1, 2014 at 8:25 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Do I need the top plate spacer? If you want full 3" in the front, yes
    Do I need the diff drop? No.
    Do I need to order new UCAs? Anything over 2-2.5" of lift is recommended
    AAL or Dakars? Depends on the use. Towing? Off-roading? On pavement? I went AAL at first and just put on the Dakars. Should have went Dakars from the beginning.
    I heard 885 coils were the way to way with the DC. Truth? I will not be running an offroad bumper or winch. 885s with no winch or bumper, yes.
  5. Apr 2, 2014 at 4:49 AM
    LEX
    Houston, Texas
    100 Series LC
    Then go with Dakars for the rear and probably some extended brake lines.
  6. Apr 2, 2014 at 5:02 AM
    geekhouse23
    ^^this.
    Would also recommend the D29XL to add to the dakar pack. It raises the spring height by 15mm and increases the spring rate for increased heavy load stability. Just installed this setup last weekend.
  7. Apr 2, 2014 at 6:05 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Where did you get these from?
  8. Apr 2, 2014 at 6:13 AM
    geekhouse23
  9. Apr 2, 2014 at 7:33 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get centre pin collars for the Dakars
  10. Apr 2, 2014 at 5:00 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Check it, also depends on funds, if you can afford dakers with the full lift do it.
    I did aal cuz dakers put lif out of price range. that was a year ago, soon ill have the dakers to put on.
    Did the same thing with the uca, at about 4" lift up front still running stock ucas, soon I will have LR ucas, however I have not been in a rush to do that cuz my alignments have been right in spec
  11. Apr 2, 2014 at 5:06 PM
    OZ-T
    Peter North
    British Columbia
    Dakars
  12. Apr 2, 2014 at 5:17 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I got the exact same setup. It rocks!!!!
    Do I need the top plate spacer? YES.
    Do I need the diff drop? NO.
    Do I need to order new UCAs? YES, get Total Caos
    AAL or Dakars? I WENT WITH DAKARS. Very satisfied.
    Yeah, the 885s are the best for full lift but will be a HARSH ride with factory front bumper and no winch.
    I got mine at in Southern Oregon. They were very helpful, knowledgeable and fair pricing. Highly recommended.
    I went with the OME shocks with 885 coils. Dakars leaf in rear with OME shocks. Metal brake line extenders.
    I did get the diff drop also, but never installed it. No need. So gave it away to a TW member.
    Later on I added a 1" body lift for other reasons...
  13. Apr 3, 2014 at 8:48 AM
    high voltage taco
    high voltage taco Well-Known Member
    Monticello, Ky
    05 TRD 6 speed 4x4
    so far, URD throwout bearing kit(sleeve), weathertechs, 285/70/17's on Ion 17x9 and OME 885s and Dakars and nitro sports. BHLM
    If your going to get top plate spacers for the front for full 3" then I would get the extra leaf for the rear. I don't have the top plate spacers with 885x's and I got about 2.8" front and 3.5 in back with dakars and no extra leaf. After hauling several loads of wood and hauling the tractor back and forth from our house to brother in laws for gardening the dakars have settled to about level. I've wound up with about 2.5 in front and 2.8 not hardly 3 in the back. I will be getting UCA's soon cause stock ones don't allow much droop.
  14. Apr 3, 2014 at 8:55 AM
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    i have the 886x with stock ucas but am buying some light racing ucas soon.. i also have the plate spacer ad it rides pretty smooth with my ARB bumper. I also plan on getting a winch for the front which is why i got the 886x, for all the added weight. In the rear, i still have OME shocks, but went the All-Pro leaf pack which has been great for extra weight in the back. Over all, I'm very pleased with my set up and it will be even better when i upgrade my UCAs. Hope this helped :D
