Delete
Discussion in 'Suspension' started by Travis1209, Jul 21, 2017.
  1. Jul 21, 2017 at 7:57 PM
    Travis1209
    Travis1209 [OP] Well-Known Member
    Travis
    2011 TRD Offroad Double Cab SB
    Delete
  2. Jul 21, 2017 at 8:09 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Save some money. Get the leafs replaced for free under the recall.
  3. Jul 21, 2017 at 8:13 PM
    Travis1209
    Travis
    No warranty so Toyota won't do it, i also read that the General Spring leaf springs are slightly more heavy duty than the factory OEM TSB. Which is what i would prefer since some people say that the rear has eventually sat lower than the front with the same setup with the TSB. So $400 will be worth it to me in the end
  4. Jul 21, 2017 at 8:15 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Don't need warranty for recalls
    Unless you mean your truck is not part of the recall
  5. Jul 21, 2017 at 8:27 PM
    Travis1209
    Travis
    Well I will call my local Toyota dealership again and see what they will do, tell them its a harsh ride when towing etc. First guy i talked to did seem a little lost..maybe ill figure something out. Won't be able to until Monday though. In the mean time I will still be fine with ordering the General Springs, they are "better" according to what others have to say about them compared to the TSB OEM leaf pack
  6. Jul 21, 2017 at 8:28 PM
    Travis1209
    Travis
    And ive got to imagine mine is part of the recall, i read all of them from 05-12 were eventually included in the recall
  7. Jul 21, 2017 at 8:37 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just go in there and tell them you need your leaf springs inspected and replaced under recall. Get those new leafs for free and add a three leaf progressive add a leaf pack.
  8. Jul 21, 2017 at 8:40 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    You can also check to see if your vehicle has any open recalls. Just Google "does my car have recalls" and some websites will come up.
  9. Jul 21, 2017 at 8:46 PM
    Travis1209
    Travis
    I did google if it needed a recall once before and if i remember correctly i found that it was not listed for any recalls. I could be wrong of course.
    As for an aal with a 4 leaf pack, im trying to get the truck level with 5100s up front set at 1.75". So an aal with a 4 leaf pack would give me a forward rake which I wouldnt prefer. Although if it does sag eventually, with the rear being lower than the front, then that would have to be the route for me to take
  10. Jul 21, 2017 at 8:49 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    The problem with just leveling the front is as soon as you tow or carry any weight in the bed you're driving around with the nose of the truck in the air.
  11. Jul 21, 2017 at 8:54 PM
    Travis1209
    Travis
    Right, not too big of a deal imo, since i dont need to tow often. Although i did think about it, which is why the General Springs sound good to me, due to them being slightly more "heavy duty" than the OEM 4 leaf pack, which should be enough to compensate for most of the truck being nose high when towing
