Delete
Discussion in 'Tonneau Covers, Caps and Shells' started by Off Topic Guy, Feb 12, 2024.
  1. Feb 12, 2024 at 7:33 AM
    Off Topic Guy
    Off Topic Guy [OP] 2023 Trophy Points - Runner Up
    Its common knowledge that the cab and bed of a truck flex independently of each other, so hard mounting something to both the cab and camper shell racks sounds like a bad idea obviously. My question is, how much travel should I expect to see between the two? Assuming I was in a scenario that flexed the cab/bed as far apart from each other as possible, what would the measurement of that difference likely be?
    For clarification, I'm looking at an XL RTT on a shortbed; instead of the overhang on the rear, it only makes sense to move the tent up towards the cab. I would obviously only hard mount it to the camper shell rack, but the overhanging tent on front would freely rest on 1-2 of the cab rack crossbars. This seems like a bad idea in my head, so wondering if others have done it, or if it would be in my better interest to use some sort of risers to mount the tent 1/2-1" (or however much flex may be possible) to alleviate the front of the tent from contacting the cab rack.
    Thoughts?
  2. Feb 12, 2024 at 7:37 AM
    Off Topic Guy
    @uploadadventure you're the only person I was able to find in my search for an XL rtt on a shortbed, where the overhang was towards the cab. Did your tent actually physically rest on the cab bars or was your bedrack slightly higher? Hard to tell from the pics you've uploaded, but I know you've wheeled your truck in all its different variations while you had it, so would love your input.
    uploadadventure likes this.
  3. Feb 12, 2024 at 8:08 AM
    Off Topic Guy
  4. Mar 4, 2024 at 3:39 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Sorry. I’ve been MIA.
    hope you found all the info you needed.
  5. Mar 5, 2024 at 6:15 AM
    Off Topic Guy
    I did, thanks! Ended up using some 1" risers on the topper rack to clear the cab rack.
  6. Mar 5, 2024 at 7:15 AM
    uploadadventure
    Dixon, Mo
    Good deal! I had to do that as well with a tent. An FSR tent as I recall.
    then I ended up trimming my uptop rack so that my tents fit right above it.
