--Delete--
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MY50cal, Jun 20, 2010.
  1. Jun 20, 2010 at 6:09 PM
    MY50cal
    MY50cal [OP] - IPFK -
    Mojo
    Chester County, PA
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Replacing both front hubs and CV shafts this weekend. Been researching and trying to get everything ready but i keep feeling like I'm forgetting things. Only thing I have so far is the CV shafts, the rest ill pick up this week.
    2x CV shafts -http://www.macautoparts.net/CV-Shafts-8224/5143020-2005-2006-Tayota-Tacoma/ProductInfo.aspx
    2x Wheel hubs - http://www.autozone.com/autozone/ca...mWhere=&searchText=wheelhubs&_requestid=82922
    1 3/8 socket for Hub nut - 35mm (thanks db67fm)
    19mm for lower ball joints
    drain and flush the front diff while im at it so -
    3qts 75-90 oil
    a couple of the write ups leading my way -
    http://www.tacomaterritory.com/forum/showthread.php?t=146572&highlight=replacement
    http://www.4x4wire.com/toyota/maintenance/cv_axle/
    I have to be missing something? I thought about replacing the bearings in the diff but i think you have to actually take the diff apart..??.. Any other suggestions? I'll take my time this weekend and make a nice write up afterwards. I really appreciate any and all input! Thanks Guys!!
    and because everybody likes pictures, this is one reason im doing this...
  2. Jun 21, 2010 at 1:03 AM
    MY50cal
    Mojo
    Chester County, PA
    Yep.
    nothing? :pout:
  3. Jun 21, 2010 at 7:45 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    The axle nut is actually 35 mm. 1 3/8 is very close and will work. I was only able to find a 36 mm and it worked fine too.
    Unless you have a bearing press, you will still have to get the bearing assembly pressed out of & into the hub. I took it to a local shop, it took them about a hour for both.
  4. Jun 21, 2010 at 10:36 AM
    MY50cal
    Mojo
    Chester County, PA
    Yep.
    haha, hard to tell with 1/2 of mud on it but ill check when i get it all clean this week. thanks!
    Hey Thanks db!! 35mm it is. As for the bearing press I am getting new hub assembly's as to avoid having to press in and out new bearings.... or am i mistaken?... :pray:
  5. Jun 21, 2010 at 10:52 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
    Take plenty of pictures an post them up here for those of us that need to do this.
  6. Jun 21, 2010 at 11:34 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    the hub nut is 35mm and you can get it at kragen for sure... i had to remove my front diff to install my RCD kit. Plus its a on there pretty damn good... an impact is probably needed.
  7. Jun 22, 2010 at 6:32 AM
    DDD
    Derek
    Santa Clarita, CA
    This is the part that most parts stores will sell you. They call it the "Wheel Bearing Hub Assembly". Is this the part that you bought?
    If you have this part then you still need to press the hub into the bearing.
    This is what the hub looks like without the bearing pressed on.
    So these 2 parts get pressed together.
    And the complete unit looks like this. (Although it should not be rusted)
  8. Jun 22, 2010 at 3:15 PM
    MY50cal
    Mojo
    Chester County, PA
    Yep.
    Fuck. My. Life....
    Thank you for setting me straight. That sucks, ill have to figure out a way to press them off and on. Just ordered them today.
  9. Jun 22, 2010 at 3:35 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD OffRoad Poser ψ(`∇´)ψ
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    a machine shop can do it, or any place that does metal welding. I got mine done for 30 bucks, took an hour, now i gotta do the other side too, but that will be in the future
  10. Jun 23, 2010 at 2:44 PM
    DDD
    Derek
    Santa Clarita, CA
    When I was changing mine it was a Saturday night at 7 pm. All local shops were closed and I did not want to wait for Monday.
    But, my local Pep Boys is open to 10pm and it took them 1 hour and $50 for both.
  11. Jun 23, 2010 at 10:45 PM
    MY50cal
    Mojo
    Chester County, PA
    Yep.
    nice, thanks bro. you have been a HUGE help! :cheers:
  12. Aug 24, 2010 at 9:23 PM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Thank you for this info, it will help me out in the next few days. My wheelbearing on drivers side is completely shot.
  13. Aug 24, 2010 at 9:33 PM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    I'm going top be doing mine tomorrow if I get my truck back on time, pics? Possible Write Up?
  14. Sep 28, 2010 at 11:25 PM
    Rich Beauregard
    Rich
    New London, CT
    I bought 2 hub assemblies from a 08 4x4 2dr 4 banger with 22k miles for $200 free shipping. The Tacoma these came off looked spotless, just crashed in back side. So I did not even have to press the bearings on/off, these were completely assembled original Toyota parts. Hell, I called my local stealership and They wanted $190 for one hub (With 6 lugs) & $176 for one bearing. I thought of buying a bearing off ebay for $90, but then all the pressing on/off and all that. So, now I have the bearings/hubs on my Tacoma (Driver side at this point) and the old ones sitting here as a spare. No pressing on/off! I know this sounds confuseing, I guess I should have taken photos. Maybe I can show some photos at a later time when I do the passenger side. (when needed.)
    2008 4x4 2dr 4 banger with 22k miles
  15. Oct 7, 2010 at 8:42 AM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    ^^^^^^ holy cow dude! I would've taken the tails. Looks like a bike hit that.
