Deleted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cypherian, Sep 23, 2011.
  1. Sep 23, 2011 at 8:30 PM
    Cypherian
    Cypherian [OP] Well-Known Member
    Mid Atlantic Region
    Deleted
  2. Sep 23, 2011 at 9:34 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    2. I like the painted engine cover I saw on one build looked slick does anyone know what paint manufacture color matches or is close to the silver Toyota uses?
    Start with Krylon primer meant for plastics. Then you can coat it with paint from Automotive Touch Up.
    6. Has anyone identified the wires you can tap into from the stock inverter to place a plug in the cab?
    Here is a link to the writeup I made:
    In Cab Outlet Tap
  3. Sep 23, 2011 at 10:21 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    As far as I have seen, there is no direct replacement for the stock flaps. If you want to replace them, you're best bet is likely the crappy generic ones you can get at Walmart.
    If you decide to trim them, reinforcing them with a metal strip along the bottom edge will be useless. The weak point is the plastic clips that hold the flap to the body panel.
