deleted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12Trd, Feb 16, 2014.
  1. Feb 16, 2014 at 11:52 AM
    12Trd
    12Trd [OP] Well-Known Member
    Rodney
    Elgin, Illinois
    2016 ORDC
    Deleted
  2. Feb 16, 2014 at 12:05 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Warranty does not get voided due to you changing oil. Take it in to get sample ran, including old oil w shavings if you have it.
  3. Feb 16, 2014 at 12:11 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Your warrant does not get voided by changing your own oil or using a wix filter. Toyota would have to prove the filter was the cause of the failure to void the warranty. If you still have the filter, take it with you and have it cut open to see how many shavings are in it. For a sanity check, I'd also see if they can have the oil pressure measured.
  4. Feb 16, 2014 at 12:13 PM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    Incorrect. The dealership has to prove that it was him changing the oil himself that caused the damage for it to void the warranty.
    It'll help if you have the receipts for the filter and oil... I remember some years ago that a bunch of mechanics sued to where a law passed that would allow them to work on customers' cars and it not void the warranty.
    Take it in and have them look at it, Although even if there wasn't any gray area's they would still probably not do anything because the truck is running and driving fine.
  5. Feb 16, 2014 at 12:49 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You need to take it in while it's still under warranty. This will 'document' a complaint (on your behalf) in case further issues develop.
    You mentioned you found these shavings on the filter itself.... Did you see any in the old oil that you drained out?? Or have you only seen it at or on the filter?
    Are you finding any shavings on the drain plug (magnet)?
    If you pull your dipstick, can you see it on the dipstick?
  6. Feb 16, 2014 at 12:53 PM
    rkd1119
    rkd1119 Well-Known Member
    Robert
    L.A. (lower Alabama)
    ‘23 Trail Edition Ice Cap
    Put a few hundred miles of this oil change then send the oil off to have it analyzed. We do this (oil scans) at the John Deere dealership I work for on equipment we want to certify for extended warranty. The place we use (its through JD) can scan engine oil, transmission (hydraulic in tractors), and even antifreeze. I don't know who to tell you to send it to, but I'm SURE there's places that do this for individuals.
    They can tell you what's wrong by what the particles in the oil are and what amounts of each there are. Good luck
  7. Feb 16, 2014 at 5:32 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
  8. Feb 17, 2014 at 12:26 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I work for a Deere dealership too. I think Hy-Gard smells good. Do you?
  9. Feb 17, 2014 at 12:59 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is not a good place to look. That filter housing surround can catch all kids of nasties.
    Were there " shavings " or just shiny specks in the drippings.
    Send a sample to Blackstone as mentioned above and quit sweating the load your drive train warranty is good for 60,000 miles.
  10. Feb 17, 2014 at 3:55 AM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Fixed first post. Sent from phone w/ autospell that changed what I wanted to say. Does NOT void warranty. Good advice above. Get it documented immediately then sample in a couple hundred miles.
