Deleted
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDinOhio, Jul 15, 2016.
  1. Jul 20, 2016 at 11:15 PM
    #241
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    OK, learned something new today. "shift flare" I previously stated I had none of the conditions mentioned in the TSB or all the other issues mentioned in this forum with my transmission.
    except for the 2-3 shift flare. Honestly, it only happens when the truck is cold and it never bothered me. Seemed to me like it was just a transmission 'warming up' kind of thing. Again, it's so minor that I never thought twice about it.
    Anyways, in dropping off my truck for the 10K service, I was originally against having the TSB done, but then I read about the 'shift flare' and thought - what the heck, i'll mention it and if they do the TSB, fine.. If they don't, it will be OK too.
    I got a call a few hours later that they didn't see any issues with the transmission (true, drives fine) but they did the TSB anyways. I have no idea if the shift flare is gone, as it only happens once in the morning when I leave for work, but i'll check tomorrow.
    The truck/transmission drives fine like before, but I do notice that it downshifts quicker, and overall has a livelier feel if you will. Again, I had no issues with the transmission prior. I only mentioned the shift flare to the service writer, because I read it here!
    Anyways, no regrets here. Truck is driving nice like before.
  2. Jul 21, 2016 at 4:31 AM
    #242
    stephensg66
    stephensg66 Member
    gary
    Does anyone know the TSB number for the trans shifting, mine shifts like crap. I have a 16 DCLB SR5 with the V6 and the AC60E trans?
  3. Jul 21, 2016 at 4:34 AM
    #243
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
  4. Jul 21, 2016 at 4:48 AM
    #244
    Mater16
    Mater16 New Member
    NC
    '16 TRD OFF ROAD
    My build date: 05/16 assembled in Texas.
    Two places where your truck can be assembled/built. . . . . Texas or Baja, Mexico
  5. Jul 21, 2016 at 6:32 AM
    #245
    dimead0zen
    dimead0zen Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    Based on my 50 miles or so of driving after the update, I believe it will help improve MPG.
    Before the update it would not even try to rev a high gear out upon acceleration, it would just jump into second gear and rev in the 3-4k+ RPM's (not good for MPG, not good for the trans, and it was not even trying to use the low end power of the engine... it drove like a Civic).
    After the update, it seems like it's staying in a high gear longer before downshifting, so when you slightly get on the gas pedal it will try to rev out 3rd or 4th gear instead of jumping to a lower gear right away. The update made shifting smoother and limited its tendency to skip to high RPMs. It's utilizing more of the low end power and lower RPM's, all leading me to believe MPG will improve maybe by a mile or two per gallon.
    We'll see over the next week or two. I do the same commute every day, and pre update I was getting 16.4 MPG.
  6. Jul 21, 2016 at 6:50 AM
    #246
    scottj2
    scottj2 Active Member
    I don't have the R->D issue, but I do have the cruise control issues, but honestly not too bad. However, my major problem is this:
    When I come to a stop, say at a red light, it will downshift normally. Then as I'm almost to a stop, it seems to upshift and harshly lurches forward. When I took it in for 5k service a couple of months ago and talked to the tech manager, he seemed to think it wasn't axle wrap, but the shifting patterns. He did mention that there was rumor of a TSB to address similar issues.
    I wonder if this TSB would address it.
    smitty99 likes this.
  7. Jul 21, 2016 at 7:12 AM
    #247
    Cavedog
    Cavedog Well-Known Member
    Eric
    Southern Minnesota
    2016 MGM AC Sport 4x4
    Just got this TSB done yesterday afternoon. I didn't have the R->D or P->D issues, or the hunting gears issue, just the problem where the transmission would stay in 4th gear while going up a hill with cruise control on and not shift back out of 4th gear.
    As far as I can tell it doesn't stay in 4th after the crest of a hill anymore, while using cruise control. The transmission now has a tendency to stay in gears longer, especially noticeable in 2nd and 3rd gear. It also takes 5-10% less throttle than before to downshift to 5th from 6th. For typical acceleration I found it to be an overall improvement, albeit relatively minor. As far as fuel economy goes, I've seen a 0.2mpg loss, but then again I've been mostly driving around trying to get a feel for the acceleration and testing the cruise control up inclines so this is likely influenced most by my driving habits. I'm still averaging right around 19.5mpg mixed.
    One thing worth noting is that it doesn't quite know what gear to be in some of the time, just like when I first bought the truck. This is probably due to the transmission learning being reset. I'm not really looking forward to having another ~1500 miles before it "learns" my driving habits again, I was actually pretty happy with the way it shifted before. I was expecting this though.
    Overall I'm happy with the change, like others have said it's a little like having ECT on for the first couple gears. I won't be able to have really useful feedback until I've been able to put a few more thousand miles on the truck.
    Kilokato and Swampcollie like this.
  8. Jul 21, 2016 at 7:32 AM
    #248
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    Took mine in tuesday for poor mpg and high revs with cruise control on. They told me yesterday they were running a diagnostic as per Toyota's rec. Called me this morning and said theres nothing wrong with the truck come get it. They will not perform the TSB as it doesnt apply to my VIN range. Im not real impressed with my first ever Toyota service on my $40k 3 week old truck.
  9. Jul 21, 2016 at 7:50 AM
    #249
    kharmajavah
    kharmajavah Member
    Sorry if I missed it, but was your fluid normal or low? I have the same build date, seems to me that most of the low fluid issues come from build dates prior to this April but I could be very wrong about that.
  10. Jul 21, 2016 at 7:58 AM
    #250
    poppy510
    poppy510 Well-Known Member
    For what it's worth:
    I did not have the problem you described. However, immediately after the TSB (which included clearing the Adaptive Learning at my request), I experienced the same downshift pattern when coming to a stop. I noticed it pulling to a stop to leave the dealer, and the first few stops thereafter. HOWEVER, it very quickly went away....like within a day.
    So I wonder if maybe you have a problem with the adaptive memory on your truck not "learning" the downshift pattern correctly. Or maybe your driving style demands an aggressive downshift.
    Don't want to send you down a rathole, just thought it was worth mentioning. I would get the TSB, and I would have the Adaptive Learning memory cleared. I had to fight them to do this, as it is not a part of the TSB.
    scottj2[QUOTED] likes this.
  11. Jul 21, 2016 at 8:04 AM
    #251
    mthopton
    mthopton Well-Known Member
    ‘03 TRD Prerunner, ‘16 TRD DCSB 4x4 - gone, 24 TRD OffRoad
    Interesting - although my VIN is listed and is a V6, my dealer says this TSB applies to the 2GR engine only (4-cyl). On the actual TSB it shows engine applicability to be 4-cyl only. What's the word here on that?
  12. Jul 21, 2016 at 8:07 AM
    #252
    kharmajavah
    kharmajavah Member
    Registered to provide some feedback:
    I was experiencing the R-D delay and funky shifting, searching, etc. Nothing that really bothered me too much, but it was a little obnoxious.
    I had the TSB performed in Tallahassee, Florida, on Monday. I think I was one of the first to come in and request it at this dealership. I gave the SA the TSB number, and it was performed no questions asked. I was there for a little over an hour. I noticed a difference immediately, and over the last several days I've had no R-D delay and the shift points seem much closer to the 2nd gen Tacomas I've driven (my brother had an '09, and I test drove several before deciding on the 2016). It absolutely drives differently, and much improved in my opinion, than it did on the day that I bought it and each day since.
    Too soon to tell on gas mileage, but it seems about the same.
    Basically, the TSB worked as advertised. Service was great and I'm pleased. I've had no other problems with the truck since I bought it (no hood issues, diff noise, leaf spring noise, etc.).
    I have NOT had the trans fluid checked. Honestly, the shifting issues and R-D delay screamed software issue to me and I was confident a TSB would be issued eventually.
  13. Jul 21, 2016 at 8:22 AM
    #253
    hyperlite986
    hyperlite986 Member
    I had the Fluid checked and was told it was good. I've been round and round with them about the delay early on and had poor results, so it's nice to know there is someone else in Tallahassee who got somewhere. I will be going for the update too. Who was your service manager if you don't mind me asking?
    Thanks!
  14. Jul 21, 2016 at 8:24 AM
    #254
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    2GR is 6cyl
  15. Jul 21, 2016 at 10:49 AM
    #255
    kharmajavah
    kharmajavah Member
    Good to know your fluid was good!
    His name was Joe Trozzo. Seemed like a nice guy. I told him what was going on, gave him the TSB number, and that was it. A little over an hour later I was out the door. I don't know if they tried to reproduce it or not, but I can't imagine people coming in and requesting a TSB if they weren't experiencing a problem.
    It's not like it turned the V6 into a V8 or anything, but it is a noticeable improvement.
  16. Jul 21, 2016 at 2:14 PM
    #256
    DarkSky
    DarkSky Well-Known Member
    Oregon
    2016 SR5 Double Cab V6 Auto 4X4 Barcelona Red
    Sorry if this has already been posted... what is the VIN range for the transmission TSB?
    Thanks!
  17. Jul 21, 2016 at 2:15 PM
    #257
    bensonxj
    bensonxj Well-Known Member
    2016 DCSB TRD Sport
    I had mine done this morning. Dealer did want to confirm the problems first. They said they didn't notice much of an issue but did it anyway because I came specifically asking for it to be done. However the tech said that he noticed a big difference in the transmission after it was finished on a test drive.
    For me only limited driving so far. Mostly city. Small trip in the mountains by my house but no road trip cruise control test yet. Transmission responsiveness around town is much much better. Shifts like prior cars and trucks that I have owned. Better off the line acceleration and doesn't try to shift too early. Going up the mountain noticed that it held the correct gear (in this case 4th) while going up rather than trying to drop to 5th, lose speed, and then down shift to 4th again. Much more pleasant to drive. MPGs seem about the same. 16.5 up the mountain. Didn't look at it when I came home. Ranging from 18-26 for short around town trips.
    Overall I am very pleased with the change and I still loved the truck before the TSB. It is just better now. No new problems have cropped up today associated with the re-flash.
  18. Jul 21, 2016 at 2:38 PM
    #258
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    So more update on mine since I got to drive to work and do the R-D from a cold start.
    There is basically ZERO lag now when cold going from R-D and the truck just drives so much better now. Also When I would stop on a hill and pointed down the hill and start going the truck would almost seem like its slipping starting off down the hill. The TSB seems to fix that as well. I will say I had a little gripe about the trans before the update and it was the only issue I had with the truck. Now the TSB seems to have solved all the issues and I have zero complaints about this truck now
  19. Jul 21, 2016 at 2:46 PM
    #259
    tripleseven
    tripleseven Well-Known Member
    Marin County, CA
    2016 TRD Offroad 4x4 - Super White
    How does this TSB work? Do they send you something in the mail, or should I be pro-active and call my dealer?
  20. Jul 21, 2016 at 2:47 PM
    #260
    bensonxj
    2016 DCSB TRD Sport
    I printed it off and took it to the dealer. They will not call you like a recall.
    Cavedog likes this.
