Deleting radio presets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewGuyJosh, May 30, 2014.
  1. May 30, 2014 at 6:00 AM
    NewGuyJosh
    NewGuyJosh [OP] Well-Known Member
    2014 double cab with entune plus (no navigation). I had satellite radio and set a few of the channels in my presets. I no longer have satellite radio and would like to remove them. However, I can't figure out to delete them and can't find it in the manual.
  2. May 30, 2014 at 9:16 AM
    kleffman
    kleffman Member
    San Diego
    2021 DCSB 4x4 OR
    I think you can only overwrite them with other stations...super annoying.
  3. May 30, 2014 at 9:30 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    You should be able to just disconnect the battery and everything should reset. You'll have to reset your clock and your Trip meters will be reset too.
  4. May 30, 2014 at 9:48 AM
    NewGuyJosh
    That's crazy. What the hell kind of radio won't let you delete a preset!
  5. May 30, 2014 at 9:50 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    In my Camry there is a delete for all saved personal info.
    Maybe this will help you......maybe not.
  6. May 30, 2014 at 9:52 AM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Why don't you just overwrite them with other FM stations?
  7. May 30, 2014 at 10:18 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    That's a good question however I have never been in a position where I ever needed to. It has always been a replace not remove. Do any vehicles have this ability other than disconnecting the battery?
  8. May 30, 2014 at 11:31 AM
    NewGuyJosh
    Yes. Every vehicle I have had allowed them to either be deleted individually or in groups (pages).
  9. May 30, 2014 at 11:39 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    Why? What's the point? Just save to new station or leave them alone.
  10. May 30, 2014 at 12:20 PM
    NewGuyJosh
    I live in a rural area and there are not enough stations that come in to replace the 2 pages of satellite stations saved. Likewise if I want to flip through my saved stations I don't want to go through 2 pages of satellite radio preview Channel which is what they all default to now.
  11. May 30, 2014 at 12:21 PM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    maybe you can find the fuse for the radio instead of disconnecting the battery.
  12. May 30, 2014 at 12:54 PM
    7shotguns
    7shotguns the captain
    Utah
    14 SR5 DCSB Black
    not much yet, I did tint the tail lights though.
    I have the same issue. I also can't stand my radio jumping from hd to non hd. Any way to fix that? Sorry for the jack
  13. May 30, 2014 at 12:55 PM
    TexAggie
    Eric
    Houston, TX
    OME Lift
    Got it. Personally I just set my presets from 1 to whatever and remember where they are and use my steering wheel controls to navigate through them. This is also due to me having a 13 model and not being able to split the screen.
  14. Jun 1, 2014 at 5:21 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    x2 adding that normally there are two OEM power connections to most radios. One is "hot" all of the time so you do not loose your presents and the second is controlled by the ignition switch. The fuse for the normally "hot" one will be smaller that for the switched radio power.
  15. Jun 1, 2014 at 5:30 AM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    I found this to be annoying as well.
