Delrin Bushings
Discussion in 'Suspension' started by weldo, Sep 28, 2018.
  1. Sep 28, 2018 at 7:20 PM
    weldo
    weldo [OP] Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Hey everyone!
    I’m seeking any and all information on the use of Delrin for suspension bushings. I’m looking to get the most out of my stock LCA and I think a harder bushing will allow the suspension to cycle much more freely than the oem rubber.
    Through my searching around it seems Delrin is mostly used by the long travel crowd and even then mostly on the LCA. Is there a reason they don’t appear on UCA very often?
    I’ve heard they transmit more vibration to the steering wheel. If anyone is daily driving a vehicle with Delrin bushings, can you weigh in on this?
    Solid bushings may be overkill for mid travel so I’m trying to determine if I should even be considering this.
    Thanks!
