Delta's 2002 Tacoma 4WD Build and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Apr 17, 2016 at 4:01 PM
    #1501
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Mine was $35 but i did not get it through a metal supplier.
  2. Apr 17, 2016 at 4:07 PM
    #1502
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Very very impressed with the bends. Nice work!
  3. Apr 17, 2016 at 4:37 PM
    #1503
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I need to do it too, plus belly skid. Then sell mine
  4. Apr 17, 2016 at 5:48 PM
    #1504
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hey @Delta00 whered you get your mesh from?
    And how thick do you think it is?
  5. Apr 17, 2016 at 5:58 PM
    #1505
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks, I'm very happy with them. My cheap angle grinder broke so I'm going to get another one tomorrow and hopefully have everything in place.
    I ordered it from HomerTaco. I don't know how thick it is but I'm sure he does.
  6. Apr 17, 2016 at 6:00 PM
    #1506
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Damn! He doesn't make 98-00 grilles, trying to get a light bar behind my grille and it's like a 1/2" too big. I was gonna do a whole new mesh but Fiolofab mounts his on the back of the grille. Just trying to find other options. Thanks tho I'll ask homer and see what he thinks
  7. Apr 17, 2016 at 6:06 PM
    #1507
    Delta00
    Troy
    Chandler AZ
    Check Build
    I'm sure he would sell a sheet of it. I did see some satoshi material at a metal supplier though. Not a home depot, an actually sheet metal one
  8. Apr 17, 2016 at 6:17 PM
    #1508
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yeah I just PM'd him, for how I want it I'd have to bend the mesh so I hope there's a way to do it. If not I'll mount the light bar to the bumper
  9. Apr 17, 2016 at 6:18 PM
    #1509
    Delta00
    Troy
    Chandler AZ
    Check Build
    What size is the bar?
  10. Apr 17, 2016 at 6:22 PM
    #1510
    BYJOSHCOOK
    Josh
    Check Out My Builds
    20" and it doesn't fit my current setup by like half an inch haha
  11. Apr 17, 2016 at 10:01 PM
    #1511
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    :woot: for that skid plate!
  12. Apr 18, 2016 at 7:53 AM
    #1512
    cynicalrider
    cynicalrider #NFG
    Jersey
    Skids looking good! Gonna fab up mounts to use the stock crossmember location?
  13. Apr 25, 2016 at 2:12 PM
    #1513
    Delta00
    Troy
    Chandler AZ
    Check Build
    Sorry just saw this yeah, stock crossmemeber.
    Also, spending $350 on maintenance rather than mods isn't as fun. LBJ and timing belt / pump soon.
  14. Apr 25, 2016 at 3:06 PM
    #1514
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I'm getting the timing belt and pump done on my truck on Wednesday. 40k miles overdue :anonymous: unless the previous owner had it done and it didnt go on the carfax
  15. Apr 25, 2016 at 3:13 PM
    #1515
    Delta00
    Troy
    Chandler AZ
    Check Build
    Doing it yourself? I've heard them go for a long time past the 90k reccomended replacement haha.
  16. Apr 25, 2016 at 3:14 PM
    #1516
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I feel ya. I recently spent like $230 on replacing the seals and bearing in my rear axle.
    Skid look good as well. I'm probably going to be lazy about and just by one from Eric at Relentless lol Also take at look at these http://www.ruffstuffspecialties.com/catalog/XMEMKIT.html You might want to use them for your belly skid, if you make one at all.
  17. Apr 25, 2016 at 3:18 PM
    #1517
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Nope! I don't have the tools to do it myself or the knowledge to fix whatever else i mess up in the process
  18. Apr 25, 2016 at 3:27 PM
    #1518
    Delta00
    Troy
    Chandler AZ
    Check Build
    Saved, im not sure if ill do a belly but you never know. I want to try making a bed rack next.....
    Nice, ill see how it goes when I attempt mine. Hopefully its not to bad.
  19. Apr 25, 2016 at 3:29 PM
    #1519
    cbechtold
    Cory
    Pleasanton, CA
    You're going to need a tube bender for that :p or just make it out of square tube... I'll be judging lel
  20. Apr 25, 2016 at 3:32 PM
    #1520
    Delta00
    Troy
    Chandler AZ
    Check Build
    Then youre going to have to judge hah, i want to make a box rocket replica.. What thickness do you think?
