Demello 1st Gen PreRunner Bumper ?'s
Discussion in '1st Gen. Tacomas (1995-2004)' started by AggiePilot12, Jan 14, 2013.
  1. Jan 14, 2013 at 1:15 PM
    AggiePilot12
    AggiePilot12 [OP] Well-Known Member
    Texas
    03 4x4 6" Double Cab
    6" Fabtech, All-Pro Leafs, Cold Air, Cat Delete
    Understand they're busy over at Demello, I have sent an email and a PM to Jason but no response so hopefully y'all can answer my questions:
    1) Are there existing license plate mounts?
    a) If so, can you flip up the license plate to access the 2 in. towing
    receiver? Similar to a vertical door hinge.
    b) If not, (why not?) would it be fairly easy to fab mounting spots?
    2) Can you use the stock spare tire access point underneath the tailgate
    via the supplied stock 'turn style rod'?
    3) Last ?: Has anyone had any trouble mounting this bumper? I am hoping
    bolt-on truly means bolt on. Not like the rock crusher sliders needing
    cutting/drilling/welding.
    Thanks TW
  2. Jan 14, 2013 at 3:19 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I have this exact bumper that I got from demello offroad about 3 or 4 years ago. It's a great looking bumper and has held up very well. License plate mount can be flipped up so you can access the 2" receiver. The bumper is truly bolt on it uses the factory holes to mount. I think it weighs like 60 lbs. give or take so you might need a hand when it comes to mounting. You can still use the spare tire access drop down.
