Demon Shackles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17taconut, Apr 15, 2022.
  1. Apr 15, 2022 at 12:37 PM
    17taconut
    17taconut [OP] Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Does anyone have opinions on the Demon Shackle kit for a 2017 TRD Off-Road? Thanks to all
  2. Apr 15, 2022 at 12:45 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    It’s the same for 2005 and up Tacomas I think. Personally, I had them and they looked like nipple rings. Also it’s held on by a single bolt and I wouldn’t pull too hard on it based on where it’s bolted on. They look cool though.
  3. Apr 18, 2022 at 11:06 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Personally I would never yank anyone out off of them.
  4. Apr 18, 2022 at 11:17 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Lots of opinions.
    https://www.tacomaworld.com/threads...-ring-upgrade-without-off-road-bumper.693625/
    https://www.tacomaworld.com/threads/demon-hooks-anyone-try-them.647227/
    I contacted the company and was told they were essentially for looks only:
    "Thanks for reaching out, Its up to you if you decide to use them for recovery, Mainly they are for looks but are able to handle up to 8k before bending/ causing damage to the hooks. The mounting brackets however are able to handle the full amount of the vehicles weight ratings. so if you choose not to use the hooks you can pull them off and attach to the mounting bracket."
    If you want a real recovery point get the ARB (I did) or get a good aftermarket bumper.
    https://arbusa.com/toyota-tacoma-2016-on/bumpers-protection-equipment/recovery-points/
