dent in fender
Discussion in '2nd Gen. Tacomas (2005-2015)' started by caseychai, Apr 12, 2013.
  1. Apr 12, 2013 at 9:42 PM
    caseychai
    caseychai [OP] Well-Known Member
    casey
    oahu
    2010 tacoma 4x4
    so i have a crease dent in my passenger fender. i have dent shield but they keep giving me the run around and saying they dont think they can fix it (whats the point of dent shield then). i was wondering if anyone could give me some tips on removing the dent myself. here are some pictures of the dents.
    -thanks
  2. Apr 12, 2013 at 9:49 PM
    4x4yota
    4x4yota 4wd is awesome
    Collin
    PA
    02 trd stepside v6
    Sry to hear....on the bright side it dont look that bad. Only sucky thing is that dents like that where its more a crease than a normal dent can be a pain....my guess would be pull the fender off and tap it with a hammer from the other side
  3. Apr 12, 2013 at 9:50 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    I know what will help a little.
    Take a hair dryer heat up the dent make sure the metal gets nice and toasty(not to toasty as you don't want to damage the paint). Immediately after spray keyboard cleaner in a can upside down.
    The heating and immediate super cooling will pull the dent out. Where that dent is at though it will not come completely out.
  4. Apr 12, 2013 at 9:52 PM
    monsterkx2fiddy
    Don't do this unless you like outy dents and most likely cracked paint.
    If you do ever get a huge dent you can hit it with your fist either on te inside or outside and it will fix it some.
  5. Apr 12, 2013 at 10:14 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Visit a few Toyota dealers that do paintless dent removal and get their opinion. I think the crease is likely too sharp, but it's better to let the technician assess.
  6. Apr 12, 2013 at 11:15 PM
    caseychai
    casey
    oahu
    2010 tacoma 4x4
    thanks for the suggestions! ill try it out, and update on how it goes.
    -thanks
  7. Apr 13, 2013 at 5:31 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    good body shop :cool:
