Deodorant...This is the pits. Hardy har har.
Discussion in 'Health' started by whippersnapper02, Oct 11, 2011.
  1. Oct 11, 2011 at 7:00 PM
    whippersnapper02
    whippersnapper02 [OP] Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    So guess what. I sweat a lot. I hate it but it happens. So the problem is that antiperspirants stain my pits white. This looks gross when I raise my arm and it ruins my expensive shirts. I haven't had luck removing the stains either. My normal deodorant was Degree but I recently switched the Crystal. Well now I have a rash on one side so I haven't been using it. I have stinky pits and I need to cure it. Anyone use Tom's deodorant? Should I just switch back to antiperspirant but switch from an A shirt to a full T shirt for undershirts?
    Help!
  2. Oct 11, 2011 at 7:56 PM
    Incognito
    Incognito μολὼν λαβέ
    Colton
    VA
    2012 Pyrite AC TRD OR
    See Build thread
    Full t-shirt with antiperspirant. Go with a v-neck if you don't want the undershirt showing.
  3. Oct 11, 2011 at 7:57 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    :eek:
  4. Oct 11, 2011 at 8:00 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    N/M.... just re-read the op
  5. Oct 11, 2011 at 8:02 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    I have on accident a few times since I didn't read the lable. I melt right through any deodorant especially if I'm active.
  6. Oct 11, 2011 at 8:02 PM
    Incognito
    Colton
    VA
    See Build thread
    I knew somebody would say something about that... :laugh: It's acceptable to wear one as long as you use it as an undershirt only.
  7. Oct 11, 2011 at 8:02 PM
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    I sweat a lot too and i use Gillete Clinical sport. shit works wonders and i rock two shirts as well. Undershirt v-neck and a normal shirt
  8. Oct 11, 2011 at 8:02 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    I may consider it. I wear wife beaters now.
  9. Oct 11, 2011 at 8:04 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    i use degree invisible stick. not a stain yet
  10. Oct 11, 2011 at 8:07 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    08 TRD Sport
    5100's @ .85, Custom Grill, Debadged, Bestop Supertop, BHLM, DDM 4500k HID heads, Nokya 2500k fogs, LED interior lights, Weathertech Mats...
    i wear tee shirts for this same reason.
    you can try soaking the shirts in vinegar or LESToil solution before washing
    i switch deoderant brands every week, rotate between 3 or 4
  11. Oct 11, 2011 at 8:07 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    That's what I used. It stained my shirts up pretty good.
    I tried white vinegar and Oxiclean. No luck with either even when soaking for a day. The hard crust is still there. I ended up buying all new shirts.
  12. Oct 11, 2011 at 8:08 PM
    pudge151
    Sean
    Connecticut
    08 TRD Sport
    its your sweat not the deoderant staining your shirts
  13. Oct 11, 2011 at 8:09 PM
    MTgirl
    MTgirl too many frogs, not enough princes...
    Weesa
    in the kitchen
    99 - 3.4L V6 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    Try putting the deodorant on before you go to bed. Most people sweat less at night and it gives the active chemicals in the deodorant more time to absorb into your skin and become more effective.
  14. Oct 11, 2011 at 8:09 PM
    red taco
    red taco Well-Known Member
    Cole
    La Verne, CA
    07 PreRunner Impulse Red Pearl
    Old Spice! and X2 on V-necks for undershirts only
  15. Oct 11, 2011 at 8:13 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    No I'm sure it is the Aluminium zirconium tetrachlorohydrex in the antiperspirant. I have no issues with this new deodorant.
    Hmmm. I may try that. I still have to get something else since my body doesn't like the natural stuff.
  16. Oct 11, 2011 at 8:13 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    Use women's deodorant... :eek:
    I have not personally tried it, but I have friends who have and it has worked.
    Oh and about using deodorant at night. That is actually a bad idea. If you do not sweat like a pig while sleeping, try to not use deodorant, so as to give that area some rest. Deodorant can become toxic you know...
  17. Oct 11, 2011 at 8:17 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    I may have to resort to it. I hate sweating so much. I'm in an air conditioned office and I am slightly warm for no reason.
    I think she meant apply at night and not reapply in the morning but I shower in the morning.
  18. Oct 11, 2011 at 8:24 PM
    MTgirl
    Weesa
    in the kitchen
    99 - 3.4L V6 4WD
    so i mistakenly said deodorant and not antiperspirant before.
    If your armpits are damp -- as they are after you towel off from a shower -- the antiperspirant will mix with that wetness and slide off your skin instead of into the sweat ducts where you need it most. That’s why it’s best to apply antiperspirant at bedtime, when your underarms are dry and you’ve got about 8 hours of relatively sweat-free slumber to allow the aluminum ingredient in antiperspirants to go to work.
    http://www.webmd.com/healthy-beauty/sweating-too-much-11/antiperspirant-ingredients
    Yeah, the article says 'women' in the title...get over it. :cool:
  19. Oct 11, 2011 at 8:25 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    NOOOOOOOO dont tell me that.. well actually i dont sweat when i have t shirts on.. i usually run with not shirt on or take it off as i start to sweat.
  20. Oct 11, 2011 at 8:29 PM
    I Liquid I
    Puerto Rico
    Don't take what I said in an offensive way... It was in no way directed at you. I just typed what I've learned. Also, I used the word deodorant loosely, because when I say deodorant I refer to products that have both a deodorant and an antiperspirant.
