Depo JDM Headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSeg23, Feb 2, 2017.
  1. Feb 2, 2017 at 8:39 AM
    BSeg23
    BSeg23 [OP] Well-Known Member
    2005 Super White TRD Offroad
    JoeTacoma02 likes this.
  2. Feb 2, 2017 at 10:53 AM
    BSeg23
    Well guess I'll be the guinea pig then, their taillights seem to be good quality.
  3. Feb 2, 2017 at 10:55 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    EDIT - snag those puppies!!!!!!!!!
    airrage and BSeg23[OP] like this.
  4. Feb 2, 2017 at 10:59 AM
    BSeg23
    Thanks for the input. I'll probably hold off then, maybe I'll get the balls to do BHLM on my own lights one of these weekends.
    ChadsPride likes this.
  5. Feb 2, 2017 at 10:59 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I've had them for a couple years.
    You need to clear silicone the entire light where it attaches to the lens. Very easy.
    They are prone to fog , but mine never have after the above ....
    Light output is not as good as stock, but still good enough. I have lots of extra lights.
    My lenses have never faded. I live in the hottest place on earth.
    Az
    BSeg23[OP] and ChadsPride like this.
  6. Feb 2, 2017 at 11:00 AM
    BSeg23
    Thanks!
  7. Feb 2, 2017 at 11:02 AM
    BSeg23
    Do you have a pic of how the look installed?
  8. Feb 2, 2017 at 11:03 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I have a set of Depos right now and so far so good. I get about 3 sets before I pay the price of OEM ones.
    Atlas86, Mademan925, Sje1124 and 4 others like this.
  9. Feb 2, 2017 at 11:05 AM
    ChadsPride
    :bikewheelie:
  10. Feb 2, 2017 at 11:06 AM
    AZBACKCOUNTRY
    Doug
    These aren't the best pics, was installing my Pelfreybilt front :)
    I've done the bhlm on a set of oem and they are near that look for sure.
    Like @Iggy said you may go through 2 pairs in the life of the truck, but still cheaper then OEM.
    I know lots of guys retro fit these lights, and have good success.
  11. Feb 2, 2017 at 11:08 AM
    AZBACKCOUNTRY
    Doug
    ChadsPride and BSeg23[OP] like this.
  12. Feb 2, 2017 at 11:09 AM
    BSeg23
    Awesome, thanks guys, think I'll give them a shot
  13. Feb 2, 2017 at 11:13 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Do they have them in 12-15?
  14. Feb 2, 2017 at 11:16 AM
    BSeg23
    I did a quick search on ebay and didn't see any Depo JDM for 12-15, plenty of other choices though
  15. Feb 2, 2017 at 11:17 AM
    AZBACKCOUNTRY
    Doug
  16. Feb 2, 2017 at 2:44 PM
    BSeg23
    Just ordered them, I'll update with a pic once installed
    ChadsPride and AZBACKCOUNTRY like this.
  17. Feb 2, 2017 at 2:58 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I literally installed a pair of these yesterday. I too had seen cautions from people saying they would leak if not sealed. Not an issue. $5 for a tube of clear silicone and I went to town on EVERY seam even if it looked fine. I let it cure and then installed them. They look great so far. Only time will tell with regards to leaking or fogging.
    One suggestion I have is to simply eliminate the bottom bracket that attaches via a screw to the inside of the fender behind the fender liner. It makes it a ROYAL BITCH to get the headlight in and out. I eliminated the bottom part (closest to the tire) and rocked it that way for the last 5 years. Three mounting points are really all you need (top two and the bottom one by the grill). Really makes it a ton easier in my opinion.
    Corny Taco and ChadsPride like this.
  18. Feb 2, 2017 at 3:10 PM
    BSeg23
    Awesome, thanks man!
  19. Feb 2, 2017 at 3:22 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Love them! I suggest putting a silicon bead around the edges though. My first set leaked on me around 1 week in. (Pic below of the first set)
    Atlas86, ChadsPride and BSeg23[OP] like this.
  20. Feb 2, 2017 at 3:48 PM
    frejil
    frejil Well-Known Member
    Andrew
    2006 Prerunner
    Depo headlights
    I love mine. Something weird about the lenses though, can't aim them 100% straight but it's not really a problem. Close enough
