depressurize the fuel system?
Discussion in 'Technical Chat' started by sgtlethargic, Jun 15, 2008.
  1. Jun 15, 2008 at 12:26 PM
    sgtlethargic
    sgtlethargic [OP] Well-Known Member
    I'm to the point of removing the fuel rail and injectors and I haven't seen anything in the on-line manuals about depressurizing the fuel system. Does it need to be depressurized and how? Or, not?
    Thanks,
    Kurt
  2. Jun 15, 2008 at 12:36 PM
    sgtlethargic
    http://www1.autozone.com/shopping/repairGuide.htm?pageId=0900c15280037453
    Relieving Fuel System Pressure
    Toyota Pick-ups, Land Cruiser, and 4 Runner 1997-00
    To relieve the fuel pressure, wrap a clean shop cloth around the union bolt (banjo bolt) at the fuel delivery rail. Slowly loosen the bolt holding the fuel line and allow pressurized fuel to escape into the cloth. Do NOT allow fuel to spray from the fitting; always wrap it in a clean cloth.
    Pressure may also be relieved at the fuel filter, if desired. Tighten the union bolt.
  3. Jun 15, 2008 at 12:42 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Just take off the gas cap to de-pressureize it.
  4. Jun 15, 2008 at 6:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Also, you can take out the EFI fuse and crank the engine for a few seconds. :)
    That only de presurizes the gas tank. The fuel injection can hold psi for a LONG time. :)
