Derping-How to?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wolftaco0503, Mar 10, 2016.
  1. Mar 10, 2016 at 9:42 PM
    Wolftaco0503
    Wolftaco0503 [OP] Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    I looked all over TW even the search. But it gave me 10+pages of the word derping, to a how to or write up. Thanks
  2. Mar 10, 2016 at 9:48 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Did you look up plasti dip that's what it's called.
  3. Mar 10, 2016 at 10:05 PM
    medic2230
    Murph
    Bama! Roll Tide
    Here's the mega thread for the Plastidip.
    https://www.tacomaworld.com/threads/the-plasti-dip-mega-thread.124474/
    It's easy.
    1) Grab some 2" blue painter's tape and place it around emblems about 2" away from them.
    2) cover surrounding area with newspaper to contain the overspray.
    3) light coats are better. 1st coat you should still be able to see the chrome on your emblems.
    4) 15 minutes later give it another light coat
    5) continue this until you have 4-5 coats on it and it's completely covered.
    6) let it sit a good hour or so after last coat to dry.
    7) peel off the tape and newspaper around emblem
    8) grab the edge of the derp that is around your emblem and start pulling it off the truck. When you get it to the emblem be careful and pull it away from the emblem and it will cut itself along the letters.
    9) Use a toothpick to get it loose inside the letters. The toothpick won't scratch the paint like metal will.
    10) Sit back and enjoy your new black emblems or whatever color you choose to do them.
  4. Mar 11, 2016 at 6:35 AM
    Wolftaco0503
    Adam
    Chicago
    Thank you will be doing this when the weather warms up
  5. Mar 11, 2016 at 6:47 AM
    Iowa10
    Iowa10 Well-Known Member
    Last weekend, I did all my badges as well as the grille and rear bumper. Loving it so far. It was very simple.
  6. Mar 11, 2016 at 6:38 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  7. Mar 11, 2016 at 6:39 PM
    Manwithoutaplan
    ID
    don't do it just paint it!
  8. Mar 11, 2016 at 6:42 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Make sure you either wait till it warms up or you pre-heat your cans(I prefer waiting until it warms up but I can done the can down the pants method) if you don't it'll splatter and have the texture of bed liner
  9. Mar 12, 2016 at 3:56 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    I dismounted my wheels and cleaned them well with regular car wash soap and the wash mitt.
    I painted center caps separately with them removed.
    For the wheel I did not mask off anything just sprayed it took one can per tire to do front and back of rim, some over spray got on the rubber of the tire it just falls off after a week or two.
    It needs to be at least 60 degrees out, the warmer the better.
    Don't overthink it, just do it.
    medic2230 likes this.
