Desert Products UCAs
Discussion in 'Suspension' started by MKW, Dec 3, 2014.
  1. Dec 3, 2014 at 4:38 PM
    MKW
    MKW [OP] Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    Anybody run them?? Any good??
  2. Dec 3, 2014 at 4:43 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    I have a set and they've been great for me so far. I do some rock crawling and I like to go at moderately fast speeds on certain trails. I don't really know what else to say other than I've had them for about 6 months now and I've gone wheeling numerous times and they've been good to me.
  3. Dec 3, 2014 at 6:01 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    They've treated me well. Typical aftermarket uniball UCA annoyances at first (squeaking and creaking). Get yourself a grease gun and some lube for the uniballs. I needed to grease the bushings for a few months after install, but the squeaking hasn't come back since.
  4. Dec 3, 2014 at 7:17 PM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    Thanks, fellas. They seem to be about in the middle of the price curve and they are tig welded, which I like. I think I'll give them a try. I would imagine that most all urethane bushings squeak at first, but I don't really know.
  5. Apr 7, 2015 at 4:07 PM
    DevL
    DevL Well-Known Member
    I greased mine during install and they did not squeak for 2 years. I told the guys who change my oil to grease them during oil changes and they did not... been squeaking lately. I don't know if that has harmed the bushings or not but those UCA are a PITA to remove and install on 05+ Tacomas so I hope they just need a shot of grease.
    They give just over 2 degrees of caster so they push your wheel and tire to the rear of the fender... you will NEED a CMC to clear 33" tires and as aggressive of a cut as possible. My tires (33.1") actually hit my liner at full stuff when squared up straight on full stuff and that is with over 3 degrees of caster up front.
  6. Apr 7, 2015 at 4:52 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    There was some debate as to how everyone caster is set and there cab mount clearance. Apparently the new UCA has caster adjust but the people that have had most success are adjusting the LCA forward instead of the UCA backward. Thus gaining more caster. Idk how to adjust caster via the LCA...
  7. Apr 9, 2015 at 4:27 AM
    DevL
    The only caster adjustment is on the LCA. It's the alignment tab. The upper on a uniball is fixed and the ball is more to the rear which is how you get the caster. With lots of lift you run out of room on the lower and cannot hit 2 degrees. By the upper ball moving back (by being built that way) it places the wheel on a back tilt, adding caster but also moves the wheel more to the rear. The only exception is the light racing unit which has adjustable eccentric bolt positions... Stock, add 1 degree, add 2 degree, etc. Uniball UCA are welded in place and cannot be adjusted.
