Desperate for help. Truck is shaking, engine light and TRAC OFF light.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by junglefighter25, Jul 5, 2016.
  1. Jul 5, 2016 at 4:20 PM
    junglefighter25
    junglefighter25 [OP] Well-Known Member
    Bob
    Charlotte, NC
    1996, 1999, 2011, 2013, 2016 Tacoma
    I have a 2013 4WD DC TRD Sport. I have about 139,000 miles on it. I get regular services every 5,000 miles or so.
    I was driving home today, about 40 mph, and my truck started shaking violently. The engine on light and TRAC OFF light came on. I could not accelerate past 40 mph.
    I took it to a shop, and after a diagnostic check, they noticed that I was missing on one cylinder. They said that getting new plugs and a tuneup would fix my truck.
    I paid $430 for the plugs and tune up, then left the shop. 1 block later, the lights were back on, and my truck is shaking.
    Is it possible that my 4WD switch is not disengaging? Here's what I'm thinking:
    -I have been noticing that it has been a bitch to get out of 4WD lately. I have to roll back and forth to get back to 2WD from 4WD. It's never easy. I get the blinking 4WD icon, for a long time.
    -I am getting that shaking feeling when I make a sharp turn, like I get when I am in 4LOW.
    -I can't accelerate more than 40 MPH, like when I'm in 4LOW.
    I disconnected the battery and reset the truck. It all went back to normal for about 2 miles, then the same crap started again.
    When I turn off my truck, the engine and TRAC lights are gone, and everything looks normal. I start driving, and within 30 seconds, the shaking and lights.
    Please help!!!!
    ChadsPride likes this.
  2. Jul 5, 2016 at 4:34 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Someone correct me if I'm wrong, but in 4lo you shouldn't be going anywhere near 40mph...not good for the transfer case. 15-20mph max in 4lo, otherwise you should be in 4hi.
    This doesn't sound like a 4x4 issue (though what you describe with your 4wd is probably a separate issue of it's own...), it sounds like the shop you took it to didn't fix the cylinder misfire and your truck is going into limp mode (allows you to drive it to safety but not much else).
    I've seen threads on here for cylinder misfires before so hopefully someone else can chime in on where to go with that issue
    Arailt and ChadsPride like this.
  3. Jul 5, 2016 at 4:37 PM
    junglefighter25
    Bob
    Charlotte, NC
    Dude, I'm no mechanic. I'm grasping at straws. The limp mode sounds completely reasonable. I just mentioned that it might be stuck in 4WD because I'm too lame to make a smart diagnosis. I appreciate your help Eon_Blue.
  4. Jul 5, 2016 at 4:38 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    ADD not disengaged?
  5. Jul 5, 2016 at 4:42 PM
    eon_blue
    Azusa, CA
    No worries, I'm not trying to come off harsh or anything...I just think based on what it sounds like, the cylinder misfire wasn't resolved and is unrelated to the trouble you're having getting into 4wd. I'm no mechanic myself, but I'd definitely take it back to where you just had the work done and tell them that they didn't fix the issue. They should be willing to work with you since they weren't able to properly remedy the issue the first time around. Good luck, I truly hope it's nothing too serious
  6. Jul 5, 2016 at 4:44 PM
    junglefighter25
    Bob
    Charlotte, NC
    Like I said, thanks man. I buy new trucks every 2 or 3 years so that I don't have to deal with this shit. I go to a shop and I get screwed because I'm a retard.
    TXpro4X4 and ChadsPride like this.
  7. Jul 5, 2016 at 4:45 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    $430 for plugs and a "tune up" on a fuel injected motor???
    Dude.... go to a trusted mechanic next time...
  8. Jul 5, 2016 at 4:48 PM
    junglefighter25
    Bob
    Charlotte, NC
    I live out of the way. I took it to the nearest shop. I get my oil changes there, and they've always been good.
  9. Jul 5, 2016 at 5:00 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    They probably thought they fixed it. Have them check it again.
    Your best bet for help is to get the codes that it's throwing, then search for solutions for those codes specifically for 2013 Tacoma.
    The running rough could be a type of limp mode, in my experiences with other vehicles, going into limp mode usually means loss of some type of critical information that the computer can only deal with by going into limp mode to safeguard. Things like cam or crank position sensor, MAF sensor, things like that. But all this is just guessing until you pull the codes.
  10. Jul 5, 2016 at 5:02 PM
    junglefighter25
    Bob
    Charlotte, NC
    Man, I am going there tomorrow morning when they open. Thanks for the advice, man.
  11. Jul 5, 2016 at 5:05 PM
    Nickel
    Diego
    2013 T/X TRD
    No problem, good luck.
    Hopefully the shop can make it right, quickly.
  12. Jul 5, 2016 at 5:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    Wow!
    scottalot, Pigpen and ChadsPride like this.
  13. Jul 5, 2016 at 8:26 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    This should be easy to check. When the truck starts shaking, pull over, stop, get underneath and try to turn the front driveshaft. If the ADD is disengaged, the shaft will turn freely.
  14. Jul 6, 2016 at 8:37 AM
    junglefighter25
    Bob
    Charlotte, NC
    Turns out the coil was bad, and was replaced this morning. Cylinder 1 was misfiring causing cylinder 5 to misfire as well.
    I am at the dealership to trade the it in for a 2016. I need to keep them fresh.
    I appreciate the help everybody.
  15. Jul 6, 2016 at 8:46 AM
    splitbolt
    NW Arkansas
    Out of the frying pan and into the fire; I like it.:bananadead:
    wilcam47, Arailt and 12TRDTacoma like this.
  16. Jul 6, 2016 at 8:58 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    No kidding. I missed that originally in the post. That's insane mileage.
    What kind of work do you do OP that you drive that much?
  17. Jul 6, 2016 at 10:53 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Oh No!
    12TRDTacoma and scottalot like this.
  18. Jul 6, 2016 at 12:03 PM
    Eric J
    Eric J Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    Keep it under 5mph in 4low. Shift from 2hi-4hi on the fly owners manual says under 62mph I usally idle in the drive at about 10 and turn to 4hi usally blinks 2 times then goes solid. Disengage the same way!
  19. Jul 6, 2016 at 2:36 PM
    junglefighter25
    Bob
    Charlotte, NC
    I service and calibrate wastewater flow monitoring systems. I drive all over NC and SC.
    Basically, I drive 3 hours out and do 10 minutes worth of work, and make a couple of stops on the way back.
  20. Jul 6, 2016 at 5:14 PM
    Nickel
    Diego
    2013 T/X TRD
    Cool, enjoy the new truck!
    junglefighter25[OP] likes this.
