Destroyed my front diff drain plug...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OdiN1701, Jul 22, 2020.
  1. Jul 22, 2020 at 7:29 AM
    OdiN1701
    OdiN1701 [OP] Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Who designed that dumb thing? Anyway replaced it with the bolt head version.
    Also, how the heck do you guys get your diff oil so bad? I had about 50K on my diff oil, and it was still clear-ish coming out. I saw threads here where someone had it super black after what he said was only 5K.
    Magnet was pretty typical, a few bits of metal in the oil but nothing concerning.
    2016Tacoman and Junkhead like this.
  2. Jul 22, 2020 at 7:41 AM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    How did you destroy it? Spray with PB blaster, let sit for 10 mins. Hit the plug with a hammer. Then the hex on a 2’ breaker bar.
    Snowman and JasonLee like this.
  3. Jul 22, 2020 at 7:45 AM
    OdiN1701
    Colorado
    Yup, and the breaker bar wouldn't get it off, and it started rounding out the plug. I ended up hammering the hex into it and using an impact to break it free.
    2016Tacoman and BillsSR5 like this.
  4. Jul 22, 2020 at 7:46 AM
    tiogacruiser
    tiogacruiser New Member
    Kilo
    FJ Cruiser
    Do you have the hex head or Allen key?
    There's some interchangeable part numbers for the 8" to get a recessed plug with the magnet.
  5. Jul 22, 2020 at 7:48 AM
    OdiN1701
    Colorado
    Well NOW I have this:
  6. Jul 22, 2020 at 7:52 AM
    OdiN1701
    Colorado
    It was the allen key, if you want to call it that.
  7. Jul 22, 2020 at 9:38 AM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    Is the new plug a 10mm?
  8. Jul 22, 2020 at 9:39 AM
    OdiN1701
    Colorado
    14mm head on the new one.
    shakerhood and TengoTaco[QUOTED] like this.
  9. Jul 22, 2020 at 9:41 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    HAHHA I'm sorry OP!!! At least you're taking one for the 3rd gen team!!!
    AKGSD likes this.
  10. Jul 22, 2020 at 9:41 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I wager that you're on the end of the spectrum of never being in 4wd and only drive on pavement, while the 5k changers are on the end of the spectrum of having 35's and only drive off road.
    usmc2msu and Gunshot-6A like this.
  11. Jul 22, 2020 at 9:44 AM
    OdiN1701
    Colorado
    I do a mix of on and off road.
    TengoTaco and Junkhead like this.
  12. Jul 22, 2020 at 10:20 AM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    That’s good, it should give you more mechanical advantage for next removal. I changed out the front fluid, no issues. But we don’t have to deal with any salt on the roads around here,
  13. Jul 22, 2020 at 10:27 AM
    OdiN1701
    Colorado
    Yeah plenty of crud here. I don't know why they didn't put bolt heads on it anyway, especially when it's torqued to 49 ft lbs.
  14. Jul 22, 2020 at 10:59 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Same happened to me. Horrible design. Had to weld the Socket directly to the plug..came right out. Replaced it with the Lexus version that has a hex head.
  15. Jul 22, 2020 at 11:32 AM
    OdiN1701
    Colorado
    Thankfully I didn't have to go that far.
  16. Jul 22, 2020 at 11:36 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    did the same
  17. Jul 22, 2020 at 11:56 AM
    iptman
    iptman Well-Known Member
    Northen VA
    2018 TRD Pro, 1997 Land Cruiser, 1977 Land Cruiser
    These plugs have a metal crush gasket right? If you're having to use a breaker bar it was way over torqued when it was installed. Those don't even have a torque spec as far as I've seen so elbow tight is plenty. The problem with the external hex bolts is it can be popped loose while wheeling and eventually fall out. Seen this happen a few times. In the Land Cruiser world most people who wheel their junk swap to the 10mm internal hex like the Tacoma has.
  18. Jul 22, 2020 at 11:59 AM
    OdiN1701
    Colorado
    The top plug has a crush washer, the bottom one is just a flat copper washer.
    The skid covers the hex head bolt, I don't see how it could just "pop out".
    usmc2msu and iptman[QUOTED] like this.
  19. Jul 22, 2020 at 12:14 PM
    iptman
    Northen VA
    Had to go look at my truck, is that the drain plug on the DS side of the diff housing? Yeah, that'd be hard to bump out even if you didn't have a skid there.
  20. Jul 22, 2020 at 12:20 PM
    OdiN1701
    Colorado
    Yeah that's the front diff drain plug.
    Skydvrr likes this.
