Destroying front axles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scotimac, Dec 17, 2013.
  1. Dec 17, 2013 at 9:20 AM
    scotimac
    scotimac [OP] New Member
    Scott
    CT
    2008 tocoma
    2.5" lift front end
    I have a 2008 tocoma that I put a 2.5" daystar over the strut assembly type lift kit in feb 2011.Last winter I got into an accident and had to replace my right CV axle so I replaced them both.last week while plowing the right axle broke. A tech at daystar told me it might be that the stock axles are longer than after market. He also said theres something made to reduce the angel of the axle. Any info would be helpful
  2. Dec 17, 2013 at 10:12 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Why not go back to the stock axles? They're pretty tough as is.
  3. Dec 17, 2013 at 10:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The only thing you're going to do to reduce the angle of the axles is lower your lift. The 'item' the Daystar tech is referring to is a differential drop but they don't work on 2nd Gens. All they do is rotate the diff and do very little to reduce the CV angles.
    Last week's snow was very wet and heavy and also had a lot of ice. Plowing puts a lot of strain on the drive line components so it's very possible that one of your CV's just broke because there was too much strain on them and not because there was an underlying reason. The aftermarket CV might not have been as strong as OEM to begin with and the plowing could have done you in.
  4. Dec 17, 2013 at 11:14 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    x2. A lot of aftermarket axles are hollow like a tube instead of being soild. For parts like these, replace with OEM.
