Desulphation mode of Schumacher 1200?
Discussion in 'Off-Topic Discussion' started by pinktaco808, Feb 21, 2017.
  1. Feb 21, 2017 at 7:35 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    I bought a schumacher 1200sc/a charger. How do I get to the desulphation mode? It say it has in the manual, but doesn't show how to set it. Does it automatically detect it and go into that mode?
  2. Feb 21, 2017 at 7:39 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
  3. Feb 21, 2017 at 8:20 PM
    pinktaco808
    Soo it will only detect it if it has to be desulphated? You can't manually set it right? How will it know? I think I should have gotten the ctek7000 instead. Cause you can manually desulphate the battery no matter how bad it is.
  4. Feb 21, 2017 at 8:35 PM
    pinktaco808
    Thanks for the help though man.
  5. Feb 22, 2017 at 7:01 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Lol idk man I just did a quick google search and came up with that... I don't actually have one of these chargers.
  6. Feb 22, 2017 at 10:28 PM
    pinktaco808
    Anyone know why when I charge a reg lead acid battery it says it 100% charge, but doesn't go into float mode?
  7. Feb 23, 2017 at 10:26 PM
    pinktaco808
  8. Feb 24, 2017 at 9:34 PM
    pinktaco808
  9. Feb 24, 2017 at 9:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you sure its not? Have you checked with a MM to see if there is more voltage present with the charger attached vs not attached?
    pinktaco808[OP] likes this.
  10. Feb 24, 2017 at 9:41 PM
    pinktaco808
    Yes cause I charged my other car battery agm and it went into the float mode.
  11. Feb 24, 2017 at 9:45 PM
    pinktaco808
    Yes it charges but won't top off for some reason maybe cause one is agm and the other is lead acid
  12. Feb 24, 2017 at 10:13 PM
    koditten
    Kirk
    Central Michigan
    I'm confused. Are you charging an AGM or flooded cell battery.
    You won't have good luck (if any) trying to de sulfate an AGM battery.
  13. Feb 24, 2017 at 10:30 PM
    pinktaco808
    It say you can desulfate a Agnes battery. But I was charging a lead acid battery. I am talking about 2 things.
  14. Feb 24, 2017 at 10:54 PM
    koditten
    Kirk
    Central Michigan
    It may say that, but its not realistic. De sulfating a battery requires a place for the build upon the plates to be shed too. AGM batteries don't have space in the bottom of the battery for the build up to fall to.
    Another reason I don't care for AGM batteries. In my opinion, the only advantage they have they can be mounted in any position and don't leak when they get damaged.
  15. Feb 25, 2017 at 4:21 AM
    pinktaco808
    A ATM still lead acid battery.
  16. Feb 25, 2017 at 4:21 AM
    pinktaco808
  17. Feb 25, 2017 at 10:54 PM
    pinktaco808
  18. Feb 26, 2017 at 9:45 PM
    pinktaco808
    How long you guys leave the battery on float mode?
  19. Feb 27, 2017 at 7:10 PM
    pinktaco808
    Bumpppppp
  20. Feb 27, 2017 at 7:20 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
