Detailed LED bed light install GUIDE. No Holes No wire cutting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by packrobottom, Aug 25, 2014.
  1. Aug 25, 2014 at 6:15 PM
    packrobottom
    packrobottom [OP] Well-Known Member
    Pack
    Sky Silver SR5 DC v6 with sport mods
    I spent quite a lot of time going thru every thread here regarding LED bed light installs and took what I think are the best bits from each one and added my own choices. All with the goal of making it simple and not alterating the truck in anyway. I also spent a lot of time researching parts. For example most of the add a circuits shown in the installs don't actually fit our 2 gen trucks properly as they aren't low profile mini which can't be found locally at big chain automotive stores and need to be ordered online. Most guides tell you to poke a hole in the factory grommet under the drivers door instead of simply untaping and then retapping it to use the tube that is there.
    I took many pictures along the way to hopefully resolve any questions you might have and also save the next guy all the time it took me.
    Parts:
    LED lights 5050. The newer 5630 strips are brighter but I couldn't find them in black pcb.
    superbright LED strip 16.4 feet/5M black pcb board. (I think black pcb board is the only good choice as it matches the black bed and doesn't stick out as much)
    PCB Black 5M 5050 LED strip
    Switch
    I wanted a completely OEM look so I splurged here. This switch is push button and looks completely like it came with the truck as you will see in the pics below.
    Toyota OEM like push button switch
    This switch requires a relay as it's 3 amp only and the strip is more.
    Relay with socket
    wire tires 4" and wire ties 8"
    2 roles of good quality weatherproof black vinyl electrical tape.
    20 feet of 3/8 wire loom
    most of the stores local to you will sell it in 10 feet you'll want 2 of them to protect the wire properly under the frame and in the back of the truck. 10 feet wasn't enough.
    Wire Loom
    wire
    Don't get solid wire get braided. Solid is bad for boats/cars
    20 feet Primary auto wire 16 Gauge. for power
    10 feet primary auto wire 16 gauge (for ground)
    Connectors
    hilights led strip connectors. (simple and easy no soldering)
    14-16 crimps preferably waterproof/shrink
    22-18 crimps preferably waterproof/shrink
    2 spade crimps for the grounds
    also one T-tap connect 22-18 and Vinyl Insulated .250" Male Quick Disconnect 22-18 AWG to go with it
    2 bullet waterproof connectors to connect wires in bed to LED strip. You could use regular crimps but this way you can remove the LEDs easily and plug them back in should you need to.
    heat shrink.
    1/4 and 1/8" 1/2" (if you want to heat shrink the bends in bed at corners.
    Low profile mini add a circuit and fuses
    most of the add a circuits at pep boys/autozone are 10 amp only so you can't use it in the power lock 20 amp slot. This one is 20 amp and fits properly. The power lock slot in the in cab fuse panel is the only always on fuse. This way you can have the lights on without the keys in and trust me you aren't leaving these lights on they are bright and noticeable.
    Installation
    Start by removing the taillight with a 10MM socket wrench
    You only need to remove 2 bolts for this not the one with the washer. it pulls out pretty hard. There are push tabs that require quite a bit of force to pop out.
    get the 3/8 loom and put enough 16 gauge red power wire inside of it to go from the back of the truck to the grommet under the drivers door. Don't try and push the wire inside the loom just push it against the seam with your thumb and it will go in quickly. At this point before I fished it I tapped it from start to finish with electrical tape some may think this overkill but it protects it, makes it easier to fish, and tape is cheap the factory one is taped in a lot of places as well.
    The hard part is routing the wire and loom past the fuel tank with the other factory loom near the middle. I was cussing at this point. I used a coat hanger taped to the end of the loom and wire the whole time I fished. Don't give up it's awkward but you'll get it eventually.
    once you have the loom routed from the back of the truck to the drivers side grommet remove the yellow tape from the grommet without cutting it.
    Peel it off and fold it back
    using some electrical lubricant or tiny bit of dish soap fish the wire by itself up taped to a coat hanger into the cab.
    after you have enough slack in the cab put the grommet back and push the wire loom snug up to it and tape it back up well
    The hard part is over.
    Now remove the drivers door sill by pulling up on it from the back
    the foot rest under the dash pull up on that and then unscrew the black plastic round nut. take the white tabs off the posts and put them in the footrest . Also remove the kick panel it has 2 tabs in the front pull towards door sill
    now pull the slack out the wire enough to get up to the dash and cut it. put more loom on it, and stop the loom where the grommet starts in the cab you'll see how the factory one does the same thing.
    run it all the way up to the coin tray covering the fuse panel and tape the end and leave enough slack
    Now run your grounds.
    in the back the easier spot is here
    Under the dash I found this to be the easier spot. (10 mm open end socket)
    you should now have two wires sticking out of coin tray hole and 2 wires in the bed. The wires in the bed you can fish in behind the taillight and into the bed thru a gap
    Wiring switch and relay
    remove the 20 amp power door fuse from top right using the white fuse remover that is under the hood in the top of the engine compartment fuse box.
    put the 20 amp fuse in slot 1 of the add a circuit and a 5 amp fuse in slot 2 that came with it.
    dash illumination tap to red/yellow wire on switch from adjacent factory switch
    I velcroed the relay under the dash with industrial Velcro it's very sturdy and not going anywhere.
    It's not centered but didn't feel like ripping it off to center it
    Use zip ties at the corners thru the drain holes to stop the 3m adhesive from sagging there. Cover the corners with 3/8 loom and tape the hit tight connectors. Using some silicon would be smart too. heat shrink/and or loom the connection to the led strip and all exposed wires coming into bed.
  2. Aug 25, 2014 at 6:23 PM
    ssilence
    ssilence Well-Known Member
    Middle Georgia
    2012 Tacoma Pre-Runner
    Pop and Lock
    Great Guide. I will be using this.
  3. Aug 25, 2014 at 6:47 PM
    Freezercat
    Freezercat Active Member
    '17 TRD Sport 4x4 Magnetic Grey
    Very cool mod and very thorough. I am always very uncomfortable tackling anything involving partial disassembly for fear of breaking or making worse. Is there any way, while not nearly as cool, to simply plug into the bed plug?
  4. Aug 25, 2014 at 6:57 PM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    Great write up
    sub'd for the future
  5. Aug 25, 2014 at 7:11 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Very Nice ! :D
  6. Aug 25, 2014 at 8:00 PM
    packrobottom
    Pack
    Thx guys been learning from this site since 2010 when I bought my first taco about time I gave back.
    Yes they have led strips with remote that you could plug into the outlet not a very elegant solution but easy and would work. wouldn't be waterproof tho
  7. Aug 26, 2014 at 3:57 AM
    Highboy90
    Highboy90 Well-Known Member
    Great information and write up. Thanks!
  8. Aug 26, 2014 at 4:12 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Thanks for the great pics and detailed guide!
  9. Aug 26, 2014 at 7:10 PM
    packrobottom
    Pack
    One additional step I did today was siliconed all the hit light joints
  10. Aug 26, 2014 at 7:43 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Sub'd
    nice write-up OP. will be doing this shortly myself. about to order about 64ft of LED strip. :)
  11. Aug 26, 2014 at 7:53 PM
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Nice work! :thumbsup:
  12. Aug 27, 2014 at 1:04 PM
    packrobottom
    Pack
    64feet! Your gonna need bigger wire son!
  13. Aug 27, 2014 at 6:30 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh I know. Lol. But its in 16 ft increments. Just ordering enough to do the rock lights (replacing my current rock light setup), bed lights, and under hood lights.
    Tacomalifer likes this.
  14. Sep 10, 2014 at 6:41 AM
    packrobottom
    Pack
    No sagging yet and we've had a couple of hundred degree days. The key is is to ziptie the corners were all the weight is through the drain holes in the railing
  15. Dec 23, 2014 at 4:52 AM
    MotoXTacoma
    MotoXTacoma Active Member
    Seattle - GPNW
    '08 4x4 MX Hauler
    Custom Satoshi grille, black badging, lockable bed boxes, bedmat, extra bed tie downs.
    Great write up. Sub'do for later project
  16. Dec 27, 2014 at 6:54 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Thanks for the detailed write up. Used a great deal of your ideas for my install. Ran everything just as you did with the exception of the power source. I plan to switch my bed lights in the bed as this feed is for both future bed lights and the factory light on my Snug Top Shell. I plan to feed power from the battery by simply adding a second nut to the terminal post on my battery (it has a regular hook up and also a marine type post that has enough room for a lug and second nut). I will fuse things at the battery with a waterproof fuse set up. Your recommendation to tape the entire loom really helps a great deal as the loom I had kept letting wire pop out the side if you moved things around. Taped everything up and used the coat hanger to fish it along the frame and such. to access the engine bay I simply pushed a small Philips screwdriver through the big rubber boot to make a small hole in it....ran flex to both sides and it was done. Lots of time saved using your install guide so Thanks again. Biggest issue was it was mid 30's in the garage so I had to go thaw my hands out fairly often. Also used a whole lot of zip ties! Comes out really clean.
  17. Jan 18, 2015 at 7:14 PM
    hwork50
    hwork50 Well-Known Member
    San Clemente
    06 PreRunner SR5 AC
    DTRL, Skid Plate, Bed Extender, ipod hook up in glove bo, bed mat, rubber mats, Garmin GPS, 2.5"Toyotec lift with 5100 shocks and Eibach springs.
  18. Jan 18, 2015 at 7:24 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
  19. Jun 21, 2015 at 7:44 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  20. Aug 6, 2015 at 12:35 AM
    houchax
    houchax I will post more.. I will post more...
    Adam
    Lakeland Fl
    '15 DCSB PRE SR5
    Bone Stock :( As of 7/28
    sub'd
