Detailed LED bed light install GUIDE. No Holes No wire cutting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by packrobottom, Aug 25, 2014.
  1. Aug 6, 2015 at 6:14 AM
    Zonktified
    Zonktified Well-Known Member
    Rob
    Wisconsin
    Tacoma TRD Sport
    Sub'd...excellent write up and pictorial. Thanks for sharing!:thumbsup:
  2. Aug 6, 2015 at 7:47 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    The only thing you should do different is sodler the connections rather than use the crimps at the corners. They will stop working eventually, it only took about 5 months for me and my lights started flickering/not coming on. I ended up taking the crimps off and soldering the wires, now theyre 100%. And yes i heat shrinked them...
    Awesome write up!
  3. Aug 9, 2015 at 9:59 PM
    15TrdSportec
    15TrdSportec Well-Known Member
    2016 DCSB TRD Sport 4x4 Super White
    Is the relay necessary for this mod? Just received my LEDs and 3M double sided tape and wanted to do the install this week.
  4. Aug 10, 2015 at 2:13 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    X2?
    Looking to doing the bed light mod soon, but pretty much a different route from the common LED strips. Going for that OEM/stock look. Got all the parts and now just gathering some info on the right way to wiring it up.
    Amateur on wiring things up. So would this be ok. What I plan to do.
    Run my wires straight to the battery for power, with an inline fuse(just to be on the safe side).
    Switch will be in the bed.
    Pretty much it to keep it simple.
  5. Aug 10, 2015 at 4:35 PM
    crutch024
    crutch024 Well-Known Member
    Scott
    Fairfield, Ohio (near Cincinnati)
    2014 Spruce Mica TRD Sport Doublecab
    Pop & Lock 8521; Extra Power Outlets in Center Console; G-Tek Fab Door Sill Protectors; Salex Organizers; NFAB Side Steps; Weather Tech Mats
  6. Aug 16, 2015 at 6:52 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Did you find out the answer? I'm new to all this, but everything makes sense except the relay picture. Why did you snip the red wire and where did the white come from?
    EDIT** Man I love the internet. Just found this about Relays and now see why it's necessary. http://www.instructables.com/id/How-Electronic-Switches-Work-For-Noobs-Relays-and/ Still don't get why that one is wired like that.
  7. Aug 17, 2015 at 10:38 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    relay is necessary when the items being powered draw more amps than the switch can handle. i.e. offoad lights such as daylighters pulling 15 amps on a 5 amp switch. You should not need a relay with LEDs as they have a low amp draw.
  8. Aug 18, 2015 at 1:52 PM
    packrobottom
    packrobottom [OP] Well-Known Member
    Pack
    Sky Silver SR5 DC v6 with sport mods
    you need a relay if you use that toyota looka like switch it will burn out if you don't. Even says so in the instructions. Also for the guy saying you need to solder the corners you don't if you do them correctly. over a year and no issues.
  9. Oct 24, 2015 at 8:27 PM
    izus13
    izus13 New Member
    Maine
    2014 Double Cab 6' Bed
    Excellent write up! I installed my LED light bar in the bed today following your wiring. Thanks!
  10. Oct 24, 2015 at 9:30 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Very nice write up! I have to do my hood first then when I get a chance I will to my truck bed.
  11. Dec 4, 2015 at 6:21 PM
    Yota4all
    Yota4all Member
    2013 Tacoma TRD Sport
    Thanks for the excellent pictures and description. I'm working on this now. Hopefully it turns out add nice as yours!
  12. Mar 6, 2016 at 5:04 PM
    rkd
    rkd Active Member
    Andrew
    Orlando, FL
    06 AC Tacoma TRD Sport 4x4
    Thanks for this write up!
  13. Nov 19, 2016 at 6:27 PM
    packrobottom
    Pack
    ok so over 2 years and finally had a sag in the middle back. just a minor one I put a dab of super glue and all good. It has held up well. You really need to protect everything or it won't last long.
  14. Nov 21, 2016 at 10:13 AM
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    Just ordered all the parts for this mod. Excited to finally have light back there!
  15. Nov 21, 2016 at 10:19 AM
    #35
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Nice write up :thumbsup:
  16. Jun 20, 2017 at 4:36 PM
    #36
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Great write up. I am thinking of doing the same thing, but I think I am going to connect mine to the dome light so that when the doors open the bed lights come on and or I will do a switch at the tailgate to turn on lights when tailgate opens.
    The reason for the doors is because eventually I will have the tailgate lock powered like the doors so when I unlock the doors the tailgate will unlock and the lights will come on.
    Killawhalegun likes this.
  17. Nov 21, 2017 at 1:21 PM
    #37
    hunterj4
    hunterj4 New Member
    Hunter
    2015 Tacoma 4x4
  18. Jan 28, 2018 at 6:10 PM
    #38
    Nwbound77
    Nwbound77 New Member
    2012 TACOMA Ted 4x4
    I need help! Love this tutorial! I'm in the process of purchasing all necessary parts. Hate to sound like a nub but I need help with running the grounds wire/wires. Anyone who's done this mod and has knowledge of it would really be a help. Thanks
  19. Jan 28, 2018 at 7:25 PM
    #39
    Alder932
    Alder932 Well-Known Member
    B.C., Canada
    2013 Tacoma Limited
    Just discovered this thread and considering doing the same. There seem to be a lot of ready made kits for sale now, and presumably weren’t when the OP put this great how-to-do tutorial together. Wondering whether to start from basics or to take the seemingly easier way and buy a kit. If a kit, any recommendations for a 2nd Gen?
  20. Mar 31, 2021 at 3:23 PM
    #40
    packrobottom
    Pack
    Lights still work! But man looking back on this It was a lot of work. Lol i'd never do this now too lazy. what was I thinking!
