Detailed oil filter instructions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thom13, Apr 20, 2020.
  1. Apr 20, 2020 at 4:01 PM
    thom13
    thom13 [OP] Member
    toyota tacoma reg cab 2011
    I have got a 4 cylinder 2011 Toyota short bed and would like to know where the oil filter is located and how to access it. I've got a skid plate underneath by the oil pan and some plastic guards in the wheel wells. Would I have to remove both of these or just 1 to get at the filter to change it. Thanx.
  2. Apr 20, 2020 at 4:12 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If I am not mistaken the 2.7L filter is located where the 1st Gen 2.4 was. If you want to avoid removing skid plates down below, you might be able to elevate the front of the truck - remove RF tire - then access filter thru that side. Any road block from that point will need to be removed before you can see the filter.
    Jimmyh likes this.
  3. Apr 20, 2020 at 4:16 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Lay on your back behind the passenger side front wheel and slide underneath. Look up and you’ll see the filter. You can access it going straight up through the control arm. While laying on your back and using your left hand turn counter clockwise to loosen. Good luck! 3C8D6E48-F3DA-4051-BF4D-694DE1D26E8E.jpg
    Jimmyh likes this.
  4. Apr 20, 2020 at 4:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Exactly as stated above by those two fine men.
    Steves104x4 likes this.
  5. Apr 21, 2020 at 7:50 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
