Details on greasing a 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by summerboy1958, Dec 27, 2009.
  1. Dec 27, 2009 at 4:11 PM
    summerboy1958
    summerboy1958 [OP] Well-Known Member
    Bruce
    Newark, De
    01 SR5 4WD, Radiant Red
    Hidden Hitch Trailer Hitch, Timbren Shock Assist System, Billy 5100's all around, Deck plate mod, AFE Pro Dry air filter, Amsoil 85W-90 Severe Gear Oil in the transmission/differentials/transfer case.
    I'd like to be able to lubricate my truck, but don't know the locations of the fittings (chassie (sp) and pro shaft). Anyone have details on where they are and the size? I need to buy a grease gun to fit.
    I have never lubricated a chassie before. I have only greased the bearing buddies on my old boat trailer. With that you just pump in the grease until it comes out the telltale hole. I'm sure it is not the same. Any comments on how you know you've put enough grease in?
  2. Dec 27, 2009 at 4:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the driveshaft and half shaft has all the fittings. i cant remember exactly how many....maybe 7 or so. put grease into them just until its starts coming out a tad.
  3. Jan 1, 2010 at 1:50 PM
    summerboy1958
    Bruce
    Newark, De
    Great info, thanks!!
    Are these the only items that need grease? Any thing on the chassis?
    I need to get a new grease gun. I have a small one that I used to grease the bearing buddy fittings, but it is too small for the tube of grease that I bought. I stopped in at PEP BOYs to buy a grease gun and saw that they had a variety zirc fittings (both metric and US standard). Are all of the fittings on the Tacoma the same? If so, what size? Does it make a difference in what kind of gun I buy? Do I need to buy anything special as a grease gun to make sure it fits the zircs?
  4. Jan 1, 2010 at 3:46 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    There are no zerks on the chassis, it needs no lube.
