determine type of rear end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOMA TPAC, Apr 13, 2013.
  1. Apr 13, 2013 at 1:00 PM
    TACOMA TPAC
    TACOMA TPAC [OP] New Member
    Ted
    South Carolina
    07 4x4 double cab
    I bought my 2007 Tacoma Double cab 4X4 used, want to change the differential fluids,how can I determine if the rear is limited slip and if so do I need to add an additive?
  2. Apr 14, 2013 at 2:01 AM
    JKD
    JKD Well-Known Member
    There would be a sticker by the fill port.
    If in doubt, any Toyota dealer could tell you if it was originally equipped with an LSD by looking up the truck by its VIN.
    Or, jack up the rear axle, put it on jack stands, and with the transmission in Neutral and the parking brake off, turn one wheel. If the opposite wheel turns the same direction, you have limited slip. If it turns backwards, you don't.
