Determined to get it right.
Discussion in 'Technical Chat' started by beechairplanes, Mar 12, 2009.
  1. Mar 12, 2009 at 9:01 PM
    beechairplanes
    beechairplanes [OP] Terrain
    Arizona
    01 tacoma 4x4 trd
    lift, yokahama geolanders,
    I got my truck back from the dealer the other day after having the tranny flushed and changing the frt & rear diff fluid. I also r & r the carrier bearing. All of this being done to fix and protect the tranny from what seems to be a periodic hard shift. The shifting issue has subsided a bit but it is still there, along with a new vibration which I can only assume is the driveline. (ie the carrier bearing) My question is this, do the 1/4 inch shims under the carrier bearing help w/ the vibration? Also, should I pull the tranny pan and clean the filter? Any other help would be great. sorry bout the novel.......:confused:
  2. Mar 12, 2009 at 9:04 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Seafoam
  3. Mar 12, 2009 at 9:08 PM
    beechairplanes
    Arizona
    01 tacoma 4x4 trd
    I have heard of that. What is it? How often?
  4. Mar 12, 2009 at 9:12 PM
    DanGer
    Sorry, just one of many members here who have recently fallen in love with it. I'm not sure if it would be the best at adressing your issue, but it cleared up my already clear idle, and just made my engine run cleaner. It is a petroleum based engine cleaner (not sure if that is the best term) but it cleans the HELL out of your engine and pretty much anything else. You feed it into your break booster line and my truck smoked pure white for about 2-3 minutes. Might be worth a try, worst case is it cleans up your engine. I remember someone recconmending a product to clear up shifting so I will try and dig it up
  5. Mar 12, 2009 at 9:14 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    how many miles on the tranny? Auto?
  6. Mar 12, 2009 at 9:22 PM
    beechairplanes
    Arizona
    01 tacoma 4x4 trd
    121,000 miles on an automatic
  7. Mar 12, 2009 at 9:26 PM
    jwscoot
    jwscoot Well-Known Member
    Mississauga, ON
    98 Tacoma v6 4x4
    Bilstein 5100 shocks all the way around, add a leaf in the rear
    If they flushed the tranny, they would have pulled the pan and replaced the filter. I worked at a sketchy tranny place and we would never not pull the pan and put a new filter in. I'm sure the dealer would have replaced it.
  8. Mar 12, 2009 at 9:29 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    has the truck been beaten or towed alot? it may be something internal.
    If you guys have a Cottman transmission place near you, they do a free tranny check and there pretty good guys.at least the one here is.
  9. Mar 12, 2009 at 9:31 PM
    DanGer
    well I can't for the life of me find that thread. Grrrrrrrr
  10. Mar 12, 2009 at 9:33 PM
    beechairplanes
    Arizona
    01 tacoma 4x4 trd
    I think I got a flush without pulling the tranny pan. Is that possible?
  11. Mar 12, 2009 at 9:37 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Did they check or have you checked your u-joints to make sure there are no problems with them. It might not hurt to pull the pan for piece of mind but you might not find much Toyota uses a wire mesh filter I don't normally see a large amount of debris in the filter at 120000 miles unless it has a failure.
  12. Mar 12, 2009 at 9:41 PM
    beechairplanes
    Arizona
    01 tacoma 4x4 trd
    I bought the truck about a week ago and all was well. There is some slight body dings but overall the truck looked in good shape. It doesnt appear to have ever had a tow package installed. It did look as though someone put a ball hitch on the bumper mount at one time. That doesnt worry me all that much.
    Here is another question. My rear differential rotates slightly when i try to move the truck while in park. The aft driveline has a slip joint of some sort that allows the driveline to stretch and contract. Is there a spec for how much movement is allowed?
  13. Mar 12, 2009 at 9:45 PM
    beechairplanes
    Arizona
    01 tacoma 4x4 trd
    My u joints feel really good. The tech agreed. To try to explain my situ a little better, I also notice that when I come to a stop i feel a bump from the underside rear?? like something is sliding fwd. I have checked the spare tire mount and all is good> Any ideas?????
  14. Mar 16, 2009 at 9:37 PM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    Axle Wrap? the axle shifting from drive positive to coast/decel position?
