Determining age of timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Apr 10, 2014.
  1. Apr 10, 2014 at 2:24 PM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I've gotten different answers on whether or not my tbelt and waterpump were replaced before I became the owner. Given the poor maintenance before I got the truck I wouldnt be shocked if it never was done. Truck has 116k on it now. Is there a date code on the tbelt? I figure I could pop off the cover and look but I figured it's worth asking first.
  2. Apr 10, 2014 at 3:40 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Change water pump and timing belt.
  3. Apr 10, 2014 at 3:47 PM
    Trapperr
    Reno, NV
    Thanks guys. My only concern was replacing it with only around 30k on it but I guess better safe than sorry.
  4. Apr 10, 2014 at 9:33 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    I think if it's not been changed it says toyota on the timing belt, unless someone put a factory toyota timing belt back in it.
  5. Apr 10, 2014 at 10:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If the rest of the truck was not well maintained, the belt was definitely not changed 30k ago.
    And yes... hit the water pump while you're in there.
    It MIGHT last 200k, but it probably won't (if it isn't already weeping).
    The factory pump on my 2nd Gen was just replaced... 108k on the truck.
    It wasn't dripping, but there was a pink flower growing under the pulley.
  6. Apr 11, 2014 at 3:48 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Definitely change out that Timing belt. Much better safe than sorry on that item. If you have ever heard A timing belt break and then listen to the engine eat the valves,,it's not a serenade of beautiful sounds. It sounds,,very very expensive in a few thousands of a second or less. You might just bend a couple valves,,or you might bend them all. Don't roll the dice on this one.
  7. Apr 11, 2014 at 4:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You can't tell the age of the belt just by looking at it.
    These belts have interior strands (I'll call them that) that you can't see from the outside. These strands are what gets stressed & break over time. You can't judge the condition of these strands just by looking at the rubber coating on the outside.
    Be safe.... Change it!
  8. Apr 11, 2014 at 5:16 AM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    I think the 3.4 is a non-interference engine, no? Meaning if you throw a timing belt the pistons won't strike the valves.
  9. Apr 11, 2014 at 5:29 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    That is correct. Having the belt snap will not ruin the valves on a 3.4 engine.
    However, it will still ruin your day, especially if you have somewhere to be. Maybe you'll get lucky, and it'll snap on you right outside of a hooters and you'll have good reason to hang out there for a few hours.
    But if you're like me, it'll snap at 2AM in a part of town you do NOT want to be stranded in.
    My vote is to replace it, and do the water pump while they're at it. Then you will KNOW when it was done, and you won't have to worry about it anymore.
  10. Apr 11, 2014 at 5:56 AM
    kn38ms
    kn38ms Well-Known Member
    NW, FL
    c'mon man...:rolleyes:
  11. Apr 11, 2014 at 6:26 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    This^^ pull the cover if there is the slightest hint of cracking in the belt it's past due.
  12. Apr 11, 2014 at 10:10 AM
    CR, WA
    stock
    Edited post #7,,for more clarity I guess. lol.
  13. Apr 11, 2014 at 10:48 AM
    steelbluesleepr
    steelbluesleepr Member
    Jayson
    St. Louis, MO
    99 Tacoma 4x4 2.7
    rust and dents.
    is the 2.7 an interference motor?
  14. Apr 11, 2014 at 8:11 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    2.7 is chain.
    The V6 and 4.7 V8 are belt.
    The 4.7 is an interference engine... not sure about the 4.0
  15. Apr 11, 2014 at 8:23 PM
    iamgone
    iamgone Member
    Georgia
    96 Tacoma xtracab 4WD
    2.5" Rough Country Suspension Lift
    Don't know about interference on the 4.0, but I'm fairly certain it has timing chains, not a belt. My wife's '04 4Runner has the 4.0.
  16. Apr 11, 2014 at 8:31 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If the belt was changed by a dealer, there will be a decal stuck to the timing belt cover. It will have the date and the miles it was changed at.
  17. Apr 11, 2014 at 9:07 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup... you're right.
    Both the 4.0 and 2.7 are chain.
    3.4 was belt.
  18. Apr 12, 2014 at 9:10 AM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Its called maintenance for a reason. Fix it before it breaks. As far as the belt it will last much longer than 110K but the tensioner will not. I changed my belt at 90K belt looked great tensioner was shot. Just do it and be done with it. After turning wrenches for almost 25 years FOR A LIVING nothing beats Preventive maintenance !!!!
  19. Apr 12, 2014 at 10:39 AM
    Indy
    Indy Master of all I survey.
    Sure you can. Timing belts are like trees. Just cut it in half and count the rings.
  20. Apr 12, 2014 at 12:30 PM
    Janster
    Jandy
    Lancaster, PA
    :facepalm: :eek:
