Determining what size shock i need?
Discussion in 'Long Travel Suspension' started by austinramsay, Sep 15, 2013.
  1. Sep 15, 2013 at 12:56 PM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Im planning on doing oem replacement 8 pack deavers with a good set of 2.5 smooth bodies and a bed cage. How am i supposed to know what size shocks to get? Like what stroke and travel? What exactly does stroke mean?
  2. Sep 15, 2013 at 2:45 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Stroke and travel are the same thing, but remember that the travel of the shock is not going to be the same as wheel travel in the vast majority of applications.
    You need to read the stickied threads in this section.
    There is really no purpose in building a bed cage and moving to large, longer travel shocks if you are going to keep the stock leaf spring configuration (spring over axle).
    The shock's mounting points on the axle and the bed cage, in combination with the angle of the shock and the amount of wheel travel, will dictate what length and travel shock you will require.
    There is no book answer. Most trucks are using 14-18'' travel shocks depending on application. Welcome to the world of custom fabrication.
  3. Sep 15, 2013 at 3:34 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    didn't like the integra huh? haha not surprised.
  4. Sep 15, 2013 at 10:23 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Hahah yeah I did just always looked back at pictures of my taco and couldn't resist one again..:eek: and my favorite front ends are the 01-04s so i had to get one haha! :) glad to be back though!
  5. Sep 15, 2013 at 10:24 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Ah okay that makes sense, yeah ive been reading just hard finding the answers i want! So your saying theres no point of getting longer shocks with the 8 pack deavers?
  6. Sep 15, 2013 at 10:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Longer shocks can be a nice benifit. But what he is saying is no one can tell you what size to get untill you have the leafs and a figure out where your gonna mount the shocks and the angle they will be at. There are too many factors to take into account with a custom job like that.
    that said, IMO if your gonna build a bed cage..might as well go SUA and full LT.
  7. Sep 15, 2013 at 10:34 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    This ^^^
    You going MT or LT?
  8. Sep 15, 2013 at 10:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If he is doing an OEM replacement..Has to be Mid travel.
  9. Sep 15, 2013 at 10:44 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Ah okay i understand that. What fabrication and custom work is required to do rear LT? Is it a lot more money to build? Whats exactly required?
    I was thinking MT but if LT isnt that much more work then maybe that! haha
  10. Sep 15, 2013 at 10:47 PM
    95 taco
    95 taco Battle Born
    Didn't read that part :eek:
    Are you a pre runner or 4x4?
    LT you'd need a bed cage, SUA, and LT leaves, possibly a shackle that mounts on top of the rear frame.
  11. Sep 15, 2013 at 10:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Alot of work. Relocating both spring hangers, custom shackles usually, bigger shocks(16-18), bed cage, frame reinforcment, bump stops..really you can go as far as you want..haha can run pretty expensive..
  12. Sep 15, 2013 at 10:51 PM
    95 taco
    95 taco Battle Born
    also this^^^
    IMO it isn't worth it, you can't tow as much well/comfortably with a LT rear vs MT, plus you use some bed space to a bed cage, plus it's $$$$
  13. Sep 15, 2013 at 10:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    He is wanting abed cage either way..
    Honestly id just relocate the shocks still under the bed. You could still fit 10-12s under for a good mid travel setup.
  14. Sep 15, 2013 at 10:56 PM
    95 taco
    95 taco Battle Born
    What shocks do silas have? his are pretty long IIRC.
  15. Sep 15, 2013 at 11:06 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Prerunner! Whats involved in doing a SUA?
    Ahhh sounds like too much $$ for me hahah! I was thinking a nice set of used j59 deavers for $450, get a used pair of 12-14" 2.5s and rebuild em, and not a full bed cage but just something to mount the shocks to. I have an idea of what i want in my head haha.
    I dont do too much towing anyways except take a dirt bile or 2 out once in a while.the idea i have for the "cage" should let me keep my bed space. Im not thinking full out cage, just a mount on one side, tube going from top left corner to top right corner and down to the other shock mount
  16. Sep 15, 2013 at 11:11 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
  17. Sep 15, 2013 at 11:14 PM
    95 taco
    95 taco Battle Born
    So just a nice simple cage, almost just hoops?
  18. Sep 15, 2013 at 11:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Silas has 14'' but they are mounted like /\ which is not good for high speed stuff. They don't dampen as much due to the angle.
  19. Sep 15, 2013 at 11:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thats for a LT setup You won't need shocks mounted that high for a mid travel setup.
    I do something like what Adam did (boxrocket) or Littlebro5 for relocate with 10 or 12'' short body shocks. You won't need a bed cage.
  20. Sep 16, 2013 at 7:47 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Yeah exactly nothing crazy just functional
    Whats a short body shock? Could i just use regular foxes kings or saws? What do you think of the bilstein 7100s? Would they be okay in high speed applications if valved correctly? Those are rebuildable right?
