Detroit Gear Driven LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Dec 11, 2010.
  1. Dec 11, 2010 at 4:06 AM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I have a 2011 SR5 and I am thinking about getting a Detroit Gear Driven LSD. I only do mild off roading and spend 85% of my time on road. (my every day driver). Any help with this decision will be appreciated.
  2. Dec 11, 2010 at 6:55 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You mean Truetrac right? You should be fine with it. and sounds like a good plan for what you doing.
  3. Dec 11, 2010 at 7:22 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    There is trutrac unit and a locker unit (which is supposed to let the wheels spin at different speeds when needed) The locker unit is about 100.00 more. Which is better for my situation. 85% road 15% off road. Not racing or real rock climbing.
  4. Dec 11, 2010 at 7:32 AM
    BlueT
    NorthEast
    One is locker one is Limited slipp and they work very different.
    I would say for where you are (upstate with snow), truck you have (2011 with electronic traction) and what you want to do, truetrac may be safer option. Locker will lock wheels and with electronic traction control you have that may be a problem. Second in snow slippery conditions auto lockers kinda suck :D
    If you are not rock crawling Truetrac may serve you much better year round.
  5. Dec 11, 2010 at 8:54 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Thanks BlueT. The Trutrac should be significantly better than whats in there now right
  6. Dec 11, 2010 at 9:09 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Have you even tried what's in there now before spending $$$ ?
    Try AUTO LSD in 2WD... and the normal TRAC in H4 and see if Toyota gives you enough limited slip first.
    Do you have an Off Road TRD? It has the hydraulic brake booster which really enhances the traction controls (TRAC and AUTO LSD). But, since you are asking about a locker, I guess not... since the Off Road comes with a locker.
  7. Dec 11, 2010 at 9:17 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    david k I only have a SR5 4x4 not a TRD. I dont have anything thats labelled "trac". So I was thinking that detroit was the way to go since it is supposed to semi lock the rear. Not really familiar with this though. My last truck-tundra trd off road worked great with factory elocker.
  8. Dec 11, 2010 at 11:43 AM
    BlueT
    NorthEast
    Its going to be better for sure but by how much you should ask few people who installed one in newest trucks that have Auto-LSD on the back. There are few on this forum so send them PM.
  9. Dec 11, 2010 at 12:50 PM
    JKD
    JKD Well-Known Member
    Have you tried the A-LSD?
  10. Dec 11, 2010 at 1:24 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    your truck by default has TRAC. there is ATRAC too, but you don't have that.
  11. Dec 11, 2010 at 1:38 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    does the trac automatically kick in while in 4wheel low or do I have to hold the traction control button(picture of car with zig zag lines) in for three seconds to activate it
  12. Dec 11, 2010 at 3:30 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    this thread details it more than you'd ever want or need!
    http://www.tacomaworld.com/forum/te...uto-lsd-explained-easy-understand-i-hope.html
    VSC and TRAC are standard on the 4x4 SR5. ATRAC is a TRD package inclusion.
  13. Dec 12, 2010 at 12:15 AM
    David K
    Others have answered and even gave you the link to my A-TRAC answers thread...
    But, you don't have a TRD OFF ROAD, so all the A-TRAC attention may haze over the other data that is there...
    1) ALL new Toyotas have the Star Safety System... which is (for you in a base/ SR-5) TRAC in H2 and H4... and selectable AUTO LSD in H2.
    Now, TRAC and AUTO LSD are the same thing (almost)... TRAC in H4 and AUTO LSD in H2 are the same... limited slip without engine output regulation... one on the rear the other on front and rear.
    TRAC in H2 has engine output regulation, so not as 'strong' a limited slip as AUTO LSD... or TRAC in H4.
    To turn on AUTO LSD, push the button that has the car with wavey lines (called the VSC Off Switch)... just push it once, quickly. This is called the TRAC OFF Mode, but is just changing the regulated traction control (limited slip) to the unregulated traction control.
    TRAC in H4 is unregulated from the start.
    If you ever want to turn off all the traction controls and have open differentials so ony one tire per axle spins if traction is lost... come to a STOP, push that button (VSC Off Switch) and HOLD it down for a few seconds, while stopped in H2 or H4. The VSC and TRAC are both OFF now. They reset if you turn off the car and restart or push the button quickly.
    L4 has NO traction control available to you (or any 4WDs except Off Road TRDs... that is A-TRAC). However, the Yellow Wire/ 4-Lo Trac Mod is a way to fool the computer to think you are in H4 so you have TRAC when you are really in L4... and those who have done it have raved!
    Hope this helps to clear up the tons of data!
  14. Dec 12, 2010 at 12:34 AM
    David K
    You are probably correct... but maybe he should try it stock first before dishing out tons of money without knowing for sure he needs to?
    Hope he let's us know how it works out and we will know better about AUTO LSD on an SR5.
  15. Dec 12, 2010 at 2:47 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    david k thanks brother that clears up a lot. Im going to go with the detroit trutrac I will order one today and report back once it is in. Thanks again to everyone on this grear forum
  16. Dec 12, 2010 at 6:46 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    This going in the rear? I see they also make 'em for the front.
  17. Dec 12, 2010 at 7:37 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    yes going in the rear raylo
  18. Dec 12, 2010 at 11:20 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    $438.00 shipped. I just dont know what will happen with the stock auto lsd. I know it is with the brakes and engine so I am thinking that I would have to hold the trac button on for three seconds until I turn everything off so that the trutrac could do its job. If anyone is familiar with this let me know.
  19. Dec 12, 2010 at 12:06 PM
    Raylo
    MD, USA
    I don't think you need to do anything. The Detroit Truetrac should minimize the differences in wheel speeds which is what triggers the computer's VSC and Auto LSD actions. If anything the electronic systems will provide a backup to the mechanical LSD.
    I am anxious to see how this comes out. Might be a good mod for me, too, assuming I can find a good shop to install. Actually, I think I could do it myself except I have no experience setting backlash and preloads. That might be a bit of an art...
  20. Dec 12, 2010 at 12:17 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Raylo. Im going to have a tech that works at toyota do it. I have him do all my involved work. I figure that the truck is brand new and if anything goes wrong toyota cant say that I voided the warranty since they are doing the work. I beleive the axle has to be pulled to intall this unit. I will have them fill the rearend with synthetic oil when its back together.
