Detroit locker for 8.4
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Pickeledpigsfeet, Aug 7, 2024.
  1. Aug 7, 2024 at 5:43 PM
    Pickeledpigsfeet
    Pickeledpigsfeet [OP] Well-Known Member
    Foothills, CA
    Eaton 187sl199a Detroit Locker
    $500
    New, never installed. Bought it years ago thinking I was going to swap a 8.4 into my older yota truck but never did.
  2. Aug 7, 2024 at 10:39 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Interested. Is everything there that I would need to get it working?
  3. Aug 7, 2024 at 11:09 PM
    Pickeledpigsfeet
    Foothills, CA
    It’s just the locker, which is the only thing that comes when you order it. It replaces your carrier in your diff. You will need to reuse your bearings and gears. Typically you would take this and your diff to a gear shop and have them install it, unless you are comfortable with setting up gears.
  4. Sep 10, 2024 at 4:08 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    I installed one of these in my PreRunner a few years ago, and bought a used 3rd member (from a Tundra I believe) and took both to a shop in San Jose to have installed. I opted for a regear to 4:88 since I had went up to larger tires. Then I just swapped out my stock 3rd member with the upgraded one. Took a few hours.
    I can't tell you how much better it is to drive, punching it through corners or up a hill (I live on top of a pretty steep hill) inspires confidence, and it's even better in the rain. Totally worth it, and safer as well.
  5. Sep 11, 2024 at 4:30 PM
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    Do you still have this? and who pays shipping im in FL
