Detroit True Trac / Suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by k9port, Jul 5, 2012.
  1. Jul 5, 2012 at 7:09 AM
    k9port
    k9port [OP] Active Member
    Palm Beach
    SR5
    Leveling Kit, Pro Comp ES 6000 front shocks and Pro comp ES 9000 rear shocks
    Does anyone have a Detroit truetrac installed? If you do, can you tell me if it is worth getting one. I am looking to add more traction to the rear of my Tacoma when pulling my boat out of the ramp. I lost traction the other day and that was recommended. I have a 2004 SR5 Pre Runner 3.4 dbl cab. I also had my truck in for routine maintenance at Tires Plus. They tried to sell me new shocks and struts. I have 68k on the truck. Do they need to be replaced at that mileage? I haven't noticed any ride issues with the suspension that would cause me to think I need to replace them.
  2. Jul 5, 2012 at 10:39 AM
    KenC
    KenC Member
    Ken
    pottsville,pa
    i currently have the factory electric locker in my tacoma but i ran a tru trac in my old jeep cherokee and it worked really well for a daily driver but to install it you have to re setup the gears since its a different carrier but if you got a lock right lunch box style locker you wouldnt have to mess with ring and pinion,hopefully some 1 else will chime in
  3. Jul 5, 2012 at 10:42 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I've also.hears good things about the powertrax no slip
  4. Jul 6, 2012 at 11:14 AM
    k9port
    Palm Beach
    SR5
    I have been looking in to the powertrax. It seems like it would be an easier install the than the Detroit. Trying not to get too crazy with changing and adding stuff to the truck.
  5. Jul 6, 2012 at 2:02 PM
    KenC
    KenC Member
    Ken
    pottsville,pa
    lunch box style lockers are a walk in the parkto install compared to setting up the gears imo,only need basic hand tools and a little common sense
  6. Jul 7, 2012 at 1:47 PM
    BurgerTaco
    BurgerTaco Burger Slinger
    Redlands, CA
    04 Xtra Cab PreRunner
    I'm in a similar position. I have a 2003 Xtra-Cab PreRunner SR5 (non-TRD) and am looking to replace my open diff with a True Trac. I've done my research and have my mind set on the True Trac. It seems to be the perfect fit for the way my truck is used.
    Are you planning to do the install or have the shop do it. I'm planning to do mine, so am anxious to see this thread develop.
    :popcorn:
  7. Jul 7, 2012 at 1:48 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Your on this site... It I'll happen
  8. Jul 8, 2012 at 4:27 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Powertrax is a ratchet style, easy to install, but pops around turns and IMO affects handling in a negative way on the street, especially curvy roads..
    The True trac, you wont even know its in there, and will work for your use, harder to install, I have one in my Camaro, as a matter of fact I removed a Powertrax one to install the True-trac!
  9. Jul 8, 2012 at 4:39 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I have one and I love it
  10. Jul 9, 2012 at 5:35 AM
    k9port
    Palm Beach
    SR5
    I found a local guy that does installs on TruTracs. He said he would do mine for 350 plus the seal and oil providing I get the diff on my own. The TruTrac that would be installed is available through Summit Racing for about 433 buks. The Part #is 913A541 you should have a 7.5 rear diff now. If I go with the PowerTrax, I will do the install with a buddy of mine that has done diff work on his truck before. It seems like all the guys on our forum like the Trutrac.
  11. Jul 9, 2012 at 1:38 PM
    BurgerTaco
    Redlands, CA
    Drive Train Specialists quoted me $410 for the TrueTrac (I believe I have an 8").
    I'm planning on doing the install with a buddy of mine who's done plenty of work in both diffs of his Land Cruiser.
    I've ordered the TrueTrac & a new gasket, but am unsure as to what other parts I'll need to complete the install.
  12. Jul 9, 2012 at 2:26 PM
    MadTaco461
    CA
    Kinda stock
    I know you need to adjust backlash. Might need shims but I never installed a locker.
