detroit truetrac test
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006KJ, Mar 1, 2014.
  1. Nov 9, 2017 at 8:00 PM
    tpotnoc
    tpotnoc Sit on my face
    Bellingham, WA
    15 2.7 DCSB PR
    How often does a Detroit product fail? That’s why I got mine. Its awesome. It’s in my daily, not a trail rig. It’s transparent on the road most of the time, no clutches to wear or replace, silent, strong.
    If you’re building a trail rig, go with lockers.
    crashnburn80 likes this.
  2. Nov 10, 2017 at 4:20 AM
    Tbimm
    Tbimm Well-Known Member
    Tom
    Belle Chasse La.
    2000 Tacoma Prerunner
    Bilstein 5100's front and back. OME 880 front coils. General HD rear springs. Fuel 16x8 Enduro rims. Dick Cepek Extreme Country 285/75/16's Some kind of headers. K&N cold air intake.
    Not a strictly a trail rig. This is and will be my daily driver. With that said I also will be using it as a recovery vehicle of sorts. The property I work on gets extremely wet and muddy and often times I am called to go out and pull our John Deere Gators out of heavy mud. I am going to fit it with front and rear winches in time so I wont always have to go into the deepest of the muck but getting to where they are stuck will require a good bit of traction. So far everything I am reading tells me this is the way for me to go. Just wanted to hear what guys who have been running it for a while think of this set up.
  3. Jan 2, 2018 at 6:35 PM
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    I want to re-gear from 3:91 to 4:56 for my 31x10.5x15 tires, also want to add limited-slip. I don't know if I need to re-gear and add truetrac, or can I get the Eaton Truetrac LSD in the gear ratio I want?
    WileECoyote likes this.
  4. Jan 2, 2018 at 6:40 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Gears and TrueTrac are independent. But doing them at the same time makes the Truetrac install basically free as it is no more labor.
    As an aside, 4.56 on 31" tires seems like pretty deep gearing.
  5. Jan 2, 2018 at 6:45 PM
    Mojave4x
    I'm thinking of 4.56 only because I thought that was factory recommendations. What would you recommend - 4:10:?
  6. Jan 2, 2018 at 6:49 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Had mine for a few years now, somewhere around 50k miles. No issues.
  7. Jan 2, 2018 at 9:27 PM
    2006KJ
    2006KJ [OP] Well-Known Member
    Front Royal VA
    81,000 miles on my truck now and the Detroit truetrac has been and still is incredible. Strongly recommended!!
    dirtnsmores and BassAckwards like this.
  8. Jan 2, 2018 at 9:50 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Gear changes are always recommended to increment at least 2 sizes, as it usually is not considered worth it for 1. The gear size increase should match the tire size increase. What size did you use to have before putting 31s on that you are trying to account for? And when you say 31, is it 31x10.5?
  9. Jan 3, 2018 at 7:17 PM
    Mojave4x
    The original tires were P225/75R/15, I replaced those with 31x10.5x15
  10. Jan 5, 2018 at 3:57 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Would anyone mind my asking what they paid for the true trac install? And was there anything else that you had to change/buy to install this?
  11. Jan 5, 2018 at 9:13 PM
    2006KJ
    Front Royal VA
    If I remember correctly i paid about $100 to have mine installed which was a good price at the time. I provide the necessary oil ect. My truck was very low miles at the time but if it wasn’t I would’ve had them go through and freshen up all the bearings/seals ect... since the axles are already out might as well do it.
    Marc70 likes this.
  12. Jan 6, 2018 at 5:54 AM
    Marc70
    Marc70
    Northern Ontario
    Wow, that's really worth it.
    I asked the local transmission repair, and they said $1000 + side bearings, fluids, and taxes on front and rear, so I imagine 1/2 for rear only.
    Bought my truck used with 190k km on it, so not sure it's worth it, but I also know how long they'll last. Just gotta convince the wife. If I could get it done at your price, I'd jump on it.
  13. Jan 6, 2018 at 6:09 AM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    Don't have one now, but had TT's front and rear in my Land Rover for about 10 years. Never a problem, awesome performance. I wouldn't hesitate for a second.
  14. Jan 6, 2018 at 6:31 AM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    I have a 1st Gen, but I THINK it still wouldn't matter when it comes to gearing? :notsure:
    Anyways, I've been wanting to do the Detroit TrueTrac LSD as well and was also thinking about re-gearing going from the same setup on 4:10's. The link might be of some help as this is what I have found during my research on the subject of tire sizes and re-gearing. :thumbsup: Hope it helps. :notsure:
    http://www.lcengineering.com/LCTechPages/TECHGEARJANUARY.html
    Also, this might help as well when determining what's inside your diff...
    https://youtu.be/fB0jrucjlxg
  15. Jan 6, 2018 at 7:46 AM
    #35
    KugelBlitz
    KugelBlitz Well-Known Member
    Warren
    Middle-GA
    2015 4WD, 6MT, TRD Sport Access Cab
    Bilstein 61112/5160, Dakar EL096R, 285/70-R17 C BFG K02, Level 8 Mk6 wheels, Bestop Softop US. OffRoad Hidden Winch Bumper, ComeUp DV-9s winch, SOS Concepts Sliders and IFS Skid plate, VIAIR 400P Auto compressor mounted in a Expedition Essentials bedside mount, TRD Quick Shifter, TRD Cat-Back exhaust, ,75WX ST CB, Pioneer AVH-X4800BS, and various other mods and things...
    I was researching LSD options for the front diff and contacted ECGS. They responded that a True Trac does not exist for the Toyota 8" front IFS differential, only the rear (PN: 913A541 for non rear e-locker).
    What other options are out there for the front diff besides going with ARB Air Lockers? Anybody have any experience with Aussie Lokkas?
    http://lokka.com/
  16. Jan 6, 2018 at 8:07 AM
    #36
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    Hey all
    Sorry for my differing opinion but,
    I installed a Eaton tru track on my previous 04 hemi ram and it was ok but in my current taco I would much preferr a selectable locker.
    The tru trac can be dangerous on snowy/ icy roads in my ram their were times I’d be going straight down a snowy road a 60mph and the tru trac would engage and launch rear off the road( not trac straight) you don’t need to be locked at highway speeds jmo .
    Also if Irc their is a tire size limit on warranty 33” iirc .
  17. Jan 6, 2018 at 10:04 AM
    #37
    2006KJ
    Front Royal VA
    It would be a lot more to do front and rear. Mine was just the rear and it’s pretty simple. Remove axles and 3rd member. Swap over ring gear and set it up. Not a big deal if you know how to do it.
  18. Jan 6, 2018 at 10:10 AM
    #38
    2006KJ
    Front Royal VA
    That doesn’t seem like the characteristics of a true trac. I’ve ever once felt mine engage or disengage, lock or unlock. I also drive in winter snow/ice several months out of the year. In fact the truetrac has drastically improved poor road condition driving for me. In my experience the DTT has been completely invisible except i always have great traction.
  19. Jan 6, 2018 at 4:10 PM
    #39
    GroupW
    Mark
    Arizona
    Red TX
    I'm not buying it either. Engage???? As the OP said, that's not how they work. They're LSD's, not lockers
    On the other hand, I have to agree that a locker may be better (at least off road) for a Taco. The weakness of a TT is that you have to have your wheels on the ground. Our trucks have VERY limited suspension travel - especially in the front.
    Marc70 likes this.
  20. Jan 6, 2018 at 7:53 PM
    #40
    Littlemule1
    Ok ok
    Poor choice of words. I didn’t feel it engage . From MY experience the tru trac would function perfectly as designed,if there was any and I mean ANY loss of traction it will seamlessly send traction were needed and that often in my experience was both wheels like a fully locked diff . Now I said engage because when you’re going 60mph straight down the road often up a incline just barely accelerating and the rear end washes out because there was a slight slip and now it’s “locked “ ( both rotating with Tourqe) and without that 1wheel just tracking and 1 rotating with tourqe a light in the rear pickup it tends to go into a less than desired direction. Now I was always able to recover it I’m just saying it’s something to be mindful of. Again there is no need to be “ locked” at anything over 20mph in my opinion. Other than that the tru trac is awesome and easy to install and a great option . I would just rather be able to have full control over traction as needed.
    Drainbung and 2006KJ[OP] like this.
