Detroit Trutrac diff lockers.
Discussion in '5 Lug' started by ryanjboutin, Nov 10, 2010.
  1. Nov 10, 2010 at 8:50 PM
    ryanjboutin
    ryanjboutin [OP] Mob dirt parking lots.
    Las Vegas
    2013 4x4 Off Road, 6 speed.
    Spacers. Spacers everywhere.
    Anybody have one?
    I've been doing some research on TW/CT/XRU, and this seems to be the popular and most frugal choice.
    I understand that the XR gears won't fit into the base rear end, but the stock XR locker will.
    I'm not overly savvy with rear diffs and the like. Anybody have any pros or cons on this and ease of installation? I'd have my mechanic install it, not me.
    I'm really not too keen on the "just weld your gears together" option either. lol
    This is the one I'm considering...http://www.jegs.com/i/Detroit-Locker/357/913A612/10002/-1?parentProductId=1032953
  2. Nov 10, 2010 at 9:01 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    only if they addressed the problem with the outer bolts backing out of them and your diff would explode, happened with my last truck. Their warranty shouldn't even be a warranty, because they won't honor it. They will make you go to the distributor and blah blah blah........ok back on topic.
    I personally wouldn't. I even had a "gear shop" install and "eaton" was blaming it on improper install........IF you do post up results and i would suggest pulling your cover off every oil change and make sure the bolts are still on tight....
    I have heard they addressed the problem but after my experience with that, i wouldn't do it again.
  3. Nov 10, 2010 at 9:03 PM
    ryanjboutin
    Las Vegas
    I imagine that Loc-Tite thread locker would be a bad idea in this instance?
  4. Nov 10, 2010 at 9:04 PM
    jeff b
    jeff b Well-Known Member
    jb
    2013 4x4
    I have one and like it a lot!
  5. Nov 10, 2010 at 9:11 PM
    ryanjboutin
    Las Vegas
    Any other info? lol
    Installation was a breeze or what? Is it locked full time? No bolts backing out?
  6. Nov 10, 2010 at 9:21 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The ring gear bolts should have loc-tite on them and be torqued at about 100 ft/lbs so they shouldn't back out. I guess he's referring to the bolts that hold the case of the trutrac together :confused:.
    Other than the above and some debate over what type of gear oil to use (dino vs. synth) I've heard mostly positive things about them. Although, I think if you get one wheel off the ground it acts like an open diff which doesn't really work for offroad, but since you're more of a street truck it shouldn't matter. I think Chris4x4 used to have one in his 1st gen.
  7. Nov 10, 2010 at 9:22 PM
    907taco
    Bobby
    Alaska
    let me say this also, this was on my Nissan Titan, this is weird because I was actually at a shop today inquiring if they had any lockers for a tacoma, they were trying to turn me on to the tru-trac. I told him what happend to my last vehicle, he admitted that they took care of that problem supposedly. That being said just because of what happend i would seriously for myself pull the diff cover off and inspect quite often. These require very little maintainence but mine after install didn't make it 6,000mi. and that is why this peticular locker leaves a sour taste in my mouth, i had just broken this thing in and wham my rear end just exploded, spider gears and everything. But i will admit, leaving 2 black marks will leave a huge smile on your face......It is a good product i just had a bad experience, especially because i did not get reimbursed for the product failing!!!!!!!!!!!! it wasn't worth my time to file a suit, i was just happy to be covered under warranty for a "whole rear end replacement".
  8. Nov 10, 2010 at 9:25 PM
    ryanjboutin
    Las Vegas
    IRT the warranty; did you remove the locker prior to taking it to the dealer, and did you tell them it was the locker that failed?
  9. Nov 10, 2010 at 9:31 PM
    907taco
    Bobby
    Alaska
    long story short, they didn't even care after i told them that i had a aftermarket product in it, the "titan" had a problem with the rear ends failing, my dealership had 2 replacement rear ends (whole axle assembly), Nissan's protocol for when the rear end fails, they just replaced the whole thing.
  10. Nov 10, 2010 at 9:37 PM
    jeff b
    jb
    2013 4x4
    I don't remember how much it cost to install (it's been in for about 6 years). No bolts backing out that I no of? We get snow and ice in the winter and it hooks up pretty good. You don't want to try the install unless you really know what your doing. Easily my favorite mod.
  11. Nov 10, 2010 at 9:44 PM
    907taco
    Bobby
    Alaska
    yes, the back lash is something you just don't learn while doing it, you need a special tool to set the back lash, too much either way will wear the gears down. etc..... well worth the money to pay a shop who does this. unless you know someone who can do it for cheap.
  12. Nov 10, 2010 at 9:49 PM
    ryanjboutin
    Las Vegas
    I know a certified Toyota tech that's in business for himself, so I'd have him install it. Goes by Speed Freek on CustomTacos.
    What is this backlash? First I'm hearing of it.
  13. Nov 10, 2010 at 9:53 PM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    It is not the easiest install in the world but can be done. You will need to set the backlash on the ring gear though after install. It is not hard but does require some knowledge. as far as the tru trac goes. I've heard both ways. Good and Bad. But the bad is pretty bad... It does destroy the diff. Also are you sure you have an 8" ring gear because xrunner's have 8.4" ring gears and the one you posted is for an 8" ring gear. So as far as the LSD goes from an xrunner I don't think it will swap over. I wouldn't really recommend it anyways... My VLSD sucks anyways... The clutches will burn out quite quickly. I will admit though that I will be doing this Tru trac soon myself and I will be installing it myself. :thumbsup: Anything else let me know. :)
  14. Nov 10, 2010 at 9:55 PM
    xroller
    Ramon
    1 hp mod
    It's the amount of play between the ring and pinion gear..... The amount the ring gear can roll back has to be within a certain spec which is adjusted by inserting shims to scoot the pinion gear closer or ring gear closer together.
  15. Nov 10, 2010 at 9:57 PM
    ryanjboutin
    Las Vegas
    Yea wasn't sure on that part. lol Thanks for the clarification.
  16. Nov 10, 2010 at 9:59 PM
    xroller
    Ramon
    1 hp mod
    not a problem man. I'm not sure if you have an 8" ring gear though. I just know we do have an 8.4" ring gear.
  17. Nov 10, 2010 at 10:00 PM
    afd23a
    The Dynamo of Dixie
    This website will give you an idea of what it takes to do the install
    http://www.gearinstalls.com/max.htm
    backlash is a measurement of the clearance between the ring and pinion gears
  18. Nov 10, 2010 at 10:07 PM
    ryanjboutin
    Las Vegas
    My understanding is that the rear ends are exactly the same, with the exception of the gear ratios. Does that matter?
    Crazy good info, thanks for that bud.
  19. Nov 10, 2010 at 10:13 PM
    xroller
    Ramon
    1 hp mod
    Not at all. As long as the ring gears are the same you should be fine. :thumbsup:
  20. Nov 10, 2010 at 10:15 PM
    afd23a
    The Dynamo of Dixie
    :thumbsup:
