Detroit TruTrac - LSD Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NumNutz, Jul 17, 2014.
  1. Jul 17, 2014 at 8:37 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I wanted to take the time to write a quick review on the Detroit TruTrac LSD. It's been installed a couple of days now and I am absolutely in love with how she performs. The mechanical LSD in my 07 Tacoma had worn out. The LSD in 08 and older Tacomas is a mechanical "real" LSD in that it uses clutch-packs to engage the other wheel when it senses one wheel spinning. Well the problem with such a system is that if you beat on your truck (the way I do:D) unfortunately those clutch-packs can wear out by the 90-100k mile mark.
    The TruTrac uses a helical-gear system. Basically this is a LSD that is made entirely out of gears. It doesn't have clutch-packs that can wear out.
    There is only one con. This type of LSD requires both wheels to have "some" traction. This means if one wheel is entirely off the ground the system will not send power to the other wheel, so maybe not the best option for those serious off-roaders, but then again if you often find yourself in such off-camber scenarios a locker is the way to go. The trutrac has a torque bias ratio. It means if the torque bias ratio is 4:1, it can apply a maximum of 4 times the loose wheel's torque on the wheel with traction. This means, if you have one wheel off the ground, you're still going nowhere with a helical-gear system. 4 times zero is still zero. One quick fix if you're stuck is to apply the brakes. With the LSD working against the brakes, it will transfer 4 times the braking force to the wheel on the ground.
    I think the pros of this LSD highly out weigh the cons. If you enjoy crawling, or more technical wheeling, I think you should pursue a locker. But, if most of your wheeling is sand, snow, gravel, or other lighter maybe more high speed stuff I would look no further than the Detroit TruTrac.
    I give another update once I've thrown a few more miles on this thing, but I'm only smiles so far. Thanks for reading.
  2. Jul 17, 2014 at 8:41 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    How much did it cost to install down there?
  3. Jul 17, 2014 at 8:46 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    $514 for the diff from Jegs
    $350 for the install. I drove the truck in as well. I didn't remove the third for them. Torspd had his installed in Houston with the third removed for $175.
  4. Jul 17, 2014 at 9:14 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Thanks
  5. Jul 18, 2014 at 12:40 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I had one on my 1st gen Tundra and really liked it. It was just a 2wd, but I could always get both tires moving. In winter I would put 6 Home Depot buckets of sand in the back (still do that in my Tacoma) and it made all the difference. I will say that when both engage you can really spin the rear around. That can make it tricky on a slick surface when the outside tire goes away. Or, you can pull impressive burnouts...that might have happened.
  6. Jul 18, 2014 at 2:45 AM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    It's downright comical trying to 2004 STI on the road in the winter with its front and rear diffs because of how quickly they engage. I can only imagine how that felt with a 2wd
  7. Jul 18, 2014 at 10:30 AM
    ThomasMore66
    Latest TopGear mag had a story about taking an STI up Mt Washington in the snow. I want one.
  8. Jul 26, 2014 at 11:56 AM
    hotrod4787
    hotrod4787 Member
    Texas
    2010 Taco Double Cab Long Bed 4x4
    Weathertech floor mats HID 6000K hi/lo 3000k fog
    Do you have a part number?
    Do we have the 8.4" ring or the 8.0"
    I have a 2010
    Thanks
  9. Jul 26, 2014 at 12:00 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    You have an 8.4
  10. Jul 26, 2014 at 1:14 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    my want very bad. one of those in the rear and I would be a happy camper
  11. Jul 28, 2014 at 8:08 AM
    mloco575
    mloco575 Well-Known Member
    CT
    2011 TRD Sport DC long bed
    so would this work in an 09 and newer truck with auto LSD?
  12. Jul 28, 2014 at 5:35 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    sub'd :thumbsup: thanks for the review!
  13. Jul 28, 2014 at 6:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    still would rather have a locker.
  14. Jul 28, 2014 at 8:32 PM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    The only locking lsd I'm aware of is the Auburn ected, which is a clutch based lsd. And is not available for our trucks.
  15. Jul 28, 2014 at 8:50 PM
    nd4spdbh
    SoCal
    that would be ideal.... as like stated a locker in stuff like snow / ice is meh.
  16. Jul 29, 2014 at 4:09 AM
    wildcats
    13 DCSB Sport
  17. Aug 17, 2014 at 2:12 PM
    hotrod4787
    hotrod4787 Member
    Texas
