Developing vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by newertoy, Aug 26, 2011.
  1. Aug 26, 2011 at 10:22 AM
    newertoy
    newertoy [OP] Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Recently installed AAL,Bilsteins all around-1.75 front,1" front differential drop.Drive shaft drop.
    New tires and alignment.
    All has been fine for about a month(NO VIB).
    NO VIBRATION FOR A MONTH
    Now a vibration is developing at 35-40 mph. It only happens when the truck has not been driven for a few hours.
    After the first or second run thru the gears(warm up) the vibs get much less. In 4x4 same vibs--just less. Have not figured out where they are comming from yet.
    Where should i start to diagnose the problem.
    Wheel bearing? front diff? Drive?
    CRAP --thought things were perfect.
