Devil Horns Emblems
Discussion in 'Diaz Fabrication' started by Andres, Sep 30, 2008.
  1. Jan 15, 2019 at 3:37 PM
    #861
    lynyrd3
    Bill
    East Central Upstate NY
    Maybe some kind of baking soda concoction :notsure:
    ChadsPride and RobP62[QUOTED] like this.
  2. Jan 15, 2019 at 3:40 PM
    #862
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    ChadsPride and lynyrd3[QUOTED] like this.
  3. Jan 15, 2019 at 3:41 PM
    #863
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Well, I know how much of a wonderful son you are. Just throwin' it out there. :fistbump:
    ChadsPride[QUOTED] and lynyrd3 like this.
  4. Jan 15, 2019 at 3:42 PM
    #864
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    If you're worried, just distilled water is enough.
  5. Jan 15, 2019 at 3:50 PM
    #865
    lynyrd3
    Bill
  6. Jan 15, 2019 at 3:53 PM
    #866
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I've never had any luck painting aluminum but PC's have come a long way. Must stick, they make aluminum hoods & funders now.
  7. Jan 15, 2019 at 3:53 PM
    #867
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I would think if you are just painting yours you could use emery paper and sand them off wet style. Or do the oven cleaner. It seems to etch the aluminum a little and you want that anyway if you are painting them. Or you could use etching primer.
  8. Jan 15, 2019 at 3:54 PM
    #868
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This ^^^, you will definitely need an etching primer or for the aluminum to be etched via the oven cleaner chemicals.
    lynyrd3 likes this.
  9. Jan 15, 2019 at 3:58 PM
    #869
    lynyrd3
    Bill
    Gotcha :thumbsup:
    RobP62[QUOTED] likes this.
  10. Jan 15, 2019 at 4:02 PM
    #870
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Here's a thought too. You could try white Plastidip. And then use a Plastidip clear. That way should it not go as well as you'd like just peel it off and do it again. I do recommend at least 6 coats of white plastidip and 3 coats of clear though for durability in your case. :D
  11. Jan 15, 2019 at 4:06 PM
    #871
    lynyrd3
    Bill
    I’m thinking of removing all the white , it only has a couple small chips but down to the aluminum . Then do the oven cleaner and emery cloth ( overkill ) prime and paint . Thinking Olive drab , military green .
  12. Jan 15, 2019 at 4:08 PM
    #872
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, I would try the oven cleaner first. Well, let me do mine this weekend. Then do yours. Yours are anodized white?
    lynyrd3[QUOTED] likes this.
  13. Jan 15, 2019 at 4:09 PM
    #873
    lynyrd3
    Bill
    I got them from Andres
    .. I thought it was just powder coated :notsure:
  14. Jan 15, 2019 at 4:11 PM
    #874
    lynyrd3
    Bill
    yes ,SuperWhite
  15. Jan 15, 2019 at 4:13 PM
    #875
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    No, I just checked his site. White only comes as a powder coat. Not anodized. I'm sorry that is completely different. Let me see what I can find out.
  16. Jan 15, 2019 at 4:17 PM
    #876
    lynyrd3
    Bill
    Cool, it will probably be easer to repaint them :thumbsup: Figured since the HomerTaco grill is going on I would change up the horns . I might even mount the horns on the tailgate and go with TOYOTA on the grill !
  17. Jan 15, 2019 at 4:18 PM
    #877
    lynyrd3
    Bill
    Thanks Rob :fistbump:
  18. Jan 15, 2019 at 4:29 PM
    #878
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, everything I am reading involves a lot of chemicals and elbow grease. Seems like a brief emery paper sand followed up with some 000 or 0000 steel wool would do the trick, then etching primer and then your favorite paint.
    I am definitely putting mine on the grill. I want them up front!
  19. Jan 15, 2019 at 4:33 PM
    #879
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Anytime Bill! :thumbsup:
  20. Jan 15, 2019 at 4:34 PM
    #880
    brother.earth
    brother.earth DrinkSmokeFish!
    Southwest Idaho
    2011 Taco TRD Sport
    Hey Andre, can you do shotpeening without anodizing afterwards? I like the slight increase in strength and the rougher surface as opposed to the natural aluminum which still shows some machining marks... I'm looking to paint it myself to color match my truck...
    ChadsPride likes this.
