DeWalt Tools
Discussion in 'Garage / Workshop' started by Pablo8, Jan 7, 2021.
  1. Mar 19, 2021 at 9:11 AM
    #81
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    There is a limit. Most 120v tools are limited to 15amps (or about 1800 watts) in practice they typically don’t pull more than 12amps for long periods (about 1440 watts)
    Cordless on the other hand is regularly delivering over 3600 watts continuous. Granted you need a lot of batteries cause your runtime will be short. But as far as raw power is concerned, cordless is the new king.
  2. Mar 19, 2021 at 9:21 AM
    #82
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    This. Plus take into account power per size, and power per weight - OK power per MASS and cordless wins.
    Here's the thing. When the cordless circular saws came out, that was the coop de Gracie. I can go to any corner or my properties and build a nice wooden fence with driver/drill and saw. I suppose I could string all my extension cords together.............meh no chance.
  3. Mar 19, 2021 at 7:35 PM
    #83
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Perhaps I should have been more clear for the nit harvesters.
    Corded power supply is not limited, therefore unlimited run-time. Batteries have limited power supply, therefore limited run-time.
    You use what you wish. I'll continue to use corded power tools. I won't have a battery crap out mid-task.
    Guys, you won't be able to teach me much regarding power tools. I've been in the industry for over 25 years......designing and testing.
  4. Mar 19, 2021 at 7:56 PM
    #84
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Imo you’d be hard pressed to run out of power with today’s battery’s options. I redecked my house (about 35 squares), fixed some framing issues and dun did all new fascia and I never even came close to running out of juice using a 8ah battery. I just put it on the charger at night when I was done and that was that. Did about 3, 12-14 hour days doing rips and cross cuts with a shit ton of $45 4 ply cdx and 6x6s.
    Used a battery powered nailer for the sheathing, for a project this large I will say air probably would have been the better way to go. I used a 6ah battery and barely made it to the end of the day. I was a little more liberal than 12 in the field.
    Jojee117 and malburg114 like this.
  5. Mar 20, 2021 at 11:15 AM
    #85
    jowybyo
    Joe
    Baltimore, MD
    Cool, where do you work?
  6. Mar 20, 2021 at 6:28 PM
    #86
    Knute
    Porter Cable/Delta, Milwaukee, Rigid/Ryobi
  7. Mar 20, 2021 at 7:14 PM
    #87
    jowybyo
    Joe
    Baltimore, MD
    Are you still in the industry?
  8. Mar 20, 2021 at 7:27 PM
    #88
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Oh another yellow tool I forgot I didn't add because it was tucked away. I used it today. 10" table saw.
  9. Mar 21, 2021 at 6:36 AM
    #89
    Knute
    No. Retired from that mess in 2019.
  10. Mar 21, 2021 at 2:06 PM
    #90
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Corded tools are for people that still get the newspaper delivered to them. Those days are gone
    Jojee117 and TK-422 like this.
  11. Mar 21, 2021 at 5:47 PM
    #91
    Knute
    o ye of small mind.................
  12. Mar 22, 2021 at 6:11 AM
    #92
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    They both have their place, corded at home in the shop, cordless on the road or anywhere remote you don't want to drag a genny to.. but small minded.....:hattip:
  13. Mar 22, 2021 at 7:40 AM
    #93
    TexasTacoma713
    PNW
    2024 OR
    Corded tools belong in the trash. The only corded tool they even make these days is sds drills or jackhammers and even then they’ll stop making those corded soon. There is no market for corded tools.
    Gas or brushless battery powered is the standard now. Why even mess around with cords???
    Even gas will be absolute eventually. Every OPE manufacturer offers a battery powered option. Leaf blowers, zero turn mowers, everything
  14. Mar 22, 2021 at 7:50 AM
    #94
    TexasTacoma713
    PNW
    2024 OR
    I got the 60volt blower and thing is a beast. You’ll want to run at least a 9ah battery tho, the 6ah run time is minimal. I get about 15-20 mins full blast nonstop on a 9ah fully charged.
    All the 60v flex volt tools are monsters.
  15. Mar 22, 2021 at 7:50 AM
    #95
    jowybyo
    Joe
    Baltimore, MD
    I'm a big fan of cordless. But there is still a market for corded. They are cheaper for one. We still use a lot of corded grinders in the shop. When you are using them continuously for hours, it really gets expensive to have enough batteries to keep up. Also, corded grinders are more ergonomic since they don't have the battery awkwardly hanging off of them. It's not a big deal if you have a small job. But if you have to do hours of grinding everyday, it takes it's toll. Also, no matter what we use, they all only last about 9 months. The corded ones are a lot cheaper to replace.
    Jojee117, EatSleepTacos and Wulf like this.
  16. Mar 22, 2021 at 7:52 AM
    #96
    Sandman614
    Tim
    '06 SR5 Off Road
    aren't they both FlexVolt 60V?
  17. Mar 22, 2021 at 7:53 AM
    #97
    TexasTacoma713
    PNW
    2024 OR
    That is a good point. Never thought of it that way. I’m always out in the field
  18. Mar 22, 2021 at 7:55 AM
    #98
    TexasTacoma713
    PNW
    2024 OR
    You’re right. I don’t see that older one around for sale tho. The axial is the newer one
  19. Mar 22, 2021 at 8:11 AM
    #99
    jowybyo
    Joe
    Baltimore, MD
    Yup, that's pretty correct. But in this case, there's a big difference in overall power of the units. Ultimately you want high force, that's what moves things. Below is a comparison of the actual force of the air.
    DCBL772: 1600g
    DBCL770: 1150g
    As you see, despite the high mph, the DCBL770 has a lower overall force. It's about a 40% difference. You could argue that the smaller flat concentrator of the DCBL770 might be better for cleaning gutters because it might be easier to control where the narrower column of air is directed. But in general the DCBL772 will more easily move wet leaves.
    Sandman614[QUOTED] likes this.
  20. Apr 19, 2021 at 8:01 AM
    #100
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    Anyone know where I can get a new 20V impact wrench that is 3/8 with the regular detent pin? Not the hog ring!
