DeWalt Tools
Discussion in 'Garage / Workshop' started by Pablo8, Jan 7, 2021.
  1. Jan 30, 2022 at 8:30 AM
    #161
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Thanks. I guess I'll stay in camp yellow. ;)
    EatSleepTacos[QUOTED] likes this.
  2. Jan 30, 2022 at 8:43 AM
    #162
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    We have a bunch of construction going on at work and I’ve noticed that all of the contractors (plumbing, electrical, steel workers, concrete, etc) use DeWalt almost exclusively.
  3. Jan 30, 2022 at 8:58 AM
    #163
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Power is not the concern, has plenty of power, it’s the run time of the batteries
  4. Jan 30, 2022 at 8:58 AM
    #164
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I am about to start purchasing the following:
    1/2 & 1/4” Impact
    Cordless drill. I have 1/2” DeWalt corded when I feel like breaking my wrist.
    Where is everyone purchasing? Do we have a DeWalt distributor?
    Been seeing some Craigslist distributors with some decent prices.
    My local HD is all right, and I get a 10% discount from those prices.
    Looking at the 1/2” impact, probably should go with my gut and do the Max since I have some lug nuts that require 175 ft lbs of tq instead of going with the cheaper model. I suppose 600 ft pounds should be good enough…
    F950D12B-68C1-40AA-9AEB-B850E0CA59A0.jpg 2B677789-093A-4854-96C1-06211187EDC2.jpg 1CEDD056-916E-4E9D-ADBA-0E2C5A91A45F.jpg 81443D8C-2CEB-4090-83CF-A1AC3B597DB3.jpg B892429B-454B-4D5E-BE4E-D508883F3661.jpg F3AA9A56-5D90-4001-B77A-9002CB9E7812.jpg 164DD68B-9C6D-4B1A-8D95-4026286C0B0E.jpg 1744E24B-4F13-42A9-8C0C-E89AA14DD1BC.jpg
  5. Jan 30, 2022 at 9:18 AM
    #165
    TexasTacoma713
    PNW
    2024 OR
    Lowes will have a buy 1 tool and get a free power stack and charger soon. (Saw the promo on https://instagram.com/autobahn_dan
    High end torque wrench is huge and overkill.
    I got the mid range with detent pin and I believe that will be on the lowes promo. That’s an older model they are phasing out (DCF894). Also recommend not running it on a 2ah battery, it won’t even break off lug nuts, gotta use at least a 4ah to get full power
    ColoradoTJ likes this.
  6. Jan 30, 2022 at 9:22 AM
    #166
    ColoradoTJ
    Colorado
    Knew the TW community would have some great information. Thank you sir.
  7. Jan 30, 2022 at 9:28 AM
    #167
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
  8. Jan 30, 2022 at 9:29 AM
    #168
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ll also agree that the high end 1/2” is overkill. I have one too and it is nice but it’s large and unwieldy. That’s why I use the 1/2” 12v and when that’s not enough, I’ll bust out the big boy. If you were to only get one though, mid range would work nicely.
    ColoradoTJ[QUOTED] likes this.
  9. Jan 30, 2022 at 9:47 AM
    #169
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    @ColoradoTJ
    I own a lot of DeWalt tools. From corded to cordless. From chainsaws to grinders. They get used and abused for work on a daily basis. I also wrench on my rig a lot since I'm constantly breaking shit. I have 3 models of impacts currently in service.
    1/4" DCF887
    3/8" DCF890
    1/2" DCF899
    The DCF899 comes out the least. The 1/4" the most. I picked up the 3/8" because I was damaging the chuck on the 1/4" driving SDS screws. The 1/4" has the power to drive even a 9" SDS screw no problem but the quick-change chuck can't take the abuse for more then 6 months. Since switching over to the 3/8" for SDS driving the 1/4" has gotten repaired much less.
    As others have said the 1/2" DCF899 is heavy and brutally strong. One nice feature about the DCF899 is the 3 speed setting. You can tame the tool down for less torque intensive work.
  10. Jan 30, 2022 at 9:49 AM
    #170
    TexasTacoma713
    PNW
    2024 OR
    You may also want to cross reference prices on eBay too, but check seller ratings before purchasing.
    I’m sure those power stack batteries have power, I’m just concerned about run time on them
    And if you’re buying a charger separately, consider buying a higher output amperage one. See used section on Amazon link
    DEWALT DCB1106 6 Amp Charger https://www.amazon.com/dp/B089FMLC3H?_encoding=UTF8
  11. Jan 30, 2022 at 9:59 AM
    #171
    dfanonymous
    I was under the impression they aren’t designed for run time. The powerstack are like a 1.7 ah.
    Plus the power is fixed. Dewalt is 18v nominal. If I remember right the watt outs are similar to the 5 ah xr battery, but the power stack is smaller and lighter. Edit: I fact checked myself and the watt hours are similar
    Dcb 201 battery. It’s safe to say the power of the power stack is similar to a 2.0 battery as advertised.
    I’m thinking dewalt is waiting to see how they do before they come out with the larger AH batteries in the power stack configuration.
    theesotericone likes this.
  12. Jan 30, 2022 at 10:02 AM
    #172
    theesotericone
    Bishop CA
    Have you used the DCB118 charger? It's the charger DeWalt ships with there FlexVolt tools. You can also buy it separately. Like most DeWalt chargers it also chargers the 20V line. It'll charge a 5AH 20V in about 20 minutes. I have 2 and they are the only ones I use. The 20V chargers have a home in a drawer that never sees daylight. lol
    https://www.amazon.com/DEWALT-DCB11...t=&hvlocphy=9031764&hvtargid=pla-435585941203
  13. Jan 30, 2022 at 10:08 AM
    #173
    theesotericone
    Bishop CA
    Battery tech is constantly changing but the one thing that's really important to me is run time. That's why I only own 5AH 20V batteries. I also have FlexVolt 9AH's. I need a battery to last long enough that I'm not wasting time running to the charger. For most hobby guys it's probably not that much of an issue but I want to work not walk. lol
  14. Jan 30, 2022 at 10:08 AM
    #174
    ColoradoTJ
    Colorado
    I’m glad you said something. This is the same thing that is happening to my 1/4” Ridgid. Pisses me off to no end. This time it’s done.
    38E68452-231D-4361-87AE-ACC173D73489.jpg B24744AB-5004-4791-AE57-26AB11CD9282.jpg
    Don’t get me wrong, this Ridgid was purchased in 2012, went through a complete home remodel, three fence rebuilds, and a chicken coup 8x18 Hilton. Just seeing if there is something better on the market.
  15. Jan 30, 2022 at 10:11 AM
    #175
    TexasTacoma713
    PNW
    2024 OR
    Oh I know about that 8 amp charger… but I ain’t paying $90… rather pay $25 for a 6 amp
  16. Jan 30, 2022 at 10:14 AM
    #176
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    There’s a 12A charger now too
  17. Jan 30, 2022 at 10:14 AM
    #177
    theesotericone
    Bishop CA
    Sorry man. All I see is 4 link. lol
    On a serious side you can get the parts to repair the chuck pretty easily. I've repaired my DeWalt 1/4" about 5 times now and can do it in under 10 minutes with $7 in parts. That said, having a non-quick change for heavier tasks is the way to go. When I picked up the 3/8" I also grabbed a few of these. They allow me to use 1/4" bits on my 3/8".
    https://www.amazon.com/Titan-12034-...9aea495ffbf&pd_rd_wg=HUb9y&pd_rd_i=B07HBHV6LV
  18. Jan 30, 2022 at 10:17 AM
    #178
    theesotericone
    Bishop CA
    Both mine came with FlexVolt tools. When DeWalt runs their Fathers Day promo you can usually pick up combo kits pretty cheap. Every other time of year I just buy the bare tools because I have plenty of batteries now and buying the bare tool is always a lot cheaper.
  19. Jan 30, 2022 at 10:19 AM
    #179
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    Been using dewalt cordless tools for the last 10+ yrs at work as an electrician & also at home. Never had any issues from the 18v to now the 20v’s. Been impressed with the abuse they’ve taken from drops off of 6-8’ step ladders onto concrete floors & kept on motoring! Drill, impact, rotohammer, mini bandsaw, & vac get the most use. Pretty good set home also, skill saw & pole saw get use ofeten & work great. Looking to add the jig saw, palm sander, & mini blower at some point
  20. Jan 30, 2022 at 10:19 AM
    #180
    dfanonymous
    Oh for sure. Some of the tools are power drainers too. I sheeted a whole roof with a 6 ah battery on my skillsaw but it took a 6 and a 8 ah to break up a 6 sq ft slab of concrete using a sds rotary using a chisel. :rofl:
