[DEZ TOY FAB] FULLY FABRICATED MOTOR/TRANS MOUNTS 05-15 TACOMA 1GR-FE
Discussion in 'Dezert Toy Fabrication' started by DTFtacoma, Oct 20, 2016.
  1. Oct 20, 2016 at 11:32 AM
    DTFtacoma
    DTFtacoma [OP] Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Hey guys after tons of requests I decided to begin production of fully fabricated motor & transmission mounts for the 05+ Tacomas with 4.0 V-6. Two wheel & four wheel drive 5 speed automatic and 6 speed manual transmission mounts are now in production. These are CAD designed, laser cut, CNC bent, powder coated, with grade 8 hardware included.
    Brought to you for the low price of $380 for the motor mount and $220 for the Transmission mount or you could buy the combo for $560.
    First the Motor mounts
    ***Driver***
    ***Passenger***
    Transmission mounts
    ***5 Speed Automatic Trans Mount***
    ***6 Speed Manual Trans Mount***
    ***4WD 5 & 6 Speed Trans Mount***
    ***Prototype Pics***
    ***PRODUCTION PICS***
    Mounts come with properly lubricated bushing halves pre-installed.
    These are the only to come with an additional mount that acts as a clamp to help alleviate some of the stress on the OEM frame mounting location.
  2. Oct 20, 2016 at 11:37 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Damn!!!!!! Subd for bad ass products like always from DTF!!!!
    :headbang::headbang::headbang::headbang::headbang::headbang::headbang::headbang::headbang:
    BassAckwards and DTFtacoma[OP] like this.
  3. Oct 20, 2016 at 11:51 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Thank you!
    ChadsPride likes this.
  4. Oct 20, 2016 at 11:58 AM
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Sub'd!!
  5. Oct 20, 2016 at 1:28 PM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Subbed.
  6. Oct 20, 2016 at 3:02 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Sub'd
  7. Oct 20, 2016 at 3:36 PM
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SCV, CA
    SOLD =( MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    Looks great. Going to be any love for the 4 cylinder guys?
  8. Oct 20, 2016 at 4:13 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    When u get the 6 speed mount I'll buy one
  9. Oct 20, 2016 at 10:02 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I'll keep you posted
  10. Oct 20, 2016 at 10:05 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Same. Let me know if you need a Guinea pig for the 6 Speed. You're alot closer than SoCal and I wouldn't mind spending a weekend in Pismo if need be ;)
  11. Oct 20, 2016 at 10:09 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    No real plans on doing 4 banger mounts but if I do, I'll keep you in mind!
    dcvt16[QUOTED] and ChadsPride like this.
  12. Oct 21, 2016 at 5:28 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So introductory price of $160 for the Trans mount and X member for it @DTFtacoma ?
  13. Oct 24, 2016 at 1:35 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    @12TRDTacoma
    No sir,
    That only includes the trans mount, backing plate, and cross-member gussets.
    I didn't want to produce a cross-member in order to keep prices low.
  14. Oct 24, 2016 at 1:36 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I'll keep you posted.
  15. Oct 24, 2016 at 7:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    How much for the trans mount and x member? Your initial post makes it sound like you can get the engine mounts and the trans mount for $500. It is sort of unclear, unless my reading comprehension is out the window right now. :D
  16. Oct 24, 2016 at 7:21 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You're reading too much between the lines. No new cross member, there is a Trans mount that comes with gussets for the stock cross member.
  17. Oct 24, 2016 at 7:22 PM
    Basikbiker
    Trav
    The trans mount bolts on to the oem crossmember just like the stock one. And comes with some gussets to weld to the oem crossmember..... Makes sense to me
  18. Oct 24, 2016 at 7:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh shit! That's awesome! Me likey that a lot! Thanks for clearing that up Travis and @Sandman614 .
    Hey @DTFtacoma, are there mounts ready and available to go? I want one with the gussets and stuff.
  19. Oct 24, 2016 at 8:03 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Looks great! And good price too.
    What kind of bushings are supplied in the mounts?
  20. Oct 25, 2016 at 9:57 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Currently lead time is 3 weeks on these.
    Poly bushing are included. They're very easy to source for replacement down the road.
