[DEZ TOY FAB] FULLY FABRICATED MOTOR/TRANS MOUNTS 05-15 TACOMA 1GR-FE
Discussion in 'Dezert Toy Fabrication' started by DTFtacoma, Oct 20, 2016.
  1. Aug 22, 2017 at 2:21 PM
    #61
    DTFtacoma
    DTFtacoma [OP] Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Negative side affects on your bank account ;)
    You will feel a little more vibes through the steering wheel and feel hard shifts more. :burnrubber:
    Honestly considering these mounts do still have flex to them, just a reduced amount you should be fine. I'm my field of work a large amount of oscillation is a bad thing and usually ends in broken parts. These will help transfer more power to the ground without your drive-train bouncing around. I highly recommend installing the DMZ motor mount gussets to keep the frame side happy with or without my motor mounts installed.
  2. Aug 22, 2017 at 6:06 PM
    #62
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Do the DMZ motor mount gussets apply to years beyond '05, '06; the years people were having the most problems?
  3. Aug 22, 2017 at 6:13 PM
    #63
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Yes Tim @ DMZ offers kits for 07-15 also. Toyota "fixed" it by adding another plate similar to the FJs but it's still not strong enough.
    Hawk373[QUOTED] likes this.
  4. Oct 3, 2017 at 10:58 AM
    #64
    c jackson
    c jackson Well-Known Member
    Phoenix, AZ
    '17 Tacoma Pro
    @seecjackson
    does the 4wd 6spd trans mount fit 3rd gen? or do you have any plans for 3rd gen?
  5. Nov 23, 2017 at 3:41 PM
    #65
    Barbietaco
    Barbietaco Tools are good
    Shane
    2006 Tacoma
    Sas swap with Dana 60 and GM 14 bolt rear on 42" Pitbulls
    Are these available? If so how do I contact them. Can't find a phone number? Is PMing Dtftacoma the only way? Thanks
  6. Nov 23, 2017 at 3:50 PM
    #66
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Blk Fri deal? Lol nah kidding
  7. Nov 26, 2017 at 6:56 PM
    #67
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    No sorry that will not work. I haven't got one in the shop yet.
    Yes. If you need quicker response please email me dezerttoyfab@gmail.com
    PM replied
    :headbang:
    No sorry man can't really cut a better deal on these but if your military I can knock 5% off :thumbsup:
    jeff b[QUOTED] likes this.
  8. Oct 19, 2018 at 2:09 PM
    #68
    Hawk373
    2012 TRD Sport DCLB
    Has anyone else had a lot of fitment issues with the motor and trans mounts?
    I installed the motor mounts in August and they barely fit. I was just barely able to center the engine perfectly enough to start the nuts and then had to go back and forth between sides forcefully pulling the mounts outward to the frame. There’s quite a bit of tension.
    Last week I installed the transmission mount which went into position fine. The problem is that my drive train angle changed enough that my radiator fan is contacting the bottom of the fan shroud. There’s over a 2” space between the fan and the top of the shroud. I’m not sure how many degrees down the engine moved, but it’s significant.
    I was finishing up a front long travel install at the same time and started driving the truck again this Tuesday. Makes a lot of noise when the fan really gets going in traffic.
    I installed DMZ solid mounts on another member’s truck a few weekends ago. They went in with very little effort and he’s having no issues after the fact. Unless someone has a good suggestion I’m thinking they’re a total loss. I’ve had no luck contacting Anthony since August.
  9. Oct 19, 2018 at 9:33 PM
    #69
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    your not alone several west coast guys In the Long Travel Tread have posted same problems.
  10. Oct 20, 2018 at 2:46 AM
    #70
    Hawk373
    2012 TRD Sport DCLB
    Class action lawsuit? :D
    At least I got a military discount, right?
    I’m learning R&D in the offroad business is charging hundreds and thousands of dollars for slick looking metal bits, doing one test fit and waiting to see what problems the customers have.
    Customer service at that point is optional for the vendor. Depends on if they have integrity, care about the people who support them and the success of their business.
  11. Oct 20, 2018 at 6:53 AM
    #71
    89ztrain
    89ztrain Well-Known Member
    North Carolina
    '11 TRD Sport 4x4
    Same issue here with the fan hitting the shroud.
    Hawk373 likes this.
  12. Oct 20, 2018 at 7:54 AM
    #72
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    You could get some energy suspension bushings for the front mounts. On install put the thinner one on top. It will drop the radiator support down about 1/2".
    I had to do this after rebuilding the front clip of the frame to drop the radiator down off the fan.
    ls1 prerunner likes this.
  13. Oct 20, 2018 at 7:56 AM
    #73
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    If its hitting the top then I could use the lift on my motor.
  14. Oct 20, 2018 at 8:25 AM
    #74
    Hawk373
    2012 TRD Sport DCLB
    I was discussing that with another member too. Which lead to his DMZ mount install.
    I actually have the bushings installed that way already. So the effect of these mounts is so bad it creates contact with an already slightly lowered radiator support. I’d have to cut the top bushing down to gain more clearance.
    I considered making plates to push the mounts in from the frame side. 1/4 or 3/8”.
    I’m hoping the lower engine angle isn’t putting stress on anything I haven’t found yet. Especially when I’m able to actually start beating on this thing.
  15. Jul 25, 2019 at 7:12 AM
    #75
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Is dtf no more? or are they still open
  16. Jul 25, 2019 at 8:59 AM
    #76
    Hawk373
    2012 TRD Sport DCLB
    Doesn’t seem like it. Why, do you want DTF engine mounts? Worst install I’ve ever had to do, plus a lot of bad side effects.
    DMZ mounts slipped right in, no issues. Really sucked having to do this twice and paying for it twice. I’d contact DMZ or @Bonzen.
    Bonzen likes this.
  17. Jul 25, 2019 at 9:01 AM
    #77
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im not, Im interested in the tranny mount
  18. Jul 25, 2019 at 9:07 AM
    #78
    Hawk373
    2012 TRD Sport DCLB
    @Bonzen only makes the engine mount and DMZ will sell you whichever you want.
    I’ve installed the DMZ mounts on two separate trucks with no issues. They go right in.
  19. Jul 25, 2019 at 11:20 AM
    #79
    Sandman614
    Tim
    '06 SR5 Off Road
    Are they designed that much differently?
  20. Jul 25, 2019 at 12:57 PM
    #80
    Hawk373
    2012 TRD Sport DCLB
    The DTF mounts had my fan into my fan shroud. It was almost impossible to get the bolt holes to line up or even get the nuts started on the threads.
    Once I did, with the engine hovering perfectly in the air, I went from side to side dragging the mounts outward to meet the engine. The bushings were screaming by the end of it.
    I installed the trans mount at a later time and that lifted the trans up, tilting the engine down even more.
    DTF on the left. No good.
    GT7 likes this.
