DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Mar 12, 2018 at 8:21 AM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    ChadsPride likes this.
  2. Mar 12, 2018 at 9:26 AM
    ztaragon
    ztaragon @zta.co
    Burleson
    2019 TRD OR DCSB
    Fox 2.5 non resi fron Fox 2.0 rear with resi Toytec AAL 285 75 16 Nitto Ridge Grappler Method wheels
    anyone know a person or place that will do the black head light mod for me in the area? would rather spend money that do it myself
    trekker and ChadsPride like this.
  3. Mar 12, 2018 at 9:31 AM
    Crash721
    Crash721 Well-Known Member
    Brandon
    2013 Tacoma PreRunner
    285/70/17 BFG KO2's 4" Maxtrac spindle lift kit. Caliraised 30" slim led bar
  4. Mar 12, 2018 at 9:31 AM
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    It's actually pretty easy. Just don't use a towel in the oven. Apparently about 300 degrees is the temperature that cotton will ignite.
  5. Mar 12, 2018 at 9:32 AM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Never would have thunk it.
  6. Mar 12, 2018 at 9:32 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  7. Mar 12, 2018 at 9:50 AM
    Suprajim54
    Jimbo
    Irving, TX
    Now, i did use cardboard in the oven, but I also put aluminum foil on both sides, heated up the oven first, turned it off, then puts parts inside. It took more time having to keep reheating the oven, but it felt like the most cautious way. Biggest pain was removing as much of the old sealant as possible. Once that was done, it was easy peasy.
  8. Mar 12, 2018 at 9:53 AM
    Silverspool
    Silverspool [OP] Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    take lesson from that other guy, dont put anything flammable in the oven. Use a baking sheet with foil on it, if you insist on putting flammable items in the oven, please have your phone ready on photo or video mode.
    IF there is a fire, its too late anyways, must take a picture of it before attempting to put it out.
  9. Mar 12, 2018 at 9:56 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Yea, pretty much this.
    That way we can mock and ridicule said person for years and years.
  10. Mar 12, 2018 at 10:09 AM
    Tundra2Play
    Tundra2Play Well-Known Member
    2003 Tundra Limited 4x4 AC 4.7 ltr
    Camburg UCAs, 5100’s, OME 885 up front, fox 2.0’s with 2” aal in rear. SCS F5’s wrapped in 315/75 Maxxis Buckshots
    Had a guy set our shop on fire, burned the place realllll good. He wasnt fired for his actions, but instead quit, because we constantly made fun of him for being a dumb ass... (After attempting to manually siphon, he started using a spare fuel pump and a jump box to try and siphon old fuel from an early 70’s charger.)
  11. Mar 12, 2018 at 10:13 AM
    Suprajim54
    Jimbo
    Irving, TX
    Is that the same location that you're currently at? Never would've guessed there was that big of a fire there.
    ETXTacoma likes this.
  12. Mar 12, 2018 at 10:15 AM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    ETXTacoma, trekker and ChadsPride like this.
  13. Mar 12, 2018 at 10:16 AM
    trekker
    trekker I like tacos
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    floor mats and a beer switch
    Probably got a small rock or something under the dust seal and some fluid came out... it happens. You can usually use high pressure rinse to clear the debris out, clean around the housing, and drive around to see if more fluid leaks. If you still leak then the seal is probably boogered up but they're pretty easy to replace.
  14. Mar 12, 2018 at 10:20 AM
    Suprajim54
    Jimbo
    Irving, TX
    Cool, I'm hoping it is something simple like that. Also going to check my diff breather to make sure its not clogged. Just thinking maybe it could be blocked causing a rise in pressure inside the diff pushing some fluid out. :notsure:
  15. Mar 12, 2018 at 10:23 AM
    ETXTacoma
    Steven
    Tyler, Texas
    What a jackass...
    Hahahahahaha
    Beef Nachos and ChadsPride like this.
  16. Mar 12, 2018 at 10:25 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Post number 10,000.
    Ain't Care.
  17. Mar 12, 2018 at 10:25 AM
    ChadsPride
    trekker likes this.
  18. Mar 12, 2018 at 10:27 AM
    trekker
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    That's what happened to me, and it also blew out my driver side axle seal and pinion seal. They were obvious leaks... much more than what it looks like on yours. Check under the rest of your truck like on the cross members and gas tank to see if you have any oil on them.
    But I was running thicker gear oil, geared to 4.88 on small tires, and driving 90mph+ for a long period of time and I guess it got too hot.
    I added an inline fuel filter to help burp the vent tube and allow the expanding air to escape around the expanding oil so it doesn't happen again.
    edit: the inline fuel filter... I removed the filter element to make it act like a catch can
    Suprajim54[QUOTED] likes this.
  19. Mar 12, 2018 at 10:44 AM
    dwaltdtx
    dwaltdtx Well-Known Member
    David
    DFW, TX
    Had to use two seals on my pass side to keep it from seeping. Still don't know why, but it's "fixed" now
    ETXTacoma and ChadsPride like this.
  20. Mar 12, 2018 at 10:47 AM
    Suprajim54
    Jimbo
    Irving, TX
    Are you saying you went through two seals before it stopped or you actually have two seals installed on pass side?
