DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Jul 2, 2018 at 9:09 AM
    Silverspool
    Silverspool [OP] Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    those of you with ARB Awnings and Prinsu racks, do you need any extra mounting hardware or does the awning come with hardware needed to mount to Prinsu?
    Edit: or Smitty awnings
    @Steawy27 @ETXTacoma @Naveronski
    ETXTacoma likes this.
  2. Jul 2, 2018 at 9:14 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You need extra mounts. Sierra Expeditions is the cheapest place I've found them.
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=25663
    Or you can cobble together some stuff but the awning will sit lower and the zipper will get caught in the door
  3. Jul 2, 2018 at 9:15 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I used the Prinsu brackets.
    Got them used, they work great. Not sure I’d pay retail for them.
  4. Jul 2, 2018 at 9:16 AM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
  5. Jul 2, 2018 at 9:25 AM
    Crash721
    Crash721 Well-Known Member
    Brandon
    2013 Tacoma PreRunner
    285/70/17 BFG KO2's 4" Maxtrac spindle lift kit. Caliraised 30" slim led bar
    I can only speak for the rack it had all the hardware needed to mount the rack and a few spares. They also have new cross bars now where you dont have to take it off to add something.
    ChadsPride likes this.
  6. Jul 2, 2018 at 9:29 AM
    hoarder23
    Shay
    NJ
    Scratches
    If you can find the cheaper do that, they are fancy and don't need to be that strong, but understand they are sold as singles
  7. Jul 2, 2018 at 9:30 AM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    2 enough for a 6ft awning? Its gonna hang off the back if the cab a little
  8. Jul 2, 2018 at 9:32 AM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    I’ve definitely rafted close to that Malibu before now that I think about it. Party cove is my jam.
  9. Jul 2, 2018 at 9:53 AM
    hoarder23
    Shay
    NJ
    Scratches
    I use 2, hasn't fallen off yet
  10. Jul 2, 2018 at 10:14 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    The dam is my jam, I preferred to be away from everyone. Lot more room for activities at cedar creek dam at least.
    4x4_Angel, ETXTacoma and ChadsPride like this.
  11. Jul 2, 2018 at 10:24 AM
    Tundra2Play
    Tundra2Play Well-Known Member
    2003 Tundra Limited 4x4 AC 4.7 ltr
    Camburg UCAs, 5100’s, OME 885 up front, fox 2.0’s with 2” aal in rear. SCS F5’s wrapped in 315/75 Maxxis Buckshots
    There’s another cove we hit if trying to chill, but party cove is still my flavor lol.
  12. Jul 2, 2018 at 10:25 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Did you ever fix that clunking in your front end?
  13. Jul 2, 2018 at 10:34 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    For those on 285/70-17s, what ya'll running for tire pressure. Tires are E rated ST Maxx on a DCLB
  14. Jul 2, 2018 at 10:40 AM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Only way to know what your trucks tire pressure should be at is to chalk test. Someone might be able to get you close but the weight of the vehicle affects the tire pressure needed.
    Beef Nachos and ChadsPride like this.
  15. Jul 2, 2018 at 10:44 AM
    Hilborn
    Michael
    Utah
    Yea. I just wanted to get close and then I'll be able to dial it in with a chalk test
    ChadsPride and SuperBad like this.
  16. Jul 2, 2018 at 11:05 AM
    Tacoaric
    Dallas, Texas
    I only go when were done riding. I spend 99% of my time on the brazos river riding, and another 1% at the party beach.
  17. Jul 2, 2018 at 11:22 AM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Hey, got to let the people know the options man!
    Well let me know if you do!
    I got some extra hardware and rigged up my own mounting solution when I put my awning on my prinsu, used some bolts, metal spacers, and such and mounted it directly to the awning, did not get in the way of the doors if I recall.
    I guess I didn't save any pictures of how it was mounted onto google photos... but I did have a picture of my hardware box that shows the hardware I used...
    The stuff in the red box.
    Bolt head went in the awning track, then fender washer, then spacer, then washer, then prinsu, then washer, and then nylon lock nut. I think I used like 5 for a 6ft awning and it was strong and held up well.
  18. Jul 2, 2018 at 11:22 AM
    Tundra2Play
    Not yet. Need new outter tie rod, for sure, but might need a new R&P. This ones just over a year old, but it’s a rock auto order, so not sure on their quality. I think it has a 2 year warranty, but not looking forward to replacing it, again.
  19. Jul 2, 2018 at 11:31 AM
    Steawy27
    Steawy27 Well-Known Member
    Mark
    2015 tacoma
    My awning came with the mounting brackets plus I got the after market ones from 4wp...so i have an extra set of yours doesnt..let me know
    Silverspool[OP] and ChadsPride like this.
  20. Jul 2, 2018 at 12:13 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    East coast gear supply
