DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Jul 25, 2018 at 5:14 AM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Word, I will happily take it, and put it in my truck as the truck bottle opener...
    I am just stating what is on the first page of the thread.
    @Zac of all trades why it say he sold his truck?
    SuperBad likes this.
  2. Jul 25, 2018 at 6:04 AM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    I dont know the trails and will reserve judgement until more facts come out rather than the back and forth of what people on the internet think. Just because someone claims he was in the wrong doesnt mean they actually know what they are talking about.
    I will try and remember the bottle opener next time I see you. I'm hoping with the TTR event this weekend that Tandem will be squeezing us in for alignments sooner than later. My alignments good enough to not destroy or wear my tires unevenly so if it takes a while its ok.
    I'll need to go after my pinch welds before saturday. I expect it to be busy with everything going on there this weekend. I just want to get some wheeling in and test the new tires out to see if I've cleared the tires.
    Some people can fit them without rubbing while others cant. I had some rubbing with my 265/70 17's that everyone said would fit with no lift and my wheels since it was only 1" bigger than stock.
    Everything about wheel specs and alignment is foreign to me. I've been trying to learn more about it but damn it gets confusing. I've read the same comments about the trail and if it wasnt a trail i'm sure the video's are enough that the cops will be getting in touch with him and taking care of it.
  3. Jul 25, 2018 at 6:14 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    For you guys running 33s, you flattening the pinch welds?
    ETXTacoma, SuperBad and ChadsPride like this.
  4. Jul 25, 2018 at 6:18 AM
    SuperBad
    Dallas, TX
    Truck stuff
    Thats my plan. Since I'm hitting the cab mount I dont see how I wont rub on the pinch weld when stuffed on a trail.
    ETXTacoma likes this.
  5. Jul 25, 2018 at 6:21 AM
    Hilborn
    Michael
    Utah
    I have the cmc. I've trimmed near everything I can think of. Just concerned if I stuff the wheel in turn, I'll rub the pinch weld
  6. Jul 25, 2018 at 6:29 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Which one is yours? I looked one over last night that was pretty torn apart. It looked like they were redoing the entire electrical system.
    Hilborn likes this.
  7. Jul 25, 2018 at 6:32 AM
    ETXTacoma
    Steven
    Tyler, Texas
    I ended up flattening the entire pinch weld on both sides. When I had the CMC done, they did a cut in the pinch weld and bent it over and then after I swapped over the front fenders and didn't have fender liners I bent over the rest of the pinch weld. I need to take off the front tires and such and put on some sort of coating on the wheel wells though since there is some surface rust on it from the sledge hammer...
    No pictures from last night?
    Hilborn[QUOTED] likes this.
  8. Jul 25, 2018 at 6:34 AM
    Hilborn
    Michael
    Utah
    I'm guessing I need to cut the weld sp it can flatten smoothly to the fender? I plan hitting it with some spray on rubberized bed liner.
  9. Jul 25, 2018 at 6:37 AM
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    I hammered mine down with a 3lb sledge. It was probably about the bottom 6-8 inches of it. I had to do a little trimming of the plastic liner, as well. Running 285/75/16
  10. Jul 25, 2018 at 6:44 AM
    Hilborn
    Michael
    Utah
    I plan on removing the whole plastic liner once I go with a snorkel
  11. Jul 25, 2018 at 6:48 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Yea, for people with fender liners, it is just the bottom 6-8 inches is all that needs to be done and you just need to do one cut. And we just did the cut right below the tab for the fender liner if I recall and then took a sledge and bent it over. I also went back and took some silicon and put some silicon in that to help prevent water and mud and such from getting trapped in that and causing rust and stuff.
    But yea, I need to remove the tires and then remove most of the factory rubberized liner stuff and then spray new stuff on there.
    If you plan on doing that, then I would do like two cuts on it.
    I'll post a picture of how mine looks. Just another thing to add to the list of stuff I need to get around to doing is the rubberized fender liner stuff.
    SuperBad and Hilborn[QUOTED] like this.
  12. Jul 25, 2018 at 6:50 AM
    Hilborn
    Michael
    Utah
    Thanks.
  13. Jul 25, 2018 at 6:50 AM
    rpkole
    rpkole Well-Known Member
    Fort Worth, TX
    2014 MGM 4x4 DCSB
    i just hit mine with a mini sledge and folded it over, im running 255/85/r16 aka 33x10 but at the time i did the CMC and Pinch weld i had 33x13.5's on
  14. Jul 25, 2018 at 6:59 AM
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    does anyone have any experience with service dept of a Ford dealer in Dallas/Plano area? Daughter went to work this morning and repair transmission immediately error popped up on dash and now engine light is on. Engine light may be due to needing oil change which i planned to do this weekend.
    SuperBad and ETXTacoma like this.
  15. Jul 25, 2018 at 7:02 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    @Xplosiv should be able to help
    49erfan[QUOTED] likes this.
  16. Jul 25, 2018 at 7:04 AM
    Naveronski
    Fort Worth
    Nope, not really.
    SuperBad and ETXTacoma[QUOTED] like this.
  17. Jul 25, 2018 at 7:06 AM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Check engine lights don’t come on for oil changes on fords, for sure. I know someone around here works at 5 star ford in Lewisville
  18. Jul 25, 2018 at 7:12 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Booooooo
  19. Jul 25, 2018 at 7:19 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yeah, not that one. Mine is the really clean one that only has 103k miles on it. New OME lift. New LRA gas tank. Been waiting on Marlin Crawler tie-rod ends for weeks and just found out it will be 3 more. Time to swap out vehicles.
  20. Jul 25, 2018 at 7:31 AM
    hoarder23
    Shay
    NJ
    Scratches
    The green one right?
