DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Jul 28, 2018 at 9:16 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    That was the cliffnotes version. I've had the tires on my mind a lot today.
    Dont forget CMC and adding a front locker might as well skip 285's and just jump up to 40's like the marlin crawler 3rd gen :devil:. I would work on figuring out what you need to change on the truck to perform through experience. See what it can do and what needs improved for your intended use. My first trip with the truck was completely stock with no off-road experience. Through trips and wheeling at local parks I have found what upgrades I need sooner than later. Breaking things helps with that also.:anonymous: It wouldnt be so bad if it was just 285's and basic armor(skids/sliders). I wish I had gone 285's sooner. They look so much better on my truck than the 265's i bought 6 months before I added the lift. I know I'm forgetting some things but I have easily added >600lbs in mods on the truck and another 200-300+ when I'm loaded up for a camping trip. I didnt notice much of a change in the truck until I got onto some step climbs.
  2. Jul 28, 2018 at 9:36 PM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Does ECT help at all?
    SuperBad[QUOTED] likes this.
  3. Jul 28, 2018 at 9:52 PM
    SuperBad
    Dallas, TX
    Truck stuff
    It helps acceleration in the city since it holds gears longer but its wasnt any help on the trails. OVtune might help on the trails but I havent convinced myself to go that route since I know gears are the right fix for my needs and future plans.
    Pandaman59 likes this.
  4. Jul 28, 2018 at 10:14 PM
    Pandaman59
    Pandaman59 Well-Known Member
    Frank
    Arlington
    2017 DCSB
    What is the cost of gearing just wondering.
  5. Jul 28, 2018 at 10:52 PM
    SuperBad
    Dallas, TX
    Truck stuff
    If only regearing your looking at a starting cost of around $1400 for just the gear install kit. Looks like my regear would run up around 3k with addons and shipping after the core exchange.
    Pandaman59[QUOTED] likes this.
  6. Jul 29, 2018 at 8:24 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Truck started to act up this morning. Not sure what's going on but I'm getting paranoid
  7. Jul 29, 2018 at 9:50 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    How so?
    SuperBad likes this.
  8. Jul 29, 2018 at 10:33 AM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Probably made a weird noise like “you’re not my dad”
  9. Jul 29, 2018 at 10:40 AM
    Hilborn
    Michael
    Utah
    It was large cargo flopping around in the bed.
    ETXTacoma, SuperBad and gulzeb like this.
  10. Jul 29, 2018 at 11:17 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You're supposed to gag the hookers before you chuck them in the back
  11. Jul 29, 2018 at 11:29 AM
    Hilborn
    Michael
    Utah
    Rookie mistake.
    Matmo215, Pandaman59 and ETXTacoma like this.
  12. Jul 29, 2018 at 1:18 PM
    hoarder23
    Shay
    NJ
    Scratches
  13. Jul 29, 2018 at 1:19 PM
    ChadsPride
    Sponsored by TacomaWorld.com
  14. Jul 29, 2018 at 3:02 PM
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
  15. Jul 29, 2018 at 3:20 PM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
  16. Jul 29, 2018 at 3:31 PM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Turns out I’m not paranoid, I have a blown ball joint. Thanks SPC. :annoyed:
    ETXTacoma likes this.
  17. Jul 29, 2018 at 3:32 PM
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    The clunking you mentioned awhile back?
    TXTaco13[QUOTED] likes this.
  18. Jul 29, 2018 at 4:00 PM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Yup, has been doing it for a while. The boot appears to be blown on one part, and the binding my buddy saw. And to top it off Tandem is booked for the foreseeable future.
    ztaragon likes this.
  19. Jul 29, 2018 at 4:07 PM
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    I have an extra for sale, but I will not help you install haha
    ztaragon and TXTaco13[QUOTED] like this.
  20. Jul 29, 2018 at 4:08 PM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Victims of their success.
