DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Jan 21, 2020 at 11:39 AM
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    I have a similar Ryobi power washer. It's a damned blessing. I power wash all the things now.
  2. Jan 21, 2020 at 11:41 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Yeah man it’s great. Playing around with soap to water ratios is the hardest part, but I usually use around 4-6oz
  3. Jan 21, 2020 at 11:46 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Yeah that was going to be the fun part.... just how much soap should i use? Is there a special soap they make for this application??
  4. Jan 21, 2020 at 12:11 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    There are marking on the foam cannon bottle. I usually fill it about an inch or two from the bottom. You can use any kind of soap really. The best “cheap” soap you can get almost anywhere I’ve used is the meguiars gold class. Once done with the foam cannon, be sure to wash out all the soap and fill it with just water and run the water through the foam cannon to clean it out so soap build up doesn’t ruin the foam cannon.
  5. Jan 21, 2020 at 12:12 PM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Thanks, Zac!
  6. Jan 21, 2020 at 12:14 PM
    Zac of all trades
    Zac
    fwpfab.com
    Matmo215[QUOTED] likes this.
  7. Jan 21, 2020 at 6:07 PM
    Goose8651
    Goose8651 Well-Known Member
    DFW
    2013 Double Cab
    Best car soap for either foam cannon and standard bucket washes.
    Adam's Car Wash Shampoo (16oz) - pH Auto Detailing & Cleaning Wash Soap | Use W/ 5 Gallon Bucket, Pressure Washer, Foam Cannon or Gun, Sponge, Mop, Mitt, Chamois | Won't Remove Car Wax or Sealant https://www.amazon.com/dp/B0058JJS0Q/ref=cm_sw_r_cp_api_i_536jEb8X56KT1
    also, Chemical Guys Mr. Pink is a great one as well.
  8. Jan 21, 2020 at 6:53 PM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Any of y’all ever sued a mechanic?
    The guy that botched the timing belt job on my truck ended up damaging a camshaft and it’s already ripped a cam seal I just replaced and I’m leaking oil again. :frusty::censored:
    photo I took when I was replacing them.
    Trying to decide if I should just bite the bullet and fix it myself or If I should try and go at him.
    Beretta4x4 and ohwhale.taco like this.
  9. Jan 22, 2020 at 6:23 AM
    Xplosiv
    Jeff
    Lewisville, TX
    Unless you just know he's going to be an ass about it, id approach him first and see if he wants to concede to any kind of compensation. A lawsuit off the bat is just going to piss him off and if he's an independent shop you probably arent going to get much if anything. Probably a wash after legal fees, time expense, days off work, etc....
    The damage doesnt look real deep from that picture, id be tempted to run some emory cloth over it and see if it smooths it out enough to make the seal live.
  10. Jan 22, 2020 at 7:15 AM
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    Anyone local have a Brute Force Fab rear bumper? I did my taxes already and think I found what to do with part of the return. Gotta fix the Supra first, but hope to have enough left over for a bumper.
  11. Jan 22, 2020 at 7:18 AM
    Goose8651
    DFW
    2013 Double Cab
    Mine is a Brute Force, but standard. Not the greatest photo, but its all i have on my phone right now.
    pSgKOIivFHWtGEoTLx8y4bropIMZSYPU1-AX_pw__2127c1b9c561619bc1fc1258186285d0a6351281.jpg
    7GBqbuo0EgH7fJjVxA7WTRqta3wsAtWYbnQZWq6u_6f75e1200fbaeee0e0a0048d5c1c162054e20d3b.jpg
  12. Jan 22, 2020 at 7:28 AM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    I have a HC rear with swing out
  13. Jan 22, 2020 at 7:34 AM
    imthejaybird
    imthejaybird I make things and do stuff. TTC #287
    Jay
    Burleson, Tx
    2006 Tacoma DCSB
    Have you tried the pressure washer yet? I'm intrigued.
  14. Jan 22, 2020 at 7:37 AM
    Suprajim54
    Jimbo
    Irving, TX
    It seems like Brute Force has a very competitive price ($805+shipping) versus others out there and I like that those side bars are no extra charge. I also like the look of the AtTheHelm one, but it's a couple hundred more and doesn't provide as much side protection. Hopefully there are some Tax Time sales coming up!
  15. Jan 22, 2020 at 7:55 AM
    Sreppep
    Philip
    Fort Worth, TX
    I’ve reached out to him and explained the situation, he has hasn’t made any effort at all to do anything.
    The reason this all started is because I started leaking oil really bad a week after he did timing belt job, I took it to him and it sat at his shop two weeks and he finally diagnosed it leaking because supposedly the oil filter was loose.
    That obviously wasn’t the issue because I continued to leak oil, after 6 months I decided to try and find where it was coming from myself so I cleaned everything really well and found it leaking from behind the timing covers, when I pulled the cover back I noticed a large laceration on the timing belt itself.
    I wasn’t about to let him work on it again and diagnose it something other than what I expected it to.
    So I ordered everything I needed and did the job myself. Then sent him photos of the belt and torn cam seal still on the truck after I finished the job and was like I’m not asking for a full refund but I’d like to be compensated for my time.
    I noticed when I pulled the cam seal that the person that pulled it before I did had used a flathead screw driver or something on it a damaged it trying to pull the seal. So I sanded lightly with some fine grit to and hit and any sharp edges but some of the damage is pretty far in there and will be hard to reach unless I pull the valve covers.
    I’m thinking it will be a huge PIA to take him to court or anything over it. I’d spend more time with that than actually fixing it.
    I may mail him a well written letter and see if that gets me anywhere with getting some type of compensation.
    I havnt went guns blazing at him but I have stated the facts of the situation.
    Xplosiv[QUOTED] likes this.
  16. Jan 22, 2020 at 7:57 AM
    Sreppep
    Philip
    Fort Worth, TX
    Did you paint your center caps? I have the same wheels but like that yours are solid with red lettering
  17. Jan 22, 2020 at 8:33 AM
    Goose8651
    DFW
    2013 Double Cab
    Yes, I painted the caps and had some TRD vinyl made for the red portion.
  18. Jan 22, 2020 at 8:54 AM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    @HCJ
    Pandaman59, HCJ and ohwhale.taco like this.
  19. Jan 22, 2020 at 8:59 AM
    ohwhale.taco
    ohwhale.taco Well-Known Member
    Keller, TX
    17 Wife Transporter
    Fox 2.5 DSC, SCS, 285's
    I'd include in that letter that you're not afraid to use every review resource at your disposal to make sure people hear about the shotty work. (BBB, Google reviews, even file a complaint with the Attorney General's office)
    I've used this tactic a couple times and wound up with a much better result than I ever expected. Businesses are scared of bad reviews and claims filed against them.
  20. Jan 22, 2020 at 9:00 AM
    ohwhale.taco
    Keller, TX
    17 Wife Transporter
    Sup bro, @Beef Nachos let me know when you're feeling some Jalapenos again
    Pandaman59 and Beef Nachos like this.
