DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Apr 10, 2017 at 7:05 AM
    #5941
    Geremy
    Geremy I like big tires and I cannot lie.
    Geremy
    2017 TRD OR DCSB
    Awesome. Not a single problem out of it. The trailer hitch drug on black gap road once. But it was a pretty steep departure angle. I could see it was coming up to it.
  2. Apr 10, 2017 at 7:21 AM
    #5942
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    I can help with the uca's sometime. If we have a mod day. I've the grease thats spc approved to fill them also. Bought it when I did mine.
    Geremy[QUOTED] likes this.
  3. Apr 10, 2017 at 7:25 AM
    #5943
    Geremy
    Geremy
    2017 TRD OR DCSB
    lessons learned. I need a CB. I only had a 2way and it forced @Suprajim54 to have to relay everything to me. So, I'll be purchasing that today. Also, I'm going to try and save for a softtopper. I think that would help with the dirt/dust in the dessert places. Plus they look badass.
    RTT look awesome and def are easy to setup but I did ok with the ground tent. I may invest in a better ground tent/matress and that should hold me over.
    Looking at this CB mount and adding a 4ft fire stick.
    https://www.amazon.com/FireStik-MK-204R-Adjustable-Antenna-Mini-Kit/dp/B000X39TQ0/ref=cm_wl_huc_item
    Thoughts? For the CB I was going to get the one @thedrewsifer uses and see if I could get the Hondo Garage ram mount to hold it.
  4. Apr 10, 2017 at 7:48 AM
    #5944
    rpkole
    rpkole Well-Known Member
    Fort Worth, TX
    2014 MGM 4x4 DCSB
    there is also this if you dont like the ground
    http://hitch-hammock.com/products/hitch-hammock
    SuperBad likes this.
  5. Apr 10, 2017 at 7:49 AM
    #5945
    Geremy
    Geremy
    2017 TRD OR DCSB
  6. Apr 10, 2017 at 7:50 AM
    #5946
    Silverspool
    Silverspool [OP] Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Considered a tent cot? Since these trips will be solo for you, iirc, might be perfect.
    Soft toppers are pretty cool tho
    SuperBad and Geremy[QUOTED] like this.
  7. Apr 10, 2017 at 8:06 AM
    #5947
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I wouldn't recommend that mount. You would have a hard time mounting it cleanly. Get a mount that is designed for a Tacoma, it will be more expensive but work better.
  8. Apr 10, 2017 at 8:08 AM
    #5948
    Geremy
    Geremy
    2017 TRD OR DCSB
    Any links? I have not been able to find one. C4 fabrication had one but they pulled it from their sight due to rubbing issues on the tail gate.
  9. Apr 10, 2017 at 8:23 AM
    #5949
    hoarder23
    Shay
    NJ
    Scratches
  10. Apr 10, 2017 at 8:27 AM
    #5950
    Geremy
    Geremy
    2017 TRD OR DCSB
  11. Apr 10, 2017 at 8:33 AM
    #5951
    rpkole
    Fort Worth, TX
    2014 MGM 4x4 DCSB
  12. Apr 10, 2017 at 8:39 AM
    #5952
    rpkole
    Fort Worth, TX
    2014 MGM 4x4 DCSB
  13. Apr 10, 2017 at 8:40 AM
    #5953
    Geremy
    Geremy
    2017 TRD OR DCSB
  14. Apr 10, 2017 at 8:45 AM
    #5954
    hoarder23
    Shay
    NJ
    Scratches
    I hate the way those look but they are likely your best option.
    The problem with the tailgate mounts is for them to be strong enough to hold up to the stress of the antenna flapping around for a long time they have to be so thick that they will rub the paint on your tailgate or bedside.
  15. Apr 10, 2017 at 8:49 AM
    #5955
    hoarder23
    Shay
    NJ
    Scratches
    Another option
  16. Apr 10, 2017 at 8:55 AM
    #5956
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    another option is handheld if you wont be using it for anything other than convoys. when i used mine as a handheld during a night wheeling trip, it worked great and 1 set of batteries lasted the evening
    Fixed mount is ideal for power source and range however.
  17. Apr 10, 2017 at 9:12 AM
    #5957
    Geremy
    Geremy
    2017 TRD OR DCSB
    I guess i'll go fixed. Looks cooler. :D
  18. Apr 10, 2017 at 9:14 AM
    #5958
    hoarder23
    Shay
    NJ
    Scratches
    Sounds like you need a front bumper and a 15' whip hooked to the rear of the Softopper
  19. Apr 10, 2017 at 9:28 AM
    #5959
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I have a Pelfreybilt one that mounts between the tailgate and bed side, similar to some others. No rubbing here, but maybe my bed is bending/needs reinforcement brackets.
  20. Apr 10, 2017 at 9:31 AM
    #5960
    SuperBad
    Dallas, TX
    Truck stuff
