DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Dec 5, 2017 at 8:58 AM
    Silverspool
    Silverspool [OP] Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    @reasonselzzz
    Snorkel is back on the market.
    ztaragon, ETXTacoma and ChadsPride like this.
  2. Dec 5, 2017 at 9:01 AM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Awwww who backed out?
    So I can shame them.
    ztaragon and ChadsPride like this.
  3. Dec 5, 2017 at 9:06 AM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    you interested in the snorkel? look real good on instagram
  4. Dec 5, 2017 at 9:26 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Nope.... cause I have something on the way already.
  5. Dec 5, 2017 at 9:30 AM
    ETXTacoma
    Steven
    Tyler, Texas
    @Jamart5
    You back out on buying a snorkel?
  6. Dec 5, 2017 at 9:54 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Truck back? It’s at the house.
  7. Dec 5, 2017 at 10:07 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    :ohsnap:
    ztaragon likes this.
  8. Dec 5, 2017 at 10:38 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Can we have a mod day soon? I just got quoted 6-7 hrs labor for AAL, u-bolt flip and lower grille light bar. Can’t be throwing that much money away. 2 hrs just for wiring the light...
  9. Dec 5, 2017 at 10:39 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Light can easily be done solo. There are several guides on here. AAL and ubolts are a good combo, but an extra set of hands is helpful there.
  10. Dec 5, 2017 at 10:43 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    I have the added complication of also having an avid bumper guard mounted in same slot, and I have never wired any lights before, so that one actually feels the toughest to me.
    Edit: For the rear, what I’ve done myself so far is add blocks and change shocks, so AAl and U-Bolt flip will be an incremental learning experience.
  11. Dec 5, 2017 at 11:02 AM
    ztaragon
    ztaragon @zta.co
    Burleson
    2019 TRD OR DCSB
    Fox 2.5 non resi fron Fox 2.0 rear with resi Toytec AAL 285 75 16 Nitto Ridge Grappler Method wheels
    2 hrs. wiring a light to the front?? that's about a 40 min job max.. where do you live? my buddy has a shop in Mansfield, did my aal, ome springs, and bilsteins back on my old setup with alignment for about $350 bucks. He is cheap and solid
  12. Dec 5, 2017 at 11:05 AM
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    Doing the AAL is only a few steps past what you did to add the lift block. Once the U-Bolts are off, jack up the frame away from the axle and loosen the center bolt holding the leaf pack together. Slide the AAL above the overload leaf, use a C-Clamp or two to compress the leafs back together and insert the new longer center bolt. Tighten it all back down, use a hacksaw/Dremel to remove the excess and check that you can put the bump stop back on. U Bolt Flip should be self explanatory, plate on top of the leaf pack and U-Bolts go in from the bottom.
    Lights should also be easy if you bought a harness with a relay. Most come with a switch so you only need to worry about running the wiring into the cab. Feed the wiring through the grommet on the drivers side firewall where other wires come in and connect wires to the battery.
    gulzeb[QUOTED] and ztaragon like this.
  13. Dec 5, 2017 at 11:09 AM
    Crash721
    Crash721 Well-Known Member
    Brandon
    2013 Tacoma PreRunner
    285/70/17 BFG KO2's 4" Maxtrac spindle lift kit. Caliraised 30" slim led bar
    The light is def not to difficult If I can figure it out then anyone should be able to lol. I dont mind helping at all mine probably took about 45 mins like @ztaragon said
  14. Dec 5, 2017 at 11:12 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Helps my confidence to have someone who’s done it before oversee it :D
    Would need to flip my timbren bumpstops as well, as part of the u-bolt flip.
    Beef Nachos likes this.
  15. Dec 5, 2017 at 11:13 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Hello...
    Someone say mod day?
    ztaragon and gulzeb[QUOTED] like this.
  16. Dec 5, 2017 at 11:13 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Holy shit, we did a leaf spring swap at one of the campsites in gilmer for @TRD493 in maybe in hour, front UCAS, solid bushing and coilovers in 2-3 hours if that. Wire your own relay it’s not bad, I can find you a diagram and it will make it look so easy, 4 wires and another ground switch isn’t bad either.
  17. Dec 5, 2017 at 11:16 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    RC/Mod day?
  18. Dec 5, 2017 at 11:17 AM
    ETXTacoma
    Steven
    Tyler, Texas
    Ughhhhhh fine.
  19. Dec 5, 2017 at 11:18 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    :D
    ETXTacoma[QUOTED] and ChadsPride like this.
  20. Dec 5, 2017 at 11:31 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    My wife found a babysitter finally, so I might actually be able to tackle this on the weekend. If anyone wants to drink beer and guide/supervise, let me know.
    I also have stainless brake lines, but I’m thinking I should leave those to professionals.
