DFW BS Thread : ********NEW MEET!! CHECK POST #1*******
Discussion in 'Texas' started by Silverspool, Jul 20, 2016.
  1. Dec 5, 2017 at 11:32 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I have a ‘14, but also had the avid and vailence bar. Shouldn’t be a problem.
    gulzeb[QUOTED] likes this.
  2. Dec 5, 2017 at 11:42 AM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I'll be doing the same thing you are as soon as my truck is out of the body shop next week. I'm down to assist/supervise.
    Coot83 likes this.
  3. Dec 5, 2017 at 11:44 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Sending PM
    ChadsPride likes this.
  4. Dec 5, 2017 at 11:51 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    You can easily handle all that stuff if you have a day or two to learn the ropes with the install or have a buddy who has done it before. When doing brake lines, I strongly encourage you to get the brake line wrenches that have the very tight tolerancing (I forget the official name) in size 10. If you use a regular wrench, you will likely strip out the stock hosing which can make the job very difficult. Another thing, I would over the span of the rest of the week spray ALL THE AREAS that are getting wrenched on with liquid wrench or PB blaster. The longer this stuff sits, the better it works and another pass a day or so later after the first spray helps too. On the brake lines, I did three days of spraying on them as from the factory they are pretty tight and need a good amount of loosening to get them off.
    As far as the lighting is concerned, many of the lights come with a single line diagram. These diagrams are pretty self explanatory most of the time with the positive/negative leads and if there are any components like a switch, relay, and or fuse in the circuit path. Worst case, you hook up the wiring the opposite way and blow the 15-30 amp fuse in the wiring harness and then have to buy a back up at advanced auto.
    Unfortunately I am already out of the area and back home for now as Austin might be calling me soon...but feel free to send me a PDF/link to your instructions for the wiring and I can decipher it if you cant.
    The first real project I did on my truck was installing coilovers which had me really nervous because I didn't know jack about the truck. After you familiarize yourself with some of the components, you will realize how easy they designed the Tacoma to be worked on by the common man. Never hurts to have a teacher along with ya, but wrenching on it instead of paying someone will give you excellent experience should a situation arise where you have to deal with swapping out a part or two on the trail or on the road.
  5. Dec 5, 2017 at 12:04 PM
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    Get a set of flare nut/line wrenches and a brake bleeding tool at Harbor Freight. Brake lines should be easy to replace. But you'll just have to bleed a lot of air from the lines.
    To use the brake bleeder tool, just loosen the bleeding nipple on the caliper, put the hose over the nipple and connect to the plastic jar with a little brake fluid in it. Connect another hose from the jar to the gun and just start squeezing the trigger. Keep squeezing until you get no more air bubbles and its just pulling fluid. Then, tighten the nipple. Keep the master cylinder topped up as you get the air out of the lines.
  6. Dec 5, 2017 at 12:05 PM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    I need to acquire those two tools there....
    trekker likes this.
  7. Dec 5, 2017 at 12:10 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    I guess I should start looking for the nipple and the master cylinder. I do know where the caliper is :D
    That job I was quoted 1.5 hrs btw
  8. Dec 5, 2017 at 12:32 PM
    Suprajim54
    Jimbo
    Irving, TX
    Brake bleeder should be on the backside of the caliper. There may be a small rubber dust cap on it.
    Master cylinder is under the hood near driver side and has the brake fluid reservoir. Keep the fluid level above the lower line to be sure you don't suck all the fluid out of the reservoir and start drawing air in.
  9. Dec 5, 2017 at 12:32 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Do you know if the wheelers’ 2” AAL goes at the bottom? Depending on length, it might need to be put in the middle.
    Edit: by bottom I mean just above overload
  10. Dec 5, 2017 at 12:36 PM
    Suprajim54
    Jimbo
    Irving, TX
    I got the Wheelers AAL and put it above the flat overload leaf, but under the 3 curved factory leaf springs.
  11. Dec 5, 2017 at 12:37 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    No twisting or breaking this time? What brand was it that broke?
  12. Dec 5, 2017 at 12:38 PM
    Suprajim54
    Jimbo
    Irving, TX
    The first AAL set i put in was from Toytec. This time I went with Wheelers.
  13. Dec 5, 2017 at 2:19 PM
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Yeah stuff going on right now.
    ETXTacoma[QUOTED] and ztaragon like this.
  14. Dec 5, 2017 at 2:26 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Dammit Juan I need to know by Friday
    ztaragon likes this.
  15. Dec 5, 2017 at 2:31 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Get speed bleeders and turn it into a one man job. I'm happy to help with all but the light since I hate electrical.
    Brake lines, AAL, Ubolt flip are all simple installs with hand tools.
    ztaragon and gulzeb[QUOTED] like this.
  16. Dec 5, 2017 at 2:35 PM
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    I’ve passed
  17. Dec 5, 2017 at 2:39 PM
    Silverspool
    Silverspool [OP] Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    My condolences
  18. Dec 5, 2017 at 3:57 PM
    lordetaco
    lordetaco Well-Known Member
    Tristan
    Lawton,OK
    2005 Toyota Tacoma
    I plan on doing this soon, so if I only do the rear do I still need to bleed the front as well?
  19. Dec 5, 2017 at 4:01 PM
    Suprajim54
    Jimbo
    Irving, TX
    Should be fine as long as you keep the master cylinder topped up and no additional air comes in from the reservoir when bleeding the rear. If the pedal feels spongy afterward, then maybe check the front.
  20. Dec 5, 2017 at 6:48 PM
    hoarder23
    Shay
    NJ
    Scratches
    @gulzeb asked and I am willing to host another Mod Day this Saturday. He needs stuff done, there's a slight chance my truck will be back and I need help putting it back together. I'm sure some others have some things they'd like done or would like to just watch and learn.
